LED Flashlight cree xm-l t6 COB Review of power supply
    • Jul 2011
    • 6063
    Re: LED Flashlight cree xm-l t6 COB Review of power supply
    Most of the time
    I do pay very much about what a company claim about brightness and about battery running time because
    Most of the time they full of crap
    The brightness of this flashlight is decent but the only complaint I have is the focus is a little bit crap-ee in that it is square all the way in and way out it is mostly a circle
    But the flashlight itself is worth $7.50 for what I paid for
    Now the charger that runs 110 ac voltage is worth maybe a $1.00 that’s for the charging power cord for it plug to charge the battery
    Now the 12 volt car charger is only good for the cord same as above
    The battery worth I have not determined as of yet
    Because I have not tested it completely
    But I am going to remove the heat shrink tubing that on the battery then I will know more
    Here are some pictures of the switching power supply for this flashlight
    I have a use for this switching power supply I going to run some LED lights off it it says 4.2 volts @ 500 milliamperes
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      i doubt that will pass a hipot test.
      not enough separation.
      no opto either.
      no cc/cv charge control.
      it just floats the cell at 4.2v
      thats a nono for li-ion.
      kill it with fire before it kills you with fire!
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        http://budgetlightforum.com/node/65678
        a whateverfire shit with a different name.
        they didnt even bother to fix the chinglish found on many other junk batteries.
        Here is a photo of the model of flashlight and battery that I am talking about
        As you can see there is NO protection board any where on this battery
        They are trying to hurt someone with this crap really
          • Jul 2011
          • 6063
          no opto either.
          This is why it going to get a 0.500 milliamperes in-line fuse on the input
          on these two switching power supply and use some real cheap LEDs so I do not care what happens to them I want to see some carnage some smoke and maybe some fire but I do not think I going to get that lucky
            • 31188
            i wish i had kept mine - i could do with some thin enamel coated wire right now!
              • Jul 2011
              • 6063
              This forum had very good reading about fake batteries and what to be aware of
              Thanks for sharing this
                by sam_sam_sam
                03-31-2024, 02:12 PM
                by sam_sam_sam
                07-01-2024, 06:34 AM
              • shamsudeen
                Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                by shamsudeen
                Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                i know that in linear power supply the noise will be very low comparing to SMPS supply....
                07-19-2025, 07:14 AM
              • JimBanville
                Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                by JimBanville
                The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                09-13-2023, 07:21 AM
