Behavior of Faulty IC's
  • sigmeyer
    • Feb 2020
    • 147
    • Serbia
    Hi everyone ,
    I just have a random question that i think many noobs like me would stop and wonder sometimes...
    I was wondering is it possible that a chip with many pins , still have a part of it working but other part being faulty? And what are the chances of that?
    Im not talking about mosfets or transistors , but complex IC's
  • R_J
    • Jun 2012
    • 9535
    Re: Behavior of Faulty IC's
    Short answer is, yes that can happen
      • 30978
      yes, a bad input or output on a digital i.c. is common
      • Heihachi_73
        • Jun 2012
        • 713
        I used to have an Atari 2600 with a faulty chip (6532 aka "RIOT"), it would still try to run but the games would either not work at all, or only partially work and be glitchy and unplayable. I ended up eBaying it PCB-only for $10 since I couldn't find a spare chip at the time. Apparently it isn't uncommon for this chip to go bad either.
        Strangely my YouTube video of the faulty 2600 still exists long after I refused to become one with Google. The aspect ratio is wrong because I forgot to crop the image in VirtualDub.
        https://www.youtube.com/watch?v=fbTb15dLK-8
        When I swapped the chip with another one the console worked fine, but I needed the chip for the other 2600 which was in better physical condition.
          • 30978
          RIOT - Ram, I/O, Timers
          a lot to fail.
            master hoarder
            • May 2008
            • 12170
            I've seen it happen plenty of times. But a lot depends on if the fault was external or not. For example, on PC motherboards damaged by lightning strike, I've seen chips that are either intermittent or have lost some functions but still allow the board to post. Case in point:
            https://www.badcaps.net/forum/showpo...&postcount=346
            I've also had a dual-output voltage regulator (in a single package) fail with one reg output open, but the other still OK:
            https://www.badcaps.net/forum/showpo...88&postcount=2
            Not sure what caused it, but the working side is still working well to this day.r example,
            • dicky96
              Sun Seeker
              • Mar 2017
              • 1825
              • Spain
              GPU with artifacts etc would also be a good example
              Follow me on YouTube
              Learn Electronics Repair
                master hoarder
                • May 2008
                • 12170
                I don't know if that counts, because the actual chip "core" is still good. It's the GPU core separating from the GPU substrate PCB that is going bad.
                • sigmeyer
                  • Feb 2020
                  • 147
                  • Serbia
                  Ye, thats what i was thinkinh... i Had this one chip on ps3 which would let the ps3 boot something was getting shorted and it made the fan spin at full speed ... After the replacement evrything was okay... Which made me think..Thanks for all the replies
                  • sigmeyer
                    • Feb 2020
                    • 147
                    • Serbia
                    I actually have one more question thats simillar to this... Can capacitors fail with a resistance? like 50 ohms or something like that... Cuz i have a short to ground on this one board with 24ohms all over the place... what could it be?
                    • sigmeyer
                      • Feb 2020
                      • 147
                      • Serbia
                      Since i know that resistors fail high, so hence why i think its a bad cap...
                      • dicky96
                        Sun Seeker
                        • Mar 2017
                        • 1825
                        • Spain
                        Yes definitely. I have seen SMD capacitors fail with a DC resistance in the 100-200ohm range
                        When that happens in the case I clearly remember (on a microcontroller reset pin) the device - LED disco lighting box - would not boot up
                        However I have also seen many a supposed fault of 20 ohms or whatever all over a voltage rail that was not a fault at all. What is the voltage supposed to be on the rail that you think has a 24 ohm short?
                          • 30978
                          usually - but not always
                            master hoarder
                            • May 2008
                            • 12170
                            Yes.
                            Ceramic caps (especially SMD MLCC) are the most likely to fail short-circuit or low resistance. Electrolytic caps can too - but typically that will make them overheat and bulge very quickly (happens more on old caps with deteriorated oxide layer.) Film caps are the least likely to short-circuit or fail low resistance, but it is possible.
                            That said, it is worth analyzing the device you are troubleshooting before concluding that it has bad (shorted) capacitors. For example, the GPU V_core and RAM Vdd rails on a video card (that is turned off and disconnected from power) can be quite low in resistance due to the GPU chip itself. In cases like that, you may erroneously conclude that you have shorted ceramic caps somewhere on the video cards when that is not true.
                            • sigmeyer
                              • Feb 2020
                              • 147
                              • Serbia
                              Im repairing a motherboard right now The FX 760GM-p21 , I have found a faulty MOSFET with markings P0903BD , ITs the mosfet next to the CPU slot, so I removed it and sure enough its shorted all the way with 0 ohms across all... I have replaced it with AOD408 Which i hope one of you could clarify for me if that is a viable option... Now about the short i was talking about... SO there is a powersupply next to the northbridge , and that powersupply is shorted together , i mean when i go across the caps they are shorted together for like 15 ohms.. Now , i do not intend of messing with that area for now as i believe that i have found the main problem which was that mosfet... But should the northbridge psu be shorted with 15 ohms when turned off?
                              Anyway hope i get some feedback on that mosfet replacement thanks all
                              Last edited by sigmeyer; 02-27-2020, 01:18 PM. Reason: i typed in the wrong datasheet code
                              • sigmeyer
                                • Feb 2020
                                • 147
                                • Serbia
                                Also i found only 1 cap close to the NB that is shorted for 0 Ohms , and that cap is on the chip itself (next to the IC DYE) wonder if i should turn it on as it is to just see if it gives any sign of life?
                                • dicky96
                                  Sun Seeker
                                  • Mar 2017
                                  • 1825
                                  • Spain
                                  Now that is interesting as I also have a north bridge with a 0 ohm short across one of the capacitors on the die and I am also trying to find out if that is actually faulty. Mine is a completely different chipset to yours though, it's Intel X58.
                                  This thread
                                  https://www.badcaps.net/forum/showthread.php?t=82819
                                  • sigmeyer
                                    • Feb 2020
                                    • 147
                                    • Serbia
                                    Honestly if you found one cap on the dye shorted aswell then that gives me hope to think that that is normal.. I think you might have problem elsewhere.
                                    • sigmeyer
                                      • Feb 2020
                                      • 147
                                      • Serbia
                                      OK so i turned on the motherboard and it exploded ....
                                      JK its working fine, seems to like the new mosfet i put in there...
                                      I installed new windows 10 and it booted with no problem ... I will upload some pictures tomorrow just so you guys know im a real person repairing real problems, incase someone would think im not hehe
                                      • sigmeyer
                                        • Feb 2020
                                        • 147
                                        • Serbia
                                        Here is the motherboard set up that i had going on... Luckly everything was working fine and the motherboard is good, i just have the part of plastic that holds the cooler in place broken off so i thought of fixing a manifactured part of plastic (made bby me ) stuck on there with hot glue ? has anyone ever done this?
                                        anyway heres the board and the first Windows boot
                                        https://www.badcaps.net/forum/attach...1&d=1587349307
                                        • lolich112
                                          GTX 1660 Ti: Missing GPU Details & Abnormal Behavior - Possible Faulty IC?
                                          by lolich112
                                          I've been encountering some perplexing issues with my ASUS ROG STRIX GTX 1660 Ti Gaming OC and am seeking insights or potential solutions from the community.
                                          Symptoms:
                                          Initially experienced a gradient-style black screen from the top.
                                          Poor performance: ~10 FPS on the lock screen.
                                          Encountered artifacts followed by black screens.
                                          After addressing a PSU-related problem, still observed a performance drop (~10 FPS).
                                          Upon using GPU-Z:
                                          Memory size shows as 0MB.
                                          Unknown bus width and bandwidth reported....
                                          10-27-2023, 06:17 AM
                                        • Spudgun
                                          Why doesn't current just bypass faulty capacitors.
                                          by Spudgun
                                          Hello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
                                          04-01-2025, 10:33 AM
                                        • b-slayer
                                          Acer A317-53 need help to disable faulty onboard ram
                                          by b-slayer
                                          Hello.
                                          I have an Acer Aspire A317-53 laptop with faulty onboard ram modules, after online searches, I have only found two options to get it working :
                                          - first one is to modify le bios to disable the onboard ram.
                                          - second one is to disable the onboard ram by desoldering some components on the mainboard.
                                          so after some hours google-ing, i have to give-up the modified bios option, main reason is I couldn't find anywhere a such modified Bios, alternate reason is that if windows update makes a bios update, the problem is always here...
                                          so i found that my motherboard...
                                          10-12-2024, 03:46 AM
                                        • brispuss
                                          Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
                                          by brispuss
                                          Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
                                          Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
                                          I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
                                          12-28-2022, 02:58 AM
                                        • harp
                                          please help with complex dmm connector
                                          by harp
                                          Maybe now he decide to post... This forum is become so unreliable... I hope you see the attachment... So, I have newer cheap 830 dmm, and I am not happy with beeping mode. Its output is from IC directly, so he wont beep unless the diggit become too low. I want to beep function is thrully analog, like the old one, and think to atempt modification with insert beeping circuit. But, I dont know principle of reading such complex connector, so please if you can draving with red lines path that exist in beep mode... it will help me a lot....
                                          06-15-2025, 07:04 AM
