Budget level ESR meter for beginner ?
  • Widget
    • Aug 2015
    • 74
    Hi guys,
    Bought one of these DIY ESR testers some time ago.
    https://www.ebay.com.au/itm/Transist...JR7A:rk:7:pf:0
    Didn't get around finishing it, ended up losing a couple of the parts (inc. the main MC); and rather than buying the replacement parts, figure it would better to just get another due to the price.
    It's only a basic tester, but I did notice there were 2x kinds;
    and
    https://www.ebay.com.au/itm/DIY-SCR-...f06c:rk:1:pf:0
    Similar in price, wondering if there were any differences that you guys know of?
    Apart from that, is there a basic/budget alternative you would recommend ? Maybe one that can test parts in-circuit ?
  • dmill89
    • Dec 2011
    • 2534
    Re: Budget level ESR meter for beginner ?
    Originally posted by Widget
    Hi guys,
    and
    Functionality wise they are similar (at least the component testing part) and neither can test components in-circuit.
    This one is a kit and uses "through-hole" components to allow easier assembly and also includes a basic square-wave generator: https://www.ebay.com.au/itm/Transist...JR7A:rk:7:pf:0
    This one is pre-assembled and thus uses more compact surface-mount components, it also omits the square wave generator and is more-compact as a whole: https://www.ebay.com.au/itm/DIY-SCR-...f06c:rk:1:pf:0
    • Beau28713
      • Feb 2018
      • 50
      I use the Bob Parker design Anatek blue ESR meter. Cost about $80 but works well for me.
        • Jul 2011
        • 6070
        I second this I have one also and quite often It has help me repair a lot of things
        • madan1
          • Nov 2016
          • 726
          Well, I have the red one and it has a "capacitor measuring" mode accessible from the menu.
          Here is an extract from the manual
          "The additional function "C+ESR@TP1-3" selects a stand-alone
          capacity measurement with ESR (Equivalent Series Resistance)
          measurement at the test pins TP1 and TP3. Capacities from 2uF
          up to 50mF can be measured. Because the measurement voltage
          is only about 300mV , in most cases the capacitor can be
          measured "in circuit" without previous disassembling."
          • Thedoc298
            • Apr 2018
            • 6
            I have a few in all price range, but this one does really well and has a case and lot's of hidden features.
            https://www.ebay.com/itm/2018-MK-328...72.m2749.l2649
            • chth96
              by chth96
              03-09-2024, 10:03 PM
              12-31-2023, 06:04 AM
            • Mark D
              Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
              by Mark D
              The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
              10-29-2024, 03:15 PM
            • jorpec
              by jorpec
              Hi
              Thnaks
              01-23-2023, 10:37 AM
            • Stephan Mathers
              EDMI ATLAS MK10 Electronic Meter Discussion
              by Stephan Mathers
              Greetings, new guy here but always interested in the crazy universe of modding
              We just finished construction of around 25 vacation houses, all inside the same private area.
              Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
              The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
              Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
              05-20-2025, 09:09 AM
