TO-220 exploded...estimated overload?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: TO-220 exploded...estimated overload?
    Probably burned rosin, though I'm not sure what the grayed stuff on the metal tab is. The good BYQ28E is much more shiny.
    Right now my power supply is not supplying enough watts to see how well the F5KF20 is doing under load, though so far the diode is supplying 100mA or so at 120V okay...
    • redwire
      • 3907
      You might be over-torturing things using light bulbs as load? Their resistance is non-linear and much lower when cold.
      A 100W 120VAC bulb is 144 ohms lit but at 1/2 voltage drops to 124 ohms, and 1/4 voltage is 90 ohms.
      I found sometimes an SMPS can't "get it up" and stays stuck outputting low voltage and high heat. Would have to graph power vs voltage.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Well, with lower voltage, even with lower ohmmage the amount of current is lower.
        100W (RMS)
        120V 144Ω = 100W = 0.83A
        60V 124Ω = 29W = 0.48A
        30V 90Ω = 10W = 0.33A
        So the current is still going down as voltage goes down, and diode loss is (V=0.7)*I (though V goes up slightly as I goes up...) which is mostly linear.
        The thing I was hoping for is that I would expect the above to be "average" current. Peak current flow is what I'm not totally accounting for, and this would be much higher than 0.83A. Then again most diodes have higher peak current limits.
        Anyway I was hoping to get 300W from this supply for proof of concept. That would be less than 3A average, so these diodes should be able to handle it -- as long as they stay cool.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          So far so good, the F5FK20 has survived many hours of powering the 100W bulb.
          The switching transistors do not like it over 150W draw however. MOSFET driving is a PITA...
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            One thing that really sucks about shoulder washers... if they melt, it will end up protecting the heatsink...
              • 31009
              try using a fiber washer on the plastic one, it will stop the screw touching the tab if the plastic melts
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                well that's not exactly the problem, when the plastic melts, the whole thing goes loose, and the transistor/diode goes into runaway as the heatsink is no longer making contact... I guess those springs have an added advantage.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  BTW, how do people feel about those plastic covered TO-220s, they clearly have higher thermal resistance, but have people been swapping them with regular TO-220s with insulation readily and still generally satisfying thermal requirements?
                    • 31009
                    some of those have very low thermal resistance, i'v done it a couple of times simply because of parts availability.
                    that said, i wasnt cooking the old parts either.
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      Yeah, that's exactly why I'm using it now, parts availability
                      When you say you weren't cooking the old part, are you sure?
                      I guess if the old part failed from ESD or something like that, then it wasn't being cooked. But perhaps the reason why it did fail is because it cooked itself inside the plastic? Heh...
                      (Anyone have any photos of dead fried plastic covered TO-220F(?)s? Seems that the thermal resistance is quite a bit different. Suspecting that one shouldn't be running TO-220F's anywhere near the limits of the device...)
                        • 31009
                        when your repairing industrial boards that arent cased, getting ones with parts broken off by clumsy idiots is not uncommon!
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          Ahh yes, forgot about mechanical damage, that indeed is a failure mechanism Actually the thermal resistance of unheatsinked TO-220 and TO-220F's are about the same, so if no heatsink, not much difference. It seems that both are around 62°C/W.
                          Difference starts when there's a heatsink attached or at least the "infinite heatsink" case (which of course doesn't exist). I'm reading anywhere from 0.7-2.5°C/W for TO-220 and 3.5-6°C/W for TO-220F.
                          • redwire
                            • 3907
                            TO-220F has quite poor heat transfer to a heatink, around half that of the TO-220.
                            I was going to build an audio power amp using them but they can't get rid of heat:
                            FJPF5200 (TO-220F) 2.5°C/W
                            FJP5200 (TO-220) 1.25°C/W
                            2SC5200 (TO-264) 0.83°C/W
                            What frequency are you running, perhaps your heating is aggravated by switching losses? The transformer secondary ringing can cause rectifiers diodes to switch on/off many times and see high peak currents in reverse recovery.
                            It might be worthwhile to lower it and see what happens.
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              So you actually tried subbing a TO-220F into a TO-220 solution and had it fail? Or is it just theoretical based on the numbers?
                              The switcher should be running around 40KHz, and as far as I can see, the "new" diode is working fine now.
                              My initial design the switching MOSFET and the diode were on the same heatsink, and both went really hot. The MOSFET died, and I suspect the diode was given a fatal blow though barely holding on - at least the diode tester says it was still OK.
                              Then when I moved it to its own heatsink, it got hot because it was barely holding on...and then killed itself.
                              The new TO-220F diode seems to be staying fairly cool, though it does have a slightly better heatsink now. Without air blowing on the heatsink, I can't really feel it getting warm at all really, though the added thermal resistance may have some impact. But on the other hand, no thermal pad, and no shoulder washer, so I could torque it down a bit more...
                              • redwire
                                • 3907
                                yes TO-220 fullpacks ran really hot, I tried them(MOSFETs) in mains SMPS instead of all the insulator/hardware to keep it simple. Thermal imaging cam showed over double the operating temp.
                                MOSFET's have thicker insulating plastic to meet safety standards for high voltage. One Vishay part was 3.8°C/W so at 10W almost 65°C.
                                40kHz seems fine, if the mosfet has good gate drive and snubber + deadtime, that is most of the battle.
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  The switching diode has a different challenge...
                                    Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
                                    The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
                                    Securing a good thermal interface between...
                                    10-07-2024, 04:35 AM
                                  • magneh
                                    Behringer Eurolive B205D repair - help identifying transistor
                                    by magneh
                                    Hello
                                    Got this speaker from a friend , defective. Power led comes on and off , in a loop.
                                    Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
                                    After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
                                    I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
                                    Still, I need to replace this transistor....
                                    06-18-2025, 02:34 AM
                                  • elsomer
                                    help to identify transistor msi ms-15ck1
                                    by elsomer
                                    hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
                                    02-17-2025, 05:30 PM
                                  • rddube
                                    Help with blowing transistor NAD T752 receiver
                                    by rddube
                                    I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
                                    Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
                                    I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
                                    09-01-2022, 05:19 AM
                                  • amigo744
                                    xbox series x u82 5 pin transistor voltages ?
                                    by amigo744
                                    hello there,
                                    xbox series x hdmi u82 transistor 5 pin,
                                    can anybody tell me voltages of this transistor in standby and power on mode ???
                                    on which pin of this transistor are the voltages ?
                                    regards
                                    08-16-2023, 08:05 AM
