Is this possible than turning on oven make a 1 second power outage in home? ( playing
  • sew333
    • Apr 2017
    • 81
    • Poland
    Hi.Have an question. It is possible that when turning on oven make a 0,5-1second power spike,without tripping fuse or breaker? I ask because when my mother in kitchen turned on oven,diablo 1 crashed to desktop on my old laptop. Nothing get tripped etc,lights not. So it was coincedence that game crashed in this moment or not?
    Laptop not restarted i just saw STEAM icon like always and desktop ,when i back.
    Event viewer said that:"A timeout was reached (30000 milliseconds) while waiting for the Steam Client"
    "the service did not respond to start or control request timeline fashion "
    Also i was on balcony in this time.
    ps:
    Diablo 1 is from GOG not steam.
    • 31286
    Re: Is this possible than turning on oven make a 1 second power outage in home? ( pla
    a poor connection between your fuses/breakers and the meter or incoming cable could cause a volt-drop.
    but so could a problem outside that is the power company's problem.
    • ChaosLegionnaire
      HC Overclocker
      • Jul 2012
      • 3266
      • Singapore
      what is the wattage of the oven? some ovens could require a lot of power and thus pull a lot of current suddenly, causing an ac brownout. it could also be due to a failing laptop power brick. try connecting the laptop power brick to a different mains outlet supplied by a different ac circuit not shared or used by the oven and see if the issue still persists and is reproduceable everytime the oven is switched on.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8710
        I was wondering about this. The laptop has a battery so unlikely was a brownout to the laptop or its power brick. The brownout could only be affecting the router or modem however, but even then they have switching supplies and usually can handle it. It's unlikely the current spike caused by turning on the heater could cause a spike that would confuse other electronics...
        Look into the network equipment that's not battery powered.
          • 31286
          nobody said it had a battery - none of my laptops do.
          that said, laptop glitch or router crash - i'm still thinking brownout.
          i'v seen it before with showers and even washing machines making flourescent lights re-strike.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8710
            That's also another thing about laptops, they usually have good UVP, and it should reset the machine if the power goes too low, and not cause corruption. So still don't think the computer is the problem.
            Not always the case with routers or networking equipment, especially cheap stuff.
            • sew333
              • Apr 2017
              • 81
              • Poland
              We tried 4 times turning oven when diablo 1 was running. Nothing happened. Also steam was running fine. But steam is only background. Diablo 1 is standalone not from Steam.
              In moment when Diablo 1 crashed to desktop event viewer said:"Event viewer said that:"A timeout was reached (30000 milliseconds) while waiting for the Steam Client"
              "the service did not respond to start or control request timeline fashion ""
              Diablo 1 is from GOG not steam.Diablo 1 is playing from standalone files.offline
              So it can be related to starting oven or it was coincedence?
              Like i said it crashed to desktop,laptop was not turned off. Laptop without battery and baterry is not charged.
                • 31286
                so steam *is* being secretly used by diablo, or steam is running 24/7 in the background - which you shouldnt allow or tolerate.
                • ChaosLegionnaire
                  HC Overclocker
                  • Jul 2012
                  • 3266
                  • Singapore
                  yea, i have this issue with the air-con condenser unit at my place. everytime the condenser fan kicks on, it causes a split second blink of the house lights tho its barely noticeable. looks like an ac brownout.
                  it also seems to cause some emi or rfi as it causes the dvi and hdmi video link of my monitor to reset causing the screen to blank out briefly. turning off the house light switches also causes the same issue with my monitor.
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    Looks like a Steam bug, Windows 7 SP1 on my socket 1366 system, has been reporting the same thing, IIRC.
                    Edit: As sure as dog shit out on the lawn somewhere not too far from here, Windows 7 SP1 had this error message in the event log waiting for me:
                    A timeout was reached (30000 milliseconds) while waiting for the Steam Client Service service to connect.
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                      ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                      This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                      09-12-2024, 03:28 PM
                      ALIENWARE Steam R2 i7-6700T Specification for Upgrade or Repair
                      This specification for the ALIENWARE Steam R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam R2 boardview and Steam R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ALIENWARE Steam...
                    • Fsufan1391
                      LG Oven model LREL6325F
                      by Fsufan1391
                      Hello everyone my oven is less than 2 years old and all of a sudden recently when i run the oven for 15 minutes or so and i am done with it and shut it off. after about 10 minutes it starts chiming and randomly putting it in different modes like the touch screen is being touched but no one is around it. I have tried to reset it by unplugging it multiple times and no luck. I took it apart to see the main board and everything looks fine. I am wondering if i should replace the main board or if its in the control panel. the touch screen is very responsive and works like it should. its only acting...
                      04-23-2025, 05:42 AM
                    • bpjl
                      SEF 551.10 - Error starting the reflow oven.
                      by bpjl
                      When starting the SEF 551.10 reflow oven, the following problem occurs:
                      It seems to me that this is related to corrupted software. Does anyone have files that can fix this device? Or maybe someone uses such an oven and is able to make a sector copy of the memory card located in the computer controlling this oven?
                      PS.: Of course, appropriate emails for help have been sent to the manufacturer and distributor in my country. No response yet, but I don't expect much. It's a fairly old device and from what I know, it's no longer...
                      10-17-2024, 06:30 AM
                    • JayPoorJay
                      Steam Generator - To Be or Not To Be - And 1000 Other Questions
                      by JayPoorJay
                      Good Morning All.
                      Now I've gone and done it! Wife and I bought a big old "new" 100yo colonial house and a guy can dream, right??? I'm building a sauna and a steam shower in the basement.
                      At this point, because of y'all, I've fixed a couple TVs, replaced a few capacitors and resistors, repaired some E ribbons, ALL with y'all's help and reading here. Next challenge,,,, I am still and perhaps will ALWAYS be at bottom of a steep learning curve with electronics... Anywho,,,
                      These things (Thermosol Steam Suite ASD450) NEW are in the thousands. That plus...
                      11-26-2024, 06:18 AM
