Help identify component
  • redwire
    • 3912
    Re: Help identify component
    2N2646 pinout seems to be an oddball metal can, non-standard TO-18 case. TO-18 (UJT) so the tab is at a weird angle compared to the typical transistor TO-18 configuration. Note they use bottom view for pinouts on datasheets.
    A 2N4871 or 2N4851 might also work. UJT's in a metal can are long obsolete.
    Tenatronics Ltd. 50-114, Motomaster 11-1519, Sears 12V 10A Automatic Battery Charger
    • Willybb
      • Nov 2019
      • 4
      Hi redwire
      Thanks for getting back to me. I thought I was loosing my mined as everything I looked up had a different tab position. I finely found the attached picture below which corresponds with the 2N2646 I have. Wanted to verify with someone else to make sure this pin layout was correct before I let the smoke out. I only have a couple of these to play with. I'll get it soldered in and see if this is the fix.
      Why is this component labeled Emitter/Base1/Base2 when most every other transistor is Emitter/Base/Collector?
      Thanks again for the help.
      Cheers
      Willy
      • redwire
        • 3912
        OK your datasheet pic is showing a transistor style TO-18 pinout I've seen many different pinouts for the 2N2646 on the Web.
        You can ID the emitter as (+) on multimeter diode-test and readings to both bases. Some TO-18 cans have the substrate (lead) emitter connected to the can, others have all three leads isolated. I'm not sure why the part labels are so weird, with no collector and two bases.
        The battery charger circuit can't damage the part if you put it in wrong (emitter correct but bases flipped) and the trimpot is not dialed to the max.
        Or maybe build an UJT oscillator or LED blinky to verify it works.
        I updated the previous schematic, can you check it with what you have got or post pics.
          UJT:
          https://www.elprocus.com/introductio...and-operation/
          https://www.watelectronics.com/uni-j...working-types/
          • Willybb
            • Nov 2019
            • 4
            As far as I can tell the only difference from your schematic to my PCB is the addition of a 6.8K resister (measures 6.9K) across the 5K potentiometer. I had removed the pot and one end of all resisters to check their values.
            I'm planning to solder in the 2N2646 and test the Charger tonight. Lets hope for no smoke. :-)
            Willy
            • Willybb
              • Nov 2019
              • 4
              Hi Guys
              The good thing is there was no smoke. The bad thing is there was no output. So either the replacement 2N2646 I got was defective or that wasn't the problem? I need to get into this thing a little deeper.
              I notice that the 8.2 zener looks strange. Almost like it has been hot? I need to test it or maybe just replace it.
              So the adventure continues.
              Willy
              • redwire
                • 3912
                It won't start charging unless a battery is present.
                The SCR's will stay off until the UJT starts oscillating and driving the trigger transformer- which needs power downstream of the SCR's.
                You could try, with it unplugged, using a lab power supply or something to give it 12VDC at the charger's output terminals. You should see ~8.2V across the zener and the UJT will oscillate assuming the trimpot is set for it to shut off at 14V or so.
                • motormayhem
                  Lenovo T460 Only Charges on One Charger
                  by motormayhem
                  Laptop Question
                  I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                  A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                  05-12-2023, 01:46 PM
                  NVDC charger configuration...
                  11-05-2024, 03:28 PM
                • flat-earther
                  how to prevent a connected charger from draining battery when not charging?
                  by flat-earther
                  I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                  So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                  but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                  So the battery is backfeeding the charger and being drained.
                  How can I prevent...
                  08-07-2025, 01:04 PM
                • flat-earther
                  ASUS X54H laptop thinks it's always charging even with charger unplugged
                  by flat-earther
                  The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                  Windows also shows ''Plugged in'' when charger is not connected.
                  This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                  Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                  If I let battery run out and say it has 3% Windows will...
                  06-24-2025, 09:32 AM
                • Johndill
                  Dell Inspiron 7567 LA-D993P odd charger issue
                  by Johndill
                  Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                  There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                  I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                  Here are the tested scenarios:
                  1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                  2. With the laptop off, plug in charger (LED says on) & the front charging...
                  11-16-2022, 10:55 PM
