Has anyone had good results from lithium rechargeable battery with 1.5 volts
    • Jul 2011
    • 6039
    I am looking for lithium ion rechargeable battery that have 1.5 volt output that have had good results
    I see that there are quite a few China made batteries out there ( with different names ) that have this requirement but the claims are not always correct
    I have used this brand before Kentli and the results are so-so but the batteries are not cheap
    You might get 500 cycles out of them before the run time drops off considerably which they claim 1500 to 2000 cycles
    Or the batteries become ( heater cells when are being charged )
    I do not think that what you are paying for and what the results you get and how long they last are worth the money
    However I did like one thing about these batteries and that is the battery voltage stays constant until the battery dies you just do not know when it going to die
    • 31009
    Re: Has anyone had good results from lithium rechargeable battery with 1.5 volts
    i dont think rechargeable lithium can supply that voltage, even the AA size cells are 3.6v
    the only 1.5v cells i'v seen are the non-rechargeable type.
      • Jul 2011
      • 6039
      They have a buck converter built in them I have taken them apart before
        This guy did the tear down: https://www.youtube.com/watch?v=L62tCyOP06w
          • 31009
          i get the feeling a Li-Po in a sealed steel can = grenade!!!!
          • carrzkiss
            Cyberpower cps1500avr not charging batteries
            by carrzkiss
            Hello, all.
            Cyberpower Battery Backup Unit.
            I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
            When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
            In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
            Checking the voltage, it was down to 22v.
            I quickly removed everything...
            06-15-2024, 02:10 PM
          • howardc64
            Where do repair shops buy MB replacement batteries?
            by howardc64
            Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
            Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
            BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
            07-25-2024, 10:42 AM
            12-31-2023, 06:04 AM
            Bosten Power Sonata 5300 Rechargeable Batteries Review
            Here are some battery test results
            The first battery the settings were not set right the fifth picture is the correct results
            I bought these batteries from a seller on EBay ( two sets of them ) this is only $2.80 each
            !!! Disclaimer Notice !!!
            I have the seller permission to post his listing for these batteries
            I am not promoting his web store
            Only these batteries to me they are a good buy for what the amp hours these batteries still have left in capacity ( “5300 mill amp hour capacity so there is still about 90 %...
            11-24-2020, 06:14 PM
          • Astonished
            Fixing the Charge Circuit of the Batteries of the DC Motor
            by Astonished
            Hi friends of electronics
            What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
            The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
            Please help me fix this circuit.
            (the datasheet of the IC: https://pdf.datasheet.live/28...
            01-28-2025, 06:24 AM
