Fluke 87 issue
  • Tallone42
    • Jun 2017
    • 9
    Fluke 87 issue
    Somehow my fluke went out. I checked the normal things, fuses, etc and upon opening it all the way, found what looked like old water damage. Anyway, Ive narrowed it down to two bad surface mount resistors. A blue 1073 and a similar 2103. I'd like to order these but I have no idea, where or what kind they actually are. They are .3 mm long. Any ideas?
    • 31191
    Re: Fluke 87 issue
    what version of the 87?
    tell me it's a "V" !
    • Tallone42
      • Jun 2017
      • 9
      Re: Fluke 87 issue
      It just says 87, but it doesn't have the fuseable resistor like the one I've seen in the first Gen, so I'm not sure.
      Tell me you have the resistors! Lol
      • petehall347
        • Jan 2015
        • 4439
        Re: Fluke 87 issue
        http://www.resistorguide.com/resistor-smd-code/
        https://www.westfloridacomponents.co...tor-sizes.html
        • retiredcaps
          • Apr 2010
          • 9271
          Re: Fluke 87 issue
          Originally posted by Tallone42
          It just says 87,
          A picture would help us help you.
          Service manuals with bill of materials are available for the Fluke 87 I (original), Fluke 87 III and now FINALLY Fluke 87V.
          Fluke 87V service manual at
          https://www.eevblog.com/forum/testgear/87v-schematics!/
          --- begin sig file ---
          --- end sig file ---
          • Tallone42
            • Jun 2017
            • 9
            Re: Fluke 87 issue
            Ok, hopefully this works. You can see the two blue ones that are bad. I looked at that website already and unless I'm measuring them wrong, they don't show any this small
            • Tallone42
              • Jun 2017
              • 9
              Re: Fluke 87 issue
              Sorry, this shows the two I'm looking for
              • retiredcaps
                • Apr 2010
                • 9271
                Re: Fluke 87 issue
                Those are good pics.
                1) You have a Fluke 87 II (with the CAT III ratings by the Volt/ohm jack). It is the 87 I, but with update CAT requirements.
                2) In your picture with the 2103 and 1073 SMD resistors, you clearly have some corrosion in that area from the water. A thorough cleaning of pcb with IPA is recommended.
                The pcb tracks around that entire area could be broken with no continuity and the SMD resistors may not be touching their solder pads.
                3) I suggest looking at modemhead's blog pictures and fixes for #2 above.
                http://mrmodemhead.com/blog/fluke-23-iii-dmm-repair/
                http://mrmodemhead.com/blog/fluke-77...per-corrosion/
                4) The track to 2103 is clearly missing. You can see the solder clearly missing.
                • Tallone42
                  • Jun 2017
                  • 9
                  Re: Fluke 87 issue
                  You know I didn't even see that? Looking at the board with the bare eye, it looks intact, I had to look at the picture to see what you were referring to and then got the board under a magnifying glass and sure enough. I'm going to follow the directions from your link later today and see if that works. I'll post my results. Thank you again. Love this website.
                  • Tallone42
                    • Jun 2017
                    • 9
                    Re: Fluke 87 issue
                    Well, upon further investigation, and checking it with my meter, that line is still intact. It's the coating that's came off. Those two caps read 89k and 130k respectively. I know I should remove them to read them but checking all the other ones, and the fact they are reading within limits, I'm still thinking those two are shot. That whole corner of the board is where the corrosion damage was.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      Re: Fluke 87 issue
                      Before we assume the SMD resistors are bad, especially since other components in series/parallel can affect your readings, let's take a step back.
                      What is actually wrong with Fluke? You never stated what exactly is wrong?
                      First, does it power up at all?
                      Since you essentially have a Fluke 87 original series meter, did you following and check the test points (TP) as outlined in the Fluke service manual (Table 3-14). In particular, what is VDD, VSS, etc?
                      As an example, see
                      http://mrmodemhead.com/blog/fluke-83-dmm-repair/
                      Fluke service manual at
                      https://cdn.badcaps-static.com/pdfs/...703bf9edff.pdf
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        Re: Fluke 87 issue
                        This area still looks suspect to me in the photo.
                          • 31191
                          Re: Fluke 87 issue
                          if that's what you call damage, you obviously never saw a ni-cad battery leak!!!!
                          • modemhead
                            Lurking
                            • Jun 2012
                            • 52
                            Re: Fluke 87 issue
                            It would be nice to know what "my Fluke went out" means. Like RC asked, does it power up, does it measure anything on any range at all? These are much better clues to the possible faults than trying to trouble-shoot by measuring various components in-circuit. More often than not, that leads to red herrings. It is unlikely that those two SMD resistors are bad.
                            If there is any hint of corrosion at all, the best plan of action is to start with a full-immersion bath in strong isopropyl alcohol and scrub the board with a brush. (*Carefully* remove the LCD assembly first, of course.) Examine all suspect areas with magnification. Continuity-test suspect traces. Vias should also be checked for continuity from top to bottom. In a battery leakage or water ingress situation, it is not uncommon for the plated-through copper inside the vias to be eroded away. A good set of sharp probes is essential for this process.
                            • PeteS in CA
                              • Aug 2005
                              • 3581
                              • USA, Unsure of Planet
                              Re: Fluke 87 issue
                              The resistors are 210K and 107K, so measuring in-circuit would be dubious. High value resistors can drop in value if they get contaminated internally. In-circuit readings are almost certain to be "low", but that could be due to other circuitry.
                              As you suggest, a better approach would be to work from the improper behavior to the circuit(s) that could cause it.
                              PeteS in CA
                              • TinkerTron
                                Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                by TinkerTron
                                Hey everyone,
                                I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                Instead, here's what's been bugging me so far:
                                The schematic...
                                03-06-2025, 02:03 PM
                              • rounin
                                MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                by rounin
                                I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                                🛠 Original Issue
                                The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                                ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                04-19-2025, 01:18 AM
                              • ugamazing
                                Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                                by ugamazing
                                I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                                We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                                12-17-2024, 07:05 PM
                              • shahnld
                                Lenovo legion 5 pro startup issue
                                by shahnld
                                Good day Experts
                                I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                                A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                                And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                                08-24-2025, 12:31 PM
                              • ahmarzo
                                Acer laptop battery draining issue
                                by ahmarzo
                                Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                                Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                                08-02-2025, 06:39 AM
