Re: Help idinifying circuit from Battery Charger
Tks Redwire but I only have two of these vs-70hr's kicking around so I guess that's out? I just recently converted an old PC power supply that I had kicking around to a bench top power supply but I do have a couple of power supplies from a TV receiver not sure what I could get out of that? These board delivers a bunch of voltages but since I am not a tech person I am not sure of the value of what I have in my junk box?? I derive a lot of satisfaction from taking scrap and turning it into something useful but most of my knowledge come from the great people on forums like this. I am a knowledge seeker.
Yeah probably best not to use a bridge and use discrete diodes - the original design spread the diodes out away from each other for a reason.
and holy crap, seeing some china shops selling the button diodes for less than 10 cents a pop in 1000 quantities... wonder how bad they are?Leave a comment:
Any diodes used need heat sinking for cooling. This is the hassle.
With a 15A load, each diode will dissipate about 7W of heat, roughly.
If you use a bridge rectifier module, then all the heat is concentrated in one square for 28W.
The VS-70HF is a large 70A 800V stud-mount diode, you would need four.
But the hassle is mounting them on the heatsink, the cathode is the bolt so two of the four diodes need insulators or the special version with reverse-polarity (anode to case). Insulators can't transfer the heat, so the diode cooks or the plastic melts and they aren't a great way to go.
Simplest fix I think is bolt a 25-50A bridge module on the heatsink, the modules are isolated case so no more hassles with shorts to the metal.
Rectifiers from a scrapped PC power supply could work. They are two Schottky's in a TO-220 case and a bit more voltage for the battery. What else you got in the junk box.Leave a comment:
It looks like the charger manufacturer tried to copy a car alternator's construction with press-fit diodes. But the plastic washers are terrible for heat conduction and aluminum rivets on copper likes to corrode and the skinny wires have to go. Yuck.
I would change over to a bridge rectifier module like KBPC5010 50A 1000V $3.00
But the big problem really is heat sinking the diodes. Even if you put in huge expensive stud-mount diodes, that small plate just can't get rid of heat very well. I would beef up the heatsink.
How many amps is this charger rated? Does it have a fan?Leave a comment:
How many amps is this charger rated? Does it have a fan?Last edited by redwire; 08-31-2019, 01:29 PM.Leave a comment:
People sometimes replace them with 50 amp/400v D0-5 style stud mount diodesLeave a comment:
No numbers visible on either of the 4?Leave a comment:
I don't believe they should be split like that, what is the number on them? it should be marked on the side. I t could be the diodes have a high forward resistance so they could show open with a meter.Last edited by R_J; 08-31-2019, 11:55 AM.Leave a comment:
Each diode can be tested with a multimeter and diode test. What seems to be shorted? the diodes?
It looks like all four diodes have a common point, the aluminum plate, so they could have 2 diodes in parallelLast edited by R_J; 08-31-2019, 11:23 AM.Leave a comment:
Tks again R_J yes there are?? first time a have seen a diode looking like that?? The circuit seem to be shorted is there a way to test these diodes?Leave a comment:
The photo is of a circuit in an older car Battery Charger. I was wondering if someone on here could identify this circuit and explain it's function and how it works. It seems to be a very simple circuit to convert AC power to DC power. The two leads from the Transformer connects to the two terminalsTags: None
NVDC charger configuration...-
Channel: Common Parts Library - Datasheets
11-05-2024, 03:28 PM -
ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
Highly Integrated Narrow VDC Battery Charger for Notebook Computers
The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
Narrow VDC applications where the system power source is
either the battery pack or the regulated output of the charger.
This makes the max voltage to the system equal to the max
battery voltage instead of the max adapter voltage. Operating
at lower system voltage can improve...-
11-05-2024, 04:43 PM -
by sam_sam_samThe Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...05-06-2023, 12:17 PM -
by sam_sam_samI have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
So I have put them on the battery testing machine to drain each battery cell down to... -
The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
The bq24745 features dynamic power management...-
10-23-2024, 02:50 AM -
- Loading...
