PLL hardmod ???
  • Retrorockit
    • Feb 2020
    • 105
    PLL hardmod ???
    I'm trying to learn, but what I'm wanting to try has never been done ASFIK.
    There used to be a PLL hard mod that socket 478 laptop guys used to run a pull down resistor so the PLL wouldn't be locked to some selected fsb value.
    I've studied the datasheet for my PLL and found the relevant pin. A high value from the BIOS latches my PLL to 266fsb maximum. On LGA775 thay defeat the resistor mod by runnning a PCI frequency out put on the same pin. My question is if I lifted that pin, and put a diode so the PCI output was still there, would the lack of any low signal input cause an error, or would it just pass as a low signal and alllow the FSB to be unlocked?
    This is for an XPS 410 overclocking project. It's Dell, it's BTX, it's P4 era.
    But I've had the related Dimension E520 to 4GHz with a QX6800 in 2015. I've got a few more tricks up my sleeve this time. I think I can reset this bit with Clockgen. But I'm already doing my multipliers and Voltage with another program. So i'm a little concerned about being able to save this setting.
  • Retrorockit
    • Feb 2020
    • 105
    Re: PLL hardmod ???
    I learned a few new abreviations and looked further down the datasheet and figured it out.
    Vil = min .3V /max .8V
    So there does need to be a signal Voltage to set the TME pin to low.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      Re: PLL hardmod ???
      QX6800?! Isn't that one of the 65nm Quads?! Those at 4 Ghz are likely to use more watts than an FX, possibly a lot more than an FX9590! That will dwarf a Prescott there!
      Heck, most 65nm Core 2 Quads at 3.6 pull 250 W or the like alone!
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • Retrorockit
        • Feb 2020
        • 105
        Re: PLL hardmod ???
        Here's my CPUZ of my MicroBTX Dimension E520. QX6800 4GHz.
        http://valid.x86.fr/bg4n0r
        It was in 2nd place for a couple years in 2015. I got bumped by a few MHz in 2017. The full multiplier overclock, and old capacitors kept me from responding.
        The Dimension 9200/XPS410 can use Setfsb for smaller increments, and new caps should let me maybe go a little higher. I mentioned at OCN LGA775 Club that BTX was designed for higher clock speeds in LGA 775 than ATX and got jumped by some ASUS fanboys.
        But the 4 phase VRM of the XPS210/410,Dim. 9200/9200C/E520 with some heatsinks is pretty stout. BTX is all about VRM cooling and high clock speeds.
        I also have some better coolers and fans than I had then. I was running the 2 motor Delta GFB121VHG 3.4A. fan off of a Molex to free up some power on the 18A rail of the Dell PSU. I'll be running a single rail EVGA PSU that has enough on the 5V. rail to run one of these.
        Throttlestop can be hacked to OC just 2 cores which will annoy hell out of the ASUS boys. But actually makes sense for a retro gamer since SSE3 is the highest instruction set then anyway.
        But 130W PentiumD CPUs and 3.8 GHz P4 were what this was designed for.
        I didn't know it at the time but I could have underclocked the fsb with Setfsb, added another multiplier and come back up. But a 12 year old computer, with known bad caps, that had been OC was on it's last legs.
        For cheap thrills the Optiplex 745 can OC also, but the 3 phase VRM holds it back about 1 multiplier.
        • Retrorockit
          Overclockable Dell computers.
          by Retrorockit
          Many Dell computers can be upgraded beyond what they were offered with and even overclocked in many cases. This may make repairing one of these more viable than it would seem. I've been playing with the BTX versions so much of what I say will be referring to those.
          Of the BTX Optiplexes, most of them have a 95W CPU hard limit. Typically a Q9650 is the maximum, For single thread Apps, an E7500 2 core can be tape modded to 3.66GHz.
          The exceptions are the Opti 745 which due to PentiumD suppport can support a QX6800 and can be overclocked using Throttlestop 6.0 software.
          The...
          02-20-2020, 05:58 AM
        • bigbeark
          ECS K7S5a PRO wierdness
          by bigbeark
          So I have this K7s5a PRO, no bad caps, but it wouldn't load Ubuntu via the CD Drive. Tried switching drives, cables ets but no luck.
          A couple of weeks ago i recapped it, got rid of all the OST and G-Luxons.
          Had to move the SCSI card around but finally it likes a PCI slot and I'm off to the races, board works good, runs a bit hot (53C).
          The other day it wont boot. I note the CD Drive is blinking. I pull the cable and it boots up fine. But it can't read the SCSI drive. Pulled the board out of the case, went over my solder joints. Decide to try a different...
          06-07-2011, 08:11 AM
        • nogger
          Samsung Plasma PSU BN44-00162a (0r 061A)
          by nogger
          Hi all, just wondered if anyone has good experience repairing this PSU used in PS50Q97HDX & other plasma's.
          Story so far:
          I have a Sammy Plasma PSU BN4-00162A on the bench at the moment which blew its VS mosfets, 8Amp fuse etc . I changed them after checking the usual sub board components etc & also checked the VA tract & components. I powered up & strangely the VA tract now blew it's mosfets even though they all measured ok. Anyway, VA mosfets changed & surface mount & sub boards checked again & now i have the PSU runnning ok with correct...
          01-31-2013, 09:13 AM
        • rephlex
          2 dead monitors, blueh h94w and amw x1700ds
          by rephlex
          Hi, I have two monitors with PSU problems and I was wondering if anyone had any ideas on what could be wrong with them before I replace all the capacitors.
          The blueh monitor works for a few minuites before cutting out. The monitor has to be left for a while before it will work again (cool down?). The voltages are OK until the screen cuts out, at which point the 5v rail drops to 4.6. Runnning the monitor off an external 5v PSU solves the problem.
          The board has ILPI-068 written on it.
          The other monitor doesn't turn on (not even the LED). I left the monitor at work so...
          03-20-2010, 08:22 AM
        • Uranium-235
          Dell D610 bleed resistor
          by Uranium-235
          so I replaced a jack on this top, and I accidently got my hakko too close to these two tiny surface mounted resistors and broke them off. I took my meter and realized they are a direct line between voltage and ground, which makes them an very high resistance bleed resistor. I found one and could not get it to register on my meter cause ether its damaged or the resistance is just so high. do you think the laptop can work without them (two of them, one for charge, one for runnning power-its a dell thing as the power adapter has two power rails too).
          if not, what do you think the resistance...
          01-23-2011, 08:39 PM
