LED Flashlight cree xm-l t6 COB Review of power supply
    • Jul 2011
    • 6039
    Re: LED Flashlight cree xm-l t6 COB Review of power supply
    Most of the time
    I do pay very much about what a company claim about brightness and about battery running time because
    Most of the time they full of crap
    The brightness of this flashlight is decent but the only complaint I have is the focus is a little bit crap-ee in that it is square all the way in and way out it is mostly a circle
    But the flashlight itself is worth $7.50 for what I paid for
    Now the charger that runs 110 ac voltage is worth maybe a $1.00 that’s for the charging power cord for it plug to charge the battery
    Now the 12 volt car charger is only good for the cord same as above
    The battery worth I have not determined as of yet
    Because I have not tested it completely
    But I am going to remove the heat shrink tubing that on the battery then I will know more
    Here are some pictures of the switching power supply for this flashlight
    I have a use for this switching power supply I going to run some LED lights off it it says 4.2 volts @ 500 milliamperes
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      i doubt that will pass a hipot test.
      not enough separation.
      no opto either.
      no cc/cv charge control.
      it just floats the cell at 4.2v
      thats a nono for li-ion.
      kill it with fire before it kills you with fire!
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        http://budgetlightforum.com/node/65678
        a whateverfire shit with a different name.
        they didnt even bother to fix the chinglish found on many other junk batteries.
        Here is a photo of the model of flashlight and battery that I am talking about
        As you can see there is NO protection board any where on this battery
        They are trying to hurt someone with this crap really
          • Jul 2011
          • 6039
          no opto either.
          This is why it going to get a 0.500 milliamperes in-line fuse on the input
          on these two switching power supply and use some real cheap LEDs so I do not care what happens to them I want to see some carnage some smoke and maybe some fire but I do not think I going to get that lucky
            • 31020
            i wish i had kept mine - i could do with some thin enamel coated wire right now!
              • Jul 2011
              • 6039
              This forum had very good reading about fake batteries and what to be aware of
              Thanks for sharing this
                by sam_sam_sam
                03-31-2024, 02:12 PM
                by sam_sam_sam
                07-01-2024, 06:34 AM
              • shamsudeen
                Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                by shamsudeen
                Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                i know that in linear power supply the noise will be very low comparing to SMPS supply....
                07-19-2025, 07:14 AM
              • CMCM
                Russound CA4 Power Supply Repair
                by CMCM
                Hello Everybody,
                Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                The outputs marked 12v and 20v are all measuring only 1v.
                The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                The capacitors physically look clean (no bludgesor leaks) and...
                07-03-2025, 01:12 PM
