Charger circuit questions
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8706
    Re: Charger circuit questions
    DGW has a "5000mAh" 18650!
    • Retro-Hipster
      Tinkerer
      • Apr 2019
      • 125
      Wow, I was so wrong with what was on the circuit board... that was embarrassing. Ahahahaha There isn't even a second chip on the board! Just half-bridge rectification, some support components to clamp the supply voltage and then a purpose made chip. >.<;;;
      Based on the datasheet this is just not programmable at all sir. You would be much better off just getting a new thing.. :x And yes, DGW has many rediculous batteries. haha He also made videos about how ridiculous they are. The 5000mAh one weighed like 1/2 the weight of a 1200mAh battery. :'D
      “Men always seem to think about their
      past before they die, as though they were
      frantically searching for proof that they
      truly lived.”
      – Jet (Cowboy Bebop) -
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8706
        Still looking for takers on someone who thinks it can be adjusted by adding "a few" components and that lying to the chip is easy...
        It's tougher than I thought and I thought it was tough to begin with! What made me change my mind and increase complexity more?
        Dealing with automatic polarity!
        Remember to deal with this too! (though forcing the user to ensure the battery is inserted in only one polarity direction would simplify the circuitry a bit...)
          • Jul 2011
          • 6070
          Has anyone bought and tested this battery to see if their claims are true or not
          Does anyone really believe that crap I do not
          You be lucky to find brand name batteries that are 3200 milliamperes
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8706
            Well people have bought them, and people tested them (and found they are not real).
            Just strange that DGW was still using it, perhaps just because it's expendable...
            Then again even if expendable, if it immolates, it still immolates!!!
            • Retro-Hipster
              Tinkerer
              • Apr 2019
              • 125
              AH, actually, DGW purched a lot of different obviously fake batteries like that one and did a full load test and such. Many of them came out closer to 500mAh than 5000. He definitely knows that they are crap.. I think he just likes things that are dangerous. :'D Dude made a damn x-ray machine in a yellow parts bin... you know he has to be crazy.
              You should check out his videos on the subject Sam. It's both entertaining and insightful.
              truly lived.”
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8706
                I really should figure out a way to test the li-ion cells that I have for capacity and use that info to balance...
                  • Jul 2011
                  • 6070
                  I also need to come up with a plan to do the same thing
                  But my problem is finding time to devote to this type of project where I do not have distractions from work and elsewhere maybe after the first of the year It might slow down some
                  • Curious.George
                    • Nov 2011
                    • 2305
                    • Unknown
                    #29
                    ROTFLMFAO! There's a point (in life) when you realize there simply aren't enough hours to do ALL the things you WANT to do. Then, you decide what you can afford to "hire out" (or, "buy new") in order to free up some hours to do the things that you REALLY want to do! E.g., do I REALLY want to fix this little scooter and then try to find a home for it? Or, would I rather just SCRAP it and spend that time working on something else?
                    (Hint: if you've got a backlog of "stuff to do", it's only going to get LONGER!)
                    <frown>
                    • Retro-Hipster
                      Tinkerer
                      • Apr 2019
                      • 125
                      <frown>
                      I could send you guys a simple Arduino load tester/schematic/spreadsheet I made a while back for testing batteries. Basically, it's basically just two voltage dividers and a current sense resistor. One divider reads the voltage before the current sense resistor to get the voltage of the power source (battery) and the other measures the voltage drop over the current sense resistor. There is a terminal for the battery input and then another terminal for output. The output can really be any resistive load, like an appropriately rated resistor.
                      The programming on the Arduino is super simple and just does the ohms law calculations and outputs the data in a csv file format in the terminal output.. (Also includes elapsed seconds) I use putty to connect and then tell putty to log the data. From there you can just import it into the spreadsheet program of your choice and graph it/do your calculations. (I could also send the spreadsheet.)
                      Actually, how about I make an article with all of this and send you both that. (I have a website I made for this sort of thing, but have basically not updated it at all since I made it. ahahah)
                      truly lived.”
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8706
                        designing the circuit is easy, actually getting hardware that actually does it, however, requires some physical effort...
                        • Curious.George
                          • Nov 2011
                          • 2305
                          • Unknown
                          #32
                          My system for testing "batteries" is pretty simple:
                          - place in charger
                          - if charger indicates FAULT, "discard"
                          - else wait for charge cycle to complete
                          - use "charged" battery; if performance is less than desired, "discard"
                          - when supply of rechargeable batteries is exhausted, buy more.
                          I use this strategy for my NiMH, Li and SLA battery supplies. Note that the latter can get very expensive (e.g., 35AHr case sizes and larger); it's still not worth the time (for me) to tinker with them!
                          • Retro-Hipster
                            Tinkerer
                            • Apr 2019
                            • 125
                            - place in charger
                            Oh, I totally made this because I'm the type that like.. buys batteries in bulk for a lot of things and liked testing stuff. I wanted to see how good the top 5 AA's were on amazon before I purchased the larger quantities... That, and this little thing is pretty handy for other things, like monitoring how much power a circuit uses over a long time period. (I used it to test a motion-activated cellular device over a month to see about how much power was consumed.)
                            truly lived.”
                            • Curious.George
                              • Nov 2011
                              • 2305
                              • Unknown
                              #34
                              If you learn something from the effort, great! E.g., you could note how the performance of the cells varies with load current (C, C/5, C/10, shelf-life). Or, how charge times varies based on charging current and/or strategy (there's boatloads of BFM in battery chemistries!)
                              [There have been a bunch of novel chargers designed over the years that used various "tricks" to speed up charging -- like "burping" the cells -- or minimize the aging the cells experience from the charging (and subsequent discharging).]
                              When I was younger, I designed car ignition systems, electronic thermostats, home alarm systems, MPPT controllers, etc. -- all "one-offs" (i.e., hobbyist, outside of my $WORK cuz they had their own ideas as to where my design efforts should be spent). If I wanted to learn something, I had to invent my own projects from which to learn.
                              But, the nature of the "challenges" increases as you get more experience (age). And, the time required to tackle those challenges increases dramatically -- weekend projects get replaced by projects that take months and even years to implement. (10 years -- full time -- for current project!)
                              [At the same time, you usually have other responsibilities that weren't on your ToDo list when younger (home maintenance, family, health) so the amount of time that you have available shrinks]
                              So, you learn to cut out the "small stuff" that you COULD do (if you had all the time in the world!) and spend money to buy those "solutions" so you have time to work on the "bigger (and more interesting) things".
                              E.g., I'll do an oil change cuz I can do it in the time it would take me to drive the car "someplace" and wait for "someone" to do it for me. Ditto replacing a starter. But, bodywork? Out of the question! Recap a generic motherboard? Nope; just rescue another machine that's already running!
                              Similarly, I'll design an operating system ONLY if I can't find something currently available that has the features that I need -- cuz the time spent designing and writing it could have been spent working on the actual application!
                              • rddube
                                Lenovo L490 Ram voltage circuit malfunction
                                by rddube
                                Hello friends,
                                Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                                I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                                07-15-2025, 04:41 PM
                              • Instafixx
                                Macbook A2179 820-01958
                                by Instafixx
                                Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
                                The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
                                I checked the Power Sequences below and found this -
                                Once a valid external power source (Charger or battery) is connected, the following rails will come online.
                                PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
                                PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
                                05-20-2023, 05:19 AM
                              • piernov
                                Laptop battery charging circuit
                                by piernov
                                1. Some theory
                                1.1. Introduction
                                Almost every laptop has a charging circuit of some sort, that does a few things:
                                • Manages switching between AC adapter and battery power
                                • Manages battery charging and generates power rail to charge battery
                                There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
                                • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
                                • Narrow VDC (NVDC)
                                Texas instrument has a nice overview of these technologies with some more details at https:...
                                11-15-2020, 01:31 PM
                              • HERETIK10
                                Adaptable charger voltage for Clevo D901C laptop
                                by HERETIK10
                                Thanks in advance to anyone who takes the time to help me. Sorry for the quality of my English, I had to use a translator at times...
                                I bought a functional Clevo D901C (Sager NP 92261) with its battery but without its power supply.
                                So, I invested in a new LiteOn charger, advertised by an online seller as the right charger for my machine... BUT, according to the pinout (4pin + shell) of the charger, 1 and 2 are 20V / and 3 and 4 are grounded. When I measure pin 4 with the ground of the PC, I have 300kOhms, which seems to be confirmed by the electrical...
                                11-08-2023, 04:24 PM
                                ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                Narrow VDC applications where the system power source is
                                either the battery pack or the regulated output of the charger.
                                This makes the max voltage to the system equal to the max
                                battery voltage instead of the max adapter voltage. Operating
                                at lower system voltage can improve...
                                11-05-2024, 04:43 PM
