Mosfet Power dissipation question
  • holmzy
    • Nov 2009
    • 99
    Re: Mosfet Power dissipation question
    Originally posted by budm
    So adjust it to be 0mV +/- 30mV offset then.
    LOL I was doing that then shorted the leads and blew the MOSFETs!
      I know you have blown the MOSFET's when you shorted the leads together so now you have new MOSFET's so why can't you adjust it be within the spec? It has 100mV offset right now, correct? Unless I read the whole thing wrong. Or are you saying you blown the NEW MOSFET's when you try to adjust the offset.
      BTW, since NE is obsolete, hope the NE you find is not faked.
      https://www.mouser.com/ProductDetail...%252BE9Q%3D%3D
      • holmzy
        • Nov 2009
        • 99
        Yes the new NF replacement I blew also. The original I blew touching the speaker cables and the NF I blew by touching the DC offset leads!
        I have found a source who claims to sell originals. But as mentioned I need to understand this Power Dissipation thing before I decide on the transistors as I'm worried about the heat produced
          Try checking the idling current sensing 2 Ohms resistor and Diode of the blown channel (I do not know which channel was blown) R321/D305(L) and R421/D405 (R) to make sure they are not damaged. At 180mV of bias setting, the idling current will be 180mV/2 Ohms = 90mA. May be the value of the resistance has gone down so to get the 180mV reading the idling current has to go up.
          Regarding to the MOSFETs, I do not see any graphs for the NE so you can compare the difference in details to the NF, in the idling mode we do not know what the Rds is to calculate the power dissipation at 90mA of current.
          • Jane
            How do you test MOSFET in laptops ?
            by Jane
            I tried to use this method:
            Testing an N-channel MOSFET:
            Step 1: Discharge the Gate (turn off the MOSFET)
            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
            Step 2: Charge the Gate (turn on the MOSFET)
            Now, place the red probe on the Gate (G) and the black probe on the
            09-27-2024, 03:31 AM
          • Nooy
            VGA MOSfet permanently shorted and loss of MOSfet pad
            by Nooy
            Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
            I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
            02-14-2024, 02:26 AM
          • redbaron1007
            Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
            by redbaron1007
            I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
            Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
            09-09-2025, 11:10 AM
          • AppleLover123
            Asus X712EA 3 volts after the first mosfet
            by AppleLover123
            Hey guys,
            i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
            I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
            Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
            I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
            Now i thought something...
            12-15-2024, 07:49 AM
          • MicroSMD Lab
            by MicroSMD Lab
            I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
            01-10-2024, 06:36 AM
