Fix Thermocouple
  • capwizard
    • Jun 2016
    • 1991
    Fix Thermocouple
    I have 3 thermocouples which I bought from Aliexpress has 2 meters long, very inconvenience to use. my question is thermocouple is two metal welded together. can I cut it then weld to make multi thermocouple?
    I cut open the one is not working, the wires are separated can I weld it and fix it?
    • Jul 2011
    • 6037
    Re: Fix Thermocouple
    Does it work when you put them together if so then yes if you can welded if you can do it with out distorting the two wires
    Or you can twist the two wires together and use a wire crimp and cut the end off of it
    I have done this on “ K “ type before and work very well
      master hoarder
      • May 2008
      • 12170
      • Bulgaria
      If it's type-K, yes you can fix it.
      I've done it quite a few times, actually. But my procedure isn't very exact, so bare with me as I try to explain. Basically, the idea is to overload the thermocouple wires with current at a certain point of interest, which will then weld together.
      The first thing to do for this procedure is you twist the two thermocouple wires at one end so that the twisted segment is about 5 to 10 mm long. Next, put an alligator clip on the twisted section closer to where the wires untwist and go into their insulating sleeves (i.e. DON'T put the alligator clip at the end of the twisted segment.) After this, you will need a high current supply... but something that won't go kaboom when you short-circuit it, because that's what we will be doing pretty much. That is, you take the other end of the alligator clip and connect it to your high current power supply's ground. After this, you bring the thermocouple's twisted end close to the positive (or negative?) end of the high current power supply and you short it out - i.e. you are putting a short-circuit / high current through the twisted segment of the thermocouple wire ONLY (and not the entire probe). The high current will melt the two twisted wires of the thermocouple and _hopefully_ weld them. I say "hopefully", because you have to get the current/voltage (i.e. dissipated power) right.
      When I fixed my probes, I actually didn't have a high-current power supply. So what I used instead... and note, THIS IS DANGEROUS ... is a small space heater set to low (about 6 to 8 Amps power draw from the wall normally, IIRC) and essentially powered it through that short twisted thermocouple segment. Because the two wires of the thermocouple are not able to carry the current load that the space heater requires, they melt and fuse together. Of course, for some thermocouples I had to try the above procedure a few times, mainly because I was probably running way too much current through them. Thus, if your twisted segment keeps "blowing up" and not welding, you current is probably too high. And if the twisted segment only starts glowing barely, then you're not supplying enough current.
      And again, just to clarify with the abovementioned method: you are NOT running current through the entire length of the thermocouple probe, but ONLY the short twisted section at the end you want to "weld" together.
      Also, another thing to clarify with MY method with the space heater above above: I was working with LIVE WIRES here, which IS VERY DANGEROUS. DO NOT ATTEMPT if you don't fully understand the risks of doing that or what you are doing.
      Oh, and wear safety glasses if "welding" the thermocouple with the above procedure. Like I said, if you put too much power, the twisted segment will spark and blow up and not weld.
      So any time you have things like that, you should be wearing safety glasses. I mean, this should go without saying, but I've seen people do silly things without any care too many times... and you only have TWO eyes. So better to protect them.
        • Jul 2011
        • 6037
        Thanks for sharing this I have not tried it this way before but I will keep this in mind for next time
          master hoarder
          • May 2008
          • 12170
          • Bulgaria
          ^ You're welcome, Sam!
          Hope it works for you too.
          • ChaosLegionnaire
            correct way to connect bare speaker wires into spring clip terminals?
            by ChaosLegionnaire
            i recently bought a logitech z607 surround system. however, its giving me grief. when i first connected it, it only had sound coming from the front right speaker. after a great deal of fiddling and reseating the speaker wires into the spring clip terminals, i finally had sound coming from all 5 satellite speakers.
            however, the sound still gets cut off intermittently if i move the speakers, subwoofer or move/touch the speaker wires on the back of the subwoofer. so i wanna ask what is the right way to connect bare speaker wires into spring clip terminals?
            i googled...
            10-27-2022, 06:19 AM
          • budwich
            Headphone wires.... confused!
            by budwich
            I picked up a "beat up" set of sennheiser headphones (hd201). The phono plug end seemed to have an issue such that most of the time only one ear would work but by compressing / bending the jacket of the phono plug, I could cause the other ear to work. Must be a phono jack (3 pin) problem. So I cut it off and have solder based replacement. BUT... the wiring seems "mysterious" to me. I can't see how this can work or even ever worked. Attached is a picture of the wires (less the phono plug). One sheath has what I believe is two enameled wires while the other has basically...
            09-01-2023, 07:27 AM
          • playit
            psu sata power wires thinner - does it make a difference ?
            by playit
            hello , i have a psu 450 zebronics (yes its bad crap) which used to work before with its own sata power cable ,but today its not able to power up harddrive efficiently with its own power sata cable , but when there is a connector which have a thick wire than the psu sata power cable wires - its powering up and working smooth , no problem yet .
            i the voltages with multimeter shows 12 ,3.3 v , no problem , but hardrives powers well only with this thick wire sata power cable connector from psu power molex .
            any explanation on this ?? thank you ,soon i am planning to buy some branded...
            10-12-2023, 05:25 AM
          • Dannyx
            Wire twisting tool for small wires - ideas ?
            by Dannyx
            Good day folks. Recently, I started doing more and more alarm system installs which involve dealing with a ton of small wires which are part of 4 to 12 core alarm cable. To make my installs as clean and neat as possible, I twist together the individual wires whenever possible to make braids like in the picture. It takes a lot of time and wears on my fingers really quickly, to the point where I actually developed a blister on my index finger from all the twisting. This got me thinking if there's a tool designed to braid small wires like this. I know there is something for twisting together solid...
            08-23-2020, 06:29 AM
          • spleenharvester
            Making a Handskit hot air station a bit less stupid
            by spleenharvester
            I bought one of these as it was the only one I could find that is compact enough to fit in my toolbox (though I've since found KSGER make a substantially safer looking one). It's one of those fan-in-handle things that has the 230V element in the handle. Quecoo briefly sold a similar unit but discontinued it.. maybe they couldn't find solutions to these problems. I'm aware these fan-in-handle things are garbage compared to a good air pump station but I only really use this for occasional QFN work etc.
            I did not realise at the time of buying that its design is... interesting, to say...
            05-09-2024, 09:09 AM
