Modifying IR LED array for brighter light
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. I'm going to install a camera for my door and to make it less obtrusive and prone to vandalism, I got myself an intercom outdoor unit which already had a camera in it and 6 white LEDs. I replaced the camera module with a better one and now I wanted to replace those highly obvious white LEDs with some IR ones. I salvaged some from some old CCTV cameras and installed them. They DO come on, but they're very dim and not useful at all. I drew the schematic of the LED section hoping to somehow be able to give them more oomph without frying them of course.
    One thing I find strange is that the original white LEDs when tested individually with my bench supply came on at 3v. Anything lower and they wouldn't light up at all. These IR ones come on VERY brightly at 3v and draw a not inconsiderable 50mA (from what I could briefly spot on my supply's display), so I was afraid they'd actually burn out, but on the contrary: they're dim.
    I was thinking of dropping the value of either R9 or R8. What do you guys think ? Have you seen a similar circuit before ?
    Wattevah...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8689
    Re: Modifying IR LED array for brighter light
    IR LEDs use a different chemistry than white/blue/violet LEDs and have a much lower characteristic forward drop, typically around 1.5V. Getting them to 3V will likely kill them.
    Most consumer cameras have IR filters that make IR LEDs appear dimmer than they really are. You will need to remove the IR filter or get a camera that will respond to IR if you want full brightness.
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      Right, forgot to mention the test conditions: I used my phone to do it. Not only to check the polarity when installing them, but also to get an idea of brightness. As expected, it showed up as a purple light. It was fairly bright at 3v, but not so bright in-circuit, obviously.
      Yes, you're right: they may not help the camera out in the dark. This is actually a camera module I picked up from Ali. It's got a joystick and some menus you can mess with and this IR filter you're mentioning could be part of the lens or something, because I see two thin wires running to the base of the lens (where it meets the board). Messing with some options in this menu, I could hear something clicking there, so there's some sort of aperture or filter moving in and out of the way, probably related to those wires...could have an effect on how effectively IR works.
      Wattevah...
      • redwire
        • 3902
        Q3 is supposed to be constant-current source- but missing a zener (constant voltage) from the base to gnd, so Q3 ends up being a switch like Q9. Unless R8 goes to +5V instead, that would make more sense.
        Right now R9 ends up limiting current to the LED strings, about 60mA total or 30mA per string by my guess. Lowering R3 to 47R 1W would give double current ~120mA or 60mA per string.
        I don't think 5mm IR LED's can take 50mA or more without getting damaged? They also have a very low forward voltage 1.25-1.6VDC compared to red, blue etc.
        Don't look at them with the eye or you can damage it, you don't "see" IR but the light still gets in to the retina.
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          First order of business is to figure out if the camera can work with IR light, otherwise it's all for nothing. I'll check the circuit again, but I believe it's correct.
          Can you explain some of your calculations ? I'd like to know how you got those numbers.
          Wattevah...
            https://www.radio-electronics.com/in...ent-source.php
            Q3 is the low side CI source.
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              • Romania
              Oops, I missed something indeed: there's two diodes on the base of Q3 arranged in series like so. 1n4148 judging by their looks, as I can just about make out 1n on there, since they're flat on the board and can't really see them.
              Are they using the Vf of the diodes as a "zener" reference voltage ? The Vf of a 1n4148 is around 1v from what I remember, so would this mean the "zener voltage" is 2v ?
              Wattevah...
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
              • zman78
                Screw-In Barrel Adapter for LED light array gets really hot?
                by zman78
                Hi All,
                I have an LED Light array that had a built-in AC-DC 24v 45 watt power supply. The power supply failed so I desoldered the LED Light array power input wires from the power supply and then screwed it into barrel connector jack (ends still tinned with the original solder).
                This is the barrel connect or jack https://www.amazon.com/gp/product/B07Q6YMM6F/
                Then I bought an external 24Volt/3Amp power brick (with same size barrel connector output) and plugged it in.
                Everything works fine, except that the screw-in barrel connector gets...
                06-28-2021, 03:35 PM
                Lithonia Lighting versus Light of America Compact Fluorescent product quality
                by sam_sam_sam
                I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                I also have back when Light of America had these light bulbs available for yard lights
                The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                While the Lithonia lighting fixture has all most certain bulb failure
                So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                I have only had this light fixture for not more than a year if it...
                07-02-2023, 03:45 PM
              • Pipolups
                Corsair K70 LUX RGB dying LEDs
                by Pipolups
                Hi there !
                I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                10-08-2024, 11:58 AM
                LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                09-07-2024, 03:40 AM
