How to read znr or mov?
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    I got a nissan instrument cluster with obvious blown znr
    I'm not familiar with them since I never replace them. This is a first for me.
    How does one read details on the znr/mov for replacement?
  • delaware74b
    • Apr 2009
    • 628
    Re: How to read znr or mov?
    I'm not sure on how to ID the zener diode, but you may want to check D1, D2, D3. All 3 look like they're damaged (split, burn/splatter on the board).
    What's the history on this cluster? I'd suspect damage with power on the comm/data lines from the ECU or another component shorted on this board.
    Stupidity should be a crime, especially for drivers. I have NO patience for them.
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      Well ZD is zener on the board, ZNR1 is the MOV? I think, that's what is blown.
      TR1 is the transistor d2139.
      2000 sentra, all stock, no mods.
      Long story short, he did errands all day, last stop at the grocery store, got in and started, battery light and airbag light came on, car drove home fine, he messed with it, disconnected the battery while engine was running to see if alternator was working, engine kept running.
      He didn't think it was the alternator. He check fuses found "battery electronic" fuse in dash box blown, replaced it, blows immediately. Calls me for advice, told him usual suspect is alternator, check the charge voltage, then mentions fuse then told him he got a short somewhere. A week goes by, he calls again, ask me to come out and take a look and tells me alternator was putting out 17V on his DMM and he replaced it and voltage is now battery voltage of 12.6V, doesn't seem to be charging. It still blowing that one fuse. I look up the fuse number and wiring schmatic, see it's key switch, security ind. light, comb. meter, TCM, data link.
      Check the fuse terminals, found 12v on one, no voltage on other, disconnect battery ohm out terminals, 12v supply, open, other terminal .4 ohms to ground. obvious short. Disconnect ignition switch, no change. Pulled cluster, short goes open.
      Pulled apart cluster what you see above is how I found it.
      I will check the diodes and report back.
      EDIT:
      Going to have to remove ZNR1, can't do it tonight, I have to go to work.
      D1-3 and D112 shows shorted in both directions.
      D116 and D117 shows anode as open, cathode .532 ohms. The printing on diode seem to be similar to D1-3 and 112
        Is the Diameter of that MOV 10mm?
        If it is then it will be 10D220K = Max continuous 14V AC RMS/18V DC 10mm Dia.
        https://www.mouser.com/ProductDetail...ugxn83Og%3D%3D
        • delaware74b
          • Apr 2009
          • 628
          D1-3 probably failed due to the battery being disconnected while the engine was running, causing the over-voltage condition.
          The fuse blowing for TCM, combination meter (that's the instrument cluster) etc is probably from the shorted diodes and MOV.
          • Mad_Professor
            A Mech Warrior
            • Feb 2011
            • 1587
            Sorry for the absence, got a lot going on with work.
            Measures 11.35mm across, how were you able to extrapolate that from the values on the blown one?
            It's possible, We got another cluster to test with but no dash lights or working meters on that cluster, old one had working meters at least and partial dash lights. It's weird because the car date of mfg is 06/00 (month/year) and the cluster used incandescent lamps for the warning icons and the meters are screwed to the pcb. It's different on the test cluster, the warning icons use LEDs and used solid pins solder to the board that are pressed into the back of the meters and held the pcb with plastic clips, no screws, this was from 08/00 car. I went ahead returned that cluster and got another one from 03/00 car, this one used incandescent and screws as well and is identical to the old one, but haven't had a chance to run over to his place to test it.
            If I get time this week I will remove the blown MOV and test the diodes again.
              Most MOV manufacturers use the xxx (K) format for the Voltage rating. The S10 (or xxD, or Dxx) is typical format for the Diameter of the device). Since it is being used in the car, the spec makes sense.
              Another example: https://cdn.badcaps-static.com/pdfs/...23c6387882.pdf
              • Babbar
                by Babbar
                04-12-2024, 01:12 AM
              • drscoot
                HP X360 convertible battery blown fuse error, not charging
                by drscoot
                HP Modelnumber: 14-dh0061nb​
                This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                All these 3 batteries are charging...
                12-15-2023, 05:54 AM
              • beetle1303
                Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                by beetle1303
                I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                01-13-2025, 08:49 PM
              • jesterace
                Samsung UE46ES8000 Blown fuse but no other signs of short
                by jesterace
                Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                09-11-2024, 03:14 PM
              • whc14765
                Gigabyte 980TI Windforce - Blown PCIE Fuse
                by whc14765
                Hey,
                I have a Gigabyte 980TI Windforce. No shorts on the main 8 pin PCIE power connectors. The 8 phase buck converter inductors are showing 2.5ohms.
                The card doesn't power up at all - no lights, no fans, nothing. I noticed that all of the 8 phase inductors are showing 0V. I couldn't find a fuse for the 8pin power connectors.
                I did notice that the PCIE x16 connector 12V line has a fuse F3 (10A marked on it) which is blown. It is reading 16ohms on one end.
                1st Question: Is there some logic on the board that checks the 12V on the PCIE x16 bus connector...
                04-08-2022, 06:22 PM
