120vdc motor question
  • manstoblame
    • Jan 2011
    • 85
    Hey fellow members here i am back again with a dumb question but I lack the the understanding that you here in the BCF have. I need a motor for a pedal assist on my bicycle that I can remove when parked to prevent theft, it has to be small but powerful, so i thought to use a inflatable beds motor but it happens to run on 120 volts dc. Question i'm faced with is if it can be powered off lower voltages and have same rpm? Just asking for a little help
  • redwire
    • 3912
    Re: 120vdc motor question
    It looks like a brushed DC motor, which will have proportionately lower speed and torque if given lower voltage.
    You can look for the motor's datasheet. HV3657-110-GF I could not find data. The motor's speed-torque curve line moves down with less voltage. So half rated voltage, say 60V roughly half the speed and torque. The motor cannot take a lot more current to make up for it, the winding and brushes heat up too much.
    I would not use it for an e-bike because speed control is best done with PWM on a brushless motor, you get much greater efficiency and better low speed torque. This is why they are king for drones, e-bikes, electric cars, RC toys etc.
    Or rewind the motor to better match your battery pack voltage. 120VDC is a bit much to unplug in the rain, any thief would zapped.
    • manstoblame
      • Jan 2011
      • 85
      Thanks Redwire for your quick response and thorough explanation. looking for a better motor will be my mission and if you have a suggestion its appreciated in advance. Thanks again
        • 31289
        look at the ones on ali-express
        if you have the money - look at the Bafang - it fits in front of the pedals and links there.
        • manstoblame
          • Jan 2011
          • 85
          Thanx STJ will do
          • manstoblame
            • Jan 2011
            • 85
            Not bad but trying a diy plus I live in an area I would like to be able to plug and play if you know what I mean but again thanks those may help with a concept maybe
            • juergenb
              Nescafe Aeroccino, still fails with new Motor (red flashes only once)
              by juergenb
              i am asking for some Help.
              I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
              The Motor didn´t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
              So i got a few of these from Banggood.
              I swapped the motor and now i have a new fault condition.
              In a working Frother you would press the start button, it will light red and work for a few minutes.
              If you press longer it will light blue and just mixup the milk.
              With the new Motor it just starts...
              03-23-2021, 11:24 AM
            • sbt123
              charnwood w821 mini wood lathe motor problem
              by sbt123
              hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
              10-27-2024, 03:43 AM
            • d00m178
              Philips toothbrush 4100 (HX369BK) - motor getting hot
              by d00m178
              trying to fix Philips toothbrush 4100 (HX369BK)
              The battery started draining quickly.
              After disassembling it, I discovered that the motor gets very hot when brush is off, which is apparently causing the battery to lose charge.
              The motor is connected to contacts M1 and M2.
              When I turn on the brush, 0.4V appears on these contacts, and the motor starts running as expected.
              But when I turn off the brush, the voltage changes to 3.8V—exactly the same as the battery.
              The motor gets so hot you can't touch it. And after 5 minutes, the battery drains to 0V.
              (To...
              11-12-2025, 03:11 PM
            • mikey5791
              Help identify this motor
              by mikey5791
              Hi all forum members,
              Found this unknown motor discarded in a junk yard and took home for learning experience. By the look of it, I suspect it is taken out from a type of air blower probably running on ac power. I used digital multimeter on ohm/resistance scale and it doesn't read anything on those 2 black wires. So, this motor is not shorted and should be good to run.
              Correct me if i am wrong on the initial test.
              Can anyone kindly advice on how to test run this motor based on visible external two black wires. Fyi, i don't see any marking on the motor body nor smell anything...
              11-24-2023, 07:54 PM
            • Per Hansson
              Motor run capacitor physical size vs voltage rating & measurements?
              by Per Hansson
              (TL;DR skip the first paragraph)
              I encountered my first dead motor run capacitor at a customer this week.
              For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
              (Unless a servo motor makes more sense that is).
              But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
              The pump would run but sometimes trip the 10A breaker.
              I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
              Then it could...
              09-20-2020, 06:32 AM
