i need datasheet for mt3360cbcg
  • ghoshiry
    • 90
    • iran
    hi guys
    ineed data sheet for this ic
    i went to program online nand by this ic
    • 31281
    Re: i need datasheet for mt3360cbcg
    mediatek??
    good luck!
    • ghoshiry
      • 90
      • iran
      this is the chip
        • 31281
        you may also try finding data for the module it's mounted on.
        • ghoshiry
          • 90
          • iran
          i cant find
          can you find to me
          tankyou
            • 31281
            post a picture of the whole module, i can only see part of the label.
            • ghoshiry
              • 90
              • iran
              this to you
              • tranquility
                Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
                by tranquility
                i want to repair an Onkyo TX-NR809 receiver.
                symptoms:
                on power on, display appears and i hear one click. enue functions is given.
                - no hdmi output
                - audio output not tested, but i think it is not there
                - usb sticks are not recognized
                if i read out the chips with display+standby button + tone+
                both dts show only ????
                chip is D830K013BZKB4
                things i have done:
                - reflow of the dts chip without taking off and reballing
                - changed the aluminium caps without the big one with 25v because i dont...
                08-25-2025, 01:04 AM
              • mattpd
                PS5 EDM-031 - Pulsing BLOD - SSD NAND chips never heat up
                by mattpd
                PS5 died in the middle of a game and never would boot again. Pulsing BLOD stays on forever but never boots.
                No LM damage. UART gives a generic "APU not responding" error.
                Under thermal camera, the SSD NAND chips stay stone cold. The controller warms, but not the NAND. I have a good 2.5v and 1.8v around the NANDs...
                I don't have a ton of PS5 experience, but I assume that the NAND would need to warm at least a little bit in order to boot...
                So to those with experience, would you expect at least a little heat from the NAND during...
                09-02-2025, 09:42 AM
              • ronaldopdias
                ene kb9028qc pin out or datasheet or how to program.
                by ronaldopdias
                Please does anyone has any information for ene kb9028qc.
                Pin out
                How to program it?
                03-10-2023, 04:00 PM
              • sohail5307
                Need a2159 128gb nand bin file
                by sohail5307
                I have received SSD nand short A2159 macbook. I received new tsb4226 nand , but i think this is removed from iphone, I have nand programmer , if anyone have nand firmware please send me
                Two nand are using :
                Tsb4226(128gb)
                Tsb4226(128gb)
                09-16-2023, 09:20 PM
              • tech_guru
                Macbook Pro 2019 A2141 NAND Shorted
                by tech_guru
                Hello. If you could please help me understand what I am doing wrong...
                This model, Macbook Pro 2019 16" A2141, 512GB, EMC 3347, with T2 Security Chip, had 4 NAND Chips shorted in 1 wing (U9100, U9200, U9300, U9400) and it has 1 more in the 2nd wing (U8600) BUT NOT shorted. All chips are TSB4227 TOSHIBA-KIOXIA SN4192TWNA12014 BGA110 128GB. I got 4 new nand chips for 1 wing and programmed them by specific position of course with JCID P13 programmer.
                I also replaced the tps power ic for the ssd.
                Now all rails come up, including the ssd rails 0.9v, 1.8v, 2.5v....
                08-28-2025, 08:04 AM
