Repairing my cable tester. Bad resister?
  • roveer
    • Feb 2019
    • 5
    I've got a cable tester that has a thing called a super injector. You put it at the other end of the cable you are testing and it communicates with the test set.
    It's been giving an error saying that pin 3 is not connected. The test set works just fine (I got another injector to verify). I opened it up and found what looks like a cooked resister (or is it a diode?). It's a board mounted device marked 2430
    I googled around and couldn't seem to find this component. Can someone give me some advice on where I could find it or what I could substitute. This pcb fits in a fairly large box so there's lots of room above those pads.
    Thanks so much. Looking forward to doing my first board level repair.
    Roveer
  • R_J
    • Jun 2012
    • 9569
    Re: Repairing my cable tester. Bad resister?
    It's a resistor, check it with an ohm meter, 243Ω
    It is likely ok and something else is bad
    Lots of them at digikey https://www.digikey.com/products/en/...=1&pageSize=25 measure the physical size to get the correct one
    • roveer
      • Feb 2019
      • 5
      All the other similar resistors are measuring .325-330 but that one is open. Thanks for the digikey info. I'm going to try and get a replacement and see what happens.
      Roveer
      • R_J
        • Jun 2012
        • 9569
        Something caused it open so check if there is something shorted that is connected to that resistor. Without seeing both sides of the board its hard to say what caused it.
        Or was there external voltage on the cable being tested?
        • roveer
          • Feb 2019
          • 5
          I think there are 8 of these resisters around the RJ45 so it's possible the stray voltage came in from the external connection. I will look to see if I can follow the traces and check components on either side. This device isn't critical, I long ago replaced it. I'm using it more as a project to teach myself a little about diagnosis/testing and component level soldering. Fortunatly this particular component is just big enough to not require microscope or heat gun.
          How can I determine the wattage of that resister? Looking through the digikey listings there are many different values.
          Roveer
          • R_J
            • Jun 2012
            • 9569
            I doubt the wattage is that critical, I would make sure the length is correct to fit the pads. The wattage won't be that high, likely 1/4 watt
            I will take a guess based on the transistor (sot23-3) that the resistor length is 3mm
            • roveer
              • Feb 2019
              • 5
              I received my resistors today from digikey. Tonight I soldered in the replacement and the unit now works. My first board level repair.
              I learned that I need something to hold a magnifying glass and a better soldering iron. Eventually I'll probably get a Weller or a Hakko. I want to be just like Louis!
              Thanks for the help.
              Roveer
              • Patch2
                Cable Repair
                by Patch2
                I have a broken connector (believe it's a 6 pin mini-DIN) on a cable. The metal shroud and all but one of the pins are separated from the cable, and just stuck together for the photo. The other end is an unknown rectangular connector. The cable is for the foot pedals on an Italian made electronic piano, and the company is out of business. Looking for ideas on how to fix it. I have a soldering iron, but I'm not very skilled at soldering, so getting a retrofit for the broken end may be beyond my ability. The other end would be easier to replace, if I could get a mini-DIN cable with the same number...
                01-02-2025, 06:04 PM
              • Tr0ll
                by Tr0ll
                Original T-con:
                First replacement T-con:
                10-07-2023, 07:48 PM
              • conghuyms
                I need datasheet cable eDP LCD 30 pin slim pls help me!
                by conghuyms
                My 30-pin eDP cable from the mainboard to the LCD screen got cut and damaged at the screen connector side. I found another cable and took the screen-side connector from it, but the wire colors are different. So I really need the wiring diagram for both ends of the eDP cable to solder it back properly. If anyone has the diagram, please kindly help me out. Thanks a lot...
                08-22-2025, 11:16 AM
              • fweonea
                HP-Pavilion x360 Laptop Dead After USB-C Cable Connection
                by fweonea
                While at university, I connected my HP-Pavilion x360 14-dw0156ng laptop, running Windows 10, to a monitor using a provided USB-C cable. Immediately after this, my laptop's screen turned black and the device stopped working entirely. There are no signs of life such as fan noise or LED indicators, holding the power button does nothing. I've previously used this same monitor model and cable without issues, the cable typically charges the laptop as well.
                I've attempted holding the power button for over 30 seconds, removing and reinserting the battery, and trying to power it on with only the...
                01-16-2024, 11:35 AM
              • marce002
                Help me make charger USB C cable with no cc pins!!
                by marce002
                Hi all, please
                I just want to make a "usb c" charging cable from 5V power supply (have cut cable w/ red black green and white pins connected from factory.... i just want to use 500mah max !
                How do I connect this ? if I do not have CC1 /2 physically wired, how to proceed?
                NOTE: an identical new (not cut) USB A to USB C cable charges my phone but not the remote control!
                here is a picture of the remote, the cable to be used and a picture of what are the factory connected pins
                thanks in advance!!
                11-17-2023, 09:16 AM
