Has anyone used this module before UPS DC- DC converter
    • Jul 2011
    • 6037
    I bought four of these for a project that I am working on
    UPS Mobile Power DIY Board Charger Step-up DC DC Converter Module 5V 2.1A Output
    I about to test this board and see how well it works
    Here is the website link to where you can buy some if you are interested in some
    https://www.ebay.com/itm/UPS-Mobile-...53.m2749.l2649
    ( You might not find all versions available from this seller )
    Look at application number 2 this is how I going to use them
    You can get in the 5 volt / 6 volt / 9 volt / 12 volt versions of them
    • Jul 2011
    • 6037
    Re: Has anyone used this module before UPS DC- DC converter
    This is the results of some rough testing the small little board is real fun to solder the wires to the board because the spacing are a little close to each other
    The little board seem to charge the battery with out any problems but I have not time to fully test yet
    • AlexVG
      Replacing the WiFi module on a vacuum cleaner iROBOT i7
      by AlexVG
      I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
      I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
      (This board does not respond, only the LEDs light up in a circle.
      The liquid damage is catastrophic and restoration is impractical).
      (I bought this board to get the WiFi module and camera).
      The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
      If...
      10-22-2024, 07:20 AM
    • repair-it
      TOSHIBA DLP 52HM95 How to reset timer module on bulb
      by repair-it
      I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
      Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
      10-11-2023, 07:18 PM
    • ut-norm
      converter dc dc 12/34 volt
      by ut-norm
      Hello everyone I am trying to repair this 12/34 volt dc dc converter powered, by mistake, with an unsuitable generator set.I have restored the 5 volt voltage that powers the R5F21134FP controller that has been replaced and I would like to replace the resonator too 3 pin ceramic indicated with a black arrow in the photo which I fear was damaged by heat during the disassembly of the controller. Unfortunately I can not determine the value. On the tiny container is printed an A followed by an incomprehensible sign.
      I attach the datasheet of the controller and the photos of the board.
      05-01-2021, 10:28 AM
    • m1ch43lzm
      70mai Dash Cam A510 - help identifying connector on camera module
      by m1ch43lzm
      Hi everyone
      I have a 70mai Dash Cam A510 which failed after about 3 months of being installed in my car, likely due to heat, i got it from aliexpress so no point in trying to return it for warranty (and shipping it back would cost me almost the same as a new one from ali)
      The camera would boot loop showing 70mai logo on the screen, sometimes it would boot fine then the live view would freeze or display purple lines
      I already took it apart, and found out that the camera boots fine if i unplug the camera module from the main PCB, sometimes "playing" with the connector...
      05-11-2025, 06:02 PM
      Light that has a bug zapper in bottom section of light fixture the LED light module took a crap but the zapper still works
      So I got the bright idea to remove the LED light module from the fixture and put it on top of another enclosure and keep using the zapper
      The removal of light module was a successful and now I just have to cut a hole in the enclosure and put a power cord that has an on and off switch on it
      You are lucky to get about two years of service out of one before the LED module starts flicking and just stops working because it is mounted on an aluminum plate and these are hard to solder on it and it is not worth messing around with them and especially this one because it has line...
      09-07-2024, 07:26 PM
