Can we omit reflective paper?
  • capwizard
    • Jun 2016
    • 1991
    Can we omit reflective paper on LED panel?
    This series of Samsung TV (Un32H5203) LED strips are total garbage. We need to change all the LED stripes but I don't want to spend money so I just use the LED Stripes from another TV set. I tried to cut holes to match with LED positions that's a lot of works. I have an idea! can we just use white paint to reflect the lights?
  • gabiz_ro
    • Mar 2011
    • 167
    • Romania
    Re: Can we omit reflective paper?
    Better some "hollow punch" to make holes in reflective paper.
    Or diy some metal pipe sharp on edge and make holes easy.
    • capwizard
      • Jun 2016
      • 1991
      Thank you, my friend, I did try but it is not working good so I will try to do is use the heater pipe and stamp on it.
      • capwizard
        • Jun 2016
        • 1991
        (1) I took out LED stripes from this TV.
        (2,3) it is a 50in TV with long stripes with my specially customized tool, no problem even leds have glue on them.
        (4) so I just use half of them and shorted the connectors for return current.
        (5) tested with my Antique LED Tester.
        (6,7) tested with TV power supply. The connectors to the LEDs are being burnt. so, I just jumped wires to the backside of PCB.
          https://www.badcaps.net/forum/attach...0&d=1551719016
          Poor contact resistance, better off solder the wires to the board directly, or replace the male/female connectors.
          https://www.badcaps.net/forum/attach...8&d=1551719016
          So that is about 2.75 Vf per LED at 11mA.
          • capwizard
            • Jun 2016
            • 1991
            (1) The TV has 24 LEDs but I put 28 LEDs then I found out, LEDs will have had a blinking problem.
            So I just bypass 4 of leds
            (2) I try to make an EXT adapter to my antique LED tester easier for me to use the same meter as an external meter then I will let you know.
            • capwizard
              • Jun 2016
              • 1991
              Yes, One thing I always wanted to do was that I wanted to know how the voltage and current of a real TV drive the led panel. I put a switch to my antique LED tester so I can put the voltage and current meter for external use. The total is 24 leds. Voltage and current divide by 24 will be each one.
              (4) shows 77.3v at 310ma. 77.3v/24=3.22v
              at 310ma for each led.
                3.22V forward Voltage at 300mA is about right, if you look at the graph of Vf VS If you can see it is about what you expect to get.
                Example: Vf VS If chart for single LED rated at 240mA
                • capwizard
                  • Jun 2016
                  • 1991
                  From the data, we can see that manufacturers are overdrive the leds cause a lot of problems
                  Now we go back to the topic: Can we omit reflective paper replace it with white paint?
                  the answer is...Why not! The result is amazingly good with no white highlights, no spots. Why don’t you try it yourself next time? Don't forget to use high gloss paint.
                  • gabiz_ro
                    • Mar 2011
                    • 167
                    • Romania
                    Some strips are bonded or in contact with metal ,using at heatsink.
                    There is double side adhesive in some cases and affect thermal transfer,with one layer of paint this is worse.
                    Protect area where strips will be mounted with something like scotch tape and after paint dry remove it so strips will be in contact with metal.
                    No dark area where are those bypassed leds?
                    Better search for schematic or datasheet of driver IC and adjust OVP protection to allow higher voltage so all leds will light fine.
                    Test with image is not so relevant, better check with white screen to see spots or dark area or any other problems with backlight.
                    • capwizard
                      • Jun 2016
                      • 1991
                      very good questions.
                      (1) I thought about that too, LED strips need to touch with the metal sheet to dispatch heat which are the major causes the failures of the LED stripes. This is my first time using this method. I am thinking that there is still much room for improvement.
                      (2) not perfect but still acceptable. Pic ( 2)
                      (3) Because of the lack of documentation, so far I only have one model that I can do it to adjust led driver's voltage.
                        HP ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio ProDesk 400 i5-6500 Specification for Upgrade or Repair
                        This specification for the HP ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio boardview and ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                        09-12-2024, 03:28 PM
                      • CapSnap123
                        Sensor on Aurora AS1018CD paper shredder doesn't work
                        by CapSnap123
                        I'm getting frustrated troubleshooting a paper shredder. The way the shredder normally works is when you turn the power on, nothing happens until you insert a piece of paper. There is an IR shredder in the shredder and inserting the paper breaks the beam and starts the shredder motor. But now the motor runs constantly, even when no paper is inserted. I've replaced the photodiode and the IR emitter. Also the relay makes a nice clicking sound so I assume it is working too. I don't know what else to check. Here's a photo of the circuit board. The red and black wires marked IR - go to the...
                        04-20-2024, 03:57 PM
                      • Petros_Z
                        Led stripes for Toshiba TV 32W1433DG
                        by Petros_Z
                        Hello, I have the TV of the title and it has problem with the led stripes. The code of the stripes is VES315WNDA-01. Also on the chassis there is a code "Model VES315WNDS-01". Searching for spare parts I found that there are led stripes for each of those codes. I don't know if someone had changed them before. Based on what code should I order the spare parts? From led stripes or chassis?
                        Thanks in advance and sorry for my bad English.
                        04-02-2024, 02:59 AM
                      • kotel studios
                        Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
                        by kotel studios
                        Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
                        In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
                        Yesterday, 02:07 AM
                      • halen
                        Hisense H55U7B vertical stripes
                        by halen
                        I have Hisense H55U7B TV with no picture, only big vertical stripes. I did several tests and I'm not sure, where is problem.
                        1. Connected tcon to 12V, white, red, green, blue, black picture visible in cycle on full LCD without error
                        2. Connected only left side of LCD to tcon, big stripes
                        3. Connected only right side of tcon, visible normal picture on the right. Working as expected.
                        Where could be problem?
                        Tcon RSAG7.820.7932/ROH
                        Main board RSAG7.820.8698/ROH
                        Jan
                        06-18-2025, 03:58 AM
