RFID zapper
  • madan1
    • Nov 2016
    • 726
    • Bulgaria
    RFID zapper
    Howdy everyone.
    Some background - I'm bored AF.. you know.. lockdowns.. closed gyms, pubs, bars... stay home.. etc.. and just got my new passport. This time it contains RFID with some biometrics.. and I'm not comfortable with that.
    Yes, yes, I know it is illegal to temper with official documents and stuff.. but I also like my privacy.
    So I was thinking about how to kill the rfid without leaving any traces.. and I remembered that I have one of those taser modules ( only the high-voltage module ).
    Here is what I'm thinking:
    -get a very strong light and see what antenna is embedded in the passport ( by the way it can be read with a phone )
    -find a similar antenna from rfid sticker or make one from few coils of copper wire
    -connect the antenna to one of the taser module outputs
    -let the spark jump between the antenna and the other taser output
    -put the passport close to the taser antenna
    -let the mo**erfocker burn! Burn, mo**erfocker, burn!
    So, do you think this will work?
    • 31258
    Re: RFID zapper
    no,
    it works by using a coil to receive energy that charges a cap to power the chip(s)
    if you want to wreck one you overload the coil with a big alternating magnetic field.
    maybe with a bulk tape eraser or a degausing wand/gun
    you see supermarkets use them to disable the stickers with a coil in them at the checkout.
    actually a spark discharge may corrupt the memory though. - but you have no way to know.
    • madan1
      • Nov 2016
      • 726
      • Bulgaria
      Re: RFID zapper
      Well, today was the day .
      See the photos for the setup and some result images.
      So first I tried it on a RFID fest card and I must admit, I overcooked it.. I left the taser on for about 5 seconds and now there is a visible melt dot on one side of the card and a bulge on the other.
      Test 2 - similar RFID fest card, but this time I just touched the battery with the wire.. so I guess just few milliseconds. Nothing visible on the card, but no more readable on the phone.
      The real deal - the passport. First confirmed that the phone can detect it.
      A little zap as in test 2 and the phone no more detects it. No visible marks.
      So I guess mission accomplished. Due to the current viral situation I guess I'll not be able to test the passport on any border soon, but I will post if any issues appear .
        • 31258
        Re: RFID zapper
        nice
        btw, if you have a frequency generator and a scope (i only have a scope) it would be interesting to see what frequency different chips respond to.
        specially the chips in money that most people have not noticed yet!!!
        those must use a pretty high frequency because of the shorter antenna.
          • 31258
          Re: RFID zapper
          incidentally, this "lock down" so-called, is drawing out the lunacy in people!
          https://www.youtube.com/watch?v=-9RB3T_kVh4
          • madan1
            • Nov 2016
            • 726
            • Bulgaria
            Re: RFID zapper
            Originally posted by stj
            nice
            I do not have a real freq.gen. or either a scope ( I have a DIY kit scope basically suitable only for analog audio signals and some spsu )
            but, I will be interested in reading more about the chips in money.. hmm... that's the first time I hear about that. By now, I knew that "they" were able to read variable RFIDs from 20+ meters and implementing the technology for tracking people... I do not know how far this has gone tho.
            That guy is crazy AF! I do not think I'll ever be that bored
            Still, soon I'll try to cook other devices. By the way any idea how to measure the induced voltage in the affected devices (pcbs) without killing the not-that-cheap-but-still-amateur-digital-multimeter ?
              • 31258
              Re: RFID zapper
              well reading voltage is easy, just make a resistive divider before the meter with high-voltage resistors in series (for physical spacing)
              but i dont know how you would get access to the pcb tracks!
              about the money - there are utube video's of people blowing the chips up in euro-notes by putting them in the microwave oven!
              i also know that the latest high-value coins have chips in because i know people in the cash-handling industry - but even they dont know how to communicate with them yet!!
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                Re: RFID zapper
                This made me laugh and I like the idea at the same time, though please care to explain where you place the "victims" to kill them: directly over the coil you taped to the desk, or close to the spark gap ? What wire did you use and how many turns of it ? Looks pretty thick.
                I'd like to do this to my credit card to disable NFC without leaving marks, though I think this would also kill the chip, making the card useless, since the NFC part is the same as the visible chip...
                Wattevah...
                • madan1
                  • Nov 2016
                  • 726
                  • Bulgaria
                  Re: RFID zapper
                  The victim's antenna is placed right over the coil.
                  I used this wire gauge, because this was the first copper wire I saw ... but I guess anything that can handle few hundreds of kV pulses without melting will do the work.
                  The windings are 7 .. that's how many I counted on an RFID sticker.
                  The idea ( at least in my head ) is that the coil charge/discharge will induce similar in the victim's antenna which will kill the chip.
                  I guess if you shorten all pins of the chip you want to protect and then ground/earth them you might be able to save it and meanwhile kill the RFID. Still, if you do not have at least one extra card for tests, it will better just to puncture the RFID chip.
                  By the way, just tried to cook an old ipod mp3 player... no luck.. I guess due to the massive metal back cover.
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    Re: RFID zapper
                    Sure wish a large EMP device like this existed to wipe out annoying music sources around here >_>
                    Wattevah...
                    • madan1
                      • Nov 2016
                      • 726
                      • Bulgaria
                      Re: RFID zapper
                      Such devices do exist... but you can't put your hands on them unless you are military or some of their contractors.
                      There are rumors about hand-held devices that can stop a car from several hundreds of meters.
                      And then we have the mother of all EMPs - high altitude/stratosphere nuclear explosion, which can cook the electrical system of whole countries.
                        • 31258
                        Re: RFID zapper
                        the car thing is a myth from fast & furious2
                        there is only 3 ways to create a large emp,
                        1: get lightning to strike your enemy!
                        2: nuke your enemy! - but it's only a local emp - you cant kill a city with an air-burst, that's more hollywood bs.
                        3: make an emp bomb - and get thrown in prison forever!
                        because an emp bomb is based on a big bomb with an added pre-charged coil and some related bits.
                        • madan1
                          • Nov 2016
                          • 726
                          • Bulgaria
                          Re: RFID zapper
                          The hand-held emp gun has been hinted is several documentaries.. one of which was about how a swat ( or special forces, etc. ) team captured a serbian war criminal.. the exact quote was that they made an ambush on the highway and were able to remotely stop the car from 100+ meters.
                          In other documentary ( I can't remember what it was about ) the hinted that the US military has such such a portable device capable of frying electronics from distance.
                          About the high-altitude nucl. expl. - https://en.wikipedia.org/wiki/Starfish_Prime
                            • 31258
                            Re: RFID zapper
                            given the fact that the serbian guy probably had a distributor and carb on his car, i still call BS.
                            besides, car electronics are shielded to hell and back - both physically and with the electronics.
                            diodes, movs, filters all over the things.
                            • ttmi100x
                              HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                              by ttmi100x
                              Greetings everyone,
                              I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                              The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                              Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                              Upon closer inspection...
                              07-31-2024, 06:36 PM
                            • howardc64
                              Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
                              by howardc64
                              Eventually discovered a burn mark near lower corner of LCD. Here is a summary
                              • Backlight on, no image
                              • Disconnect right buffer board (view from front), left side display comes on
                              • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
                              • Buffer board is pretty simple
                              Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
                              07-11-2025, 04:04 PM
                            • Tom41
                              AOC U27G3X strange burn-in
                              by Tom41
                              I have an AOC U27G3X 4K gaming monitor that I use both as a TV and for gaming on a Nintendo Switch 2 console. Recently, something very strange has been happening to it. After playing a game that has an on-screen timer for a few minutes, the last digit of the timer (the one rapidly flickering from 0 to 9) appears to burn in on the monitor. Going to a different source or power cycling the monitor does not help; there is a constant flickering area on the screen where that digit was.
                              It seems strange that only that digit would burn in, and NOT the other digits that are changing less frequently....
                              10-23-2025, 04:33 AM
                              Light that has a bug zapper in bottom section of light fixture the LED light module took a crap but the zapper still works
                              by sam_sam_sam
                              So I got the bright idea to remove the LED light module from the fixture and put it on top of another enclosure and keep using the zapper
                              The removal of light module was a successful and now I just have to cut a hole in the enclosure and put a power cord that has an on and off switch on it
                              You are lucky to get about two years of service out of one before the LED module starts flicking and just stops working because it is mounted on an aluminum plate and these are hard to solder on it and it is not worth messing around with them and especially this one because it has line...
                              09-07-2024, 07:26 PM
                            • ktmmotocross
                              Dell G15 5511 LA-K455P - new gpu fan burn SIO pwm sig. in SIO MEC1515
                              by ktmmotocross
                              Hello. Have this Dell G15 5511 la-k455p that new gpu fan burn and left pwm sig from sio with 10 ohms.
                              I read that this sio MEC1515 must be programmed, but someone says dont. My Vertyanov seems dont have this model in it.
                              Laptop works and can be tricked by split pwm, but i dont want to do this stuff this way.
                              So anyone really knows if it must be programmed?
                              09-16-2025, 07:11 AM
