Has anyone had good results from lithium rechargeable battery with 1.5 volts
    • Jul 2011
    • 6065
    I am looking for lithium ion rechargeable battery that have 1.5 volt output that have had good results
    I see that there are quite a few China made batteries out there ( with different names ) that have this requirement but the claims are not always correct
    I have used this brand before Kentli and the results are so-so but the batteries are not cheap
    You might get 500 cycles out of them before the run time drops off considerably which they claim 1500 to 2000 cycles
    Or the batteries become ( heater cells when are being charged )
    I do not think that what you are paying for and what the results you get and how long they last are worth the money
    However I did like one thing about these batteries and that is the battery voltage stays constant until the battery dies you just do not know when it going to die
    • 31199
    Re: Has anyone had good results from lithium rechargeable battery with 1.5 volts
    i dont think rechargeable lithium can supply that voltage, even the AA size cells are 3.6v
    the only 1.5v cells i'v seen are the non-rechargeable type.
      • Jul 2011
      • 6065
      They have a buck converter built in them I have taken them apart before
        This guy did the tear down: https://www.youtube.com/watch?v=L62tCyOP06w
          • 31199
          i get the feeling a Li-Po in a sealed steel can = grenade!!!!
          • carrzkiss
            Cyberpower cps1500avr not charging batteries
            by carrzkiss
            Hello, all.
            Cyberpower Battery Backup Unit.
            I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
            When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
            In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
            Checking the voltage, it was down to 22v.
            I quickly removed everything...
            06-15-2024, 02:10 PM
            MPPT 60AMP Solar Charge Controller 12V 24V 36V 48V DC Battery Regulator Testing results on 12 volts
            by sam_sam_sam
            I bought one recently but this is the first weekend that I did not have work Saturday morning or the sun did not want to cooperate with me but today it is coordinating with me and I run a very simple test on a 12 volt battery pack and it stop charging ar 14.4 volts
            Here is the website link where I bought it from
            https://www.ebay.com/itm/395434828814
            I ran this test with a new 12 volt solar panel that has a no load voltage of 19.0 and an output current of 9.1 amps
            I do not remember the starting voltage but the charging amps was 1.4 amps
            09-14-2025, 11:49 AM
          • Mcfeetroy
            Fishing bite alarm drains battery
            by Mcfeetroy
            Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
            08-01-2025, 03:52 AM
          • howardc64
            Where do repair shops buy MB replacement batteries?
            by howardc64
            Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
            Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
            BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
            07-25-2024, 10:42 AM
            Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
            by sam_sam_sam
            I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
            I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
            12-31-2023, 06:04 AM
