Somehow my fluke went out. I checked the normal things, fuses, etc and upon opening it all the way, found what looked like old water damage. Anyway, Ive narrowed it down to two bad surface mount resistors. A blue 1073 and a similar 2103. I'd like to order these but I have no idea, where or what kind they actually are. They are .3 mm long. Any ideas?
Fluke 87 issue
Re: Fluke 87 issue
A picture would help us help you.
Service manuals with bill of materials are available for the Fluke 87 I (original), Fluke 87 III and now FINALLY Fluke 87V.
Fluke 87V service manual at
https://www.eevblog.com/forum/testgear/87v-schematics!/--- begin sig file ---
--- end sig file ---Comment
Re: Fluke 87 issue
Those are good pics.
1) You have a Fluke 87 II (with the CAT III ratings by the Volt/ohm jack). It is the 87 I, but with update CAT requirements.
2) In your picture with the 2103 and 1073 SMD resistors, you clearly have some corrosion in that area from the water. A thorough cleaning of pcb with IPA is recommended.
The pcb tracks around that entire area could be broken with no continuity and the SMD resistors may not be touching their solder pads.
3) I suggest looking at modemhead's blog pictures and fixes for #2 above.
http://mrmodemhead.com/blog/fluke-23-iii-dmm-repair/
http://mrmodemhead.com/blog/fluke-77...per-corrosion/
4) The track to 2103 is clearly missing. You can see the solder clearly missing.Last edited by retiredcaps; 12-09-2018, 08:18 PM.--- begin sig file ---
Re: Fluke 87 issue
You know I didn't even see that? Looking at the board with the bare eye, it looks intact, I had to look at the picture to see what you were referring to and then got the board under a magnifying glass and sure enough. I'm going to follow the directions from your link later today and see if that works. I'll post my results. Thank you again. Love this website.Comment
Re: Fluke 87 issue
Well, upon further investigation, and checking it with my meter, that line is still intact. It's the coating that's came off. Those two caps read 89k and 130k respectively. I know I should remove them to read them but checking all the other ones, and the fact they are reading within limits, I'm still thinking those two are shot. That whole corner of the board is where the corrosion damage was.Comment
Re: Fluke 87 issue
Before we assume the SMD resistors are bad, especially since other components in series/parallel can affect your readings, let's take a step back.
What is actually wrong with Fluke? You never stated what exactly is wrong?
First, does it power up at all?
Since you essentially have a Fluke 87 original series meter, did you following and check the test points (TP) as outlined in the Fluke service manual (Table 3-14). In particular, what is VDD, VSS, etc?
As an example, see
http://mrmodemhead.com/blog/fluke-83-dmm-repair/
Fluke service manual at
https://cdn.badcaps-static.com/pdfs/...703bf9edff.pdf--- begin sig file ---
Re: Fluke 87 issue
It would be nice to know what "my Fluke went out" means. Like RC asked, does it power up, does it measure anything on any range at all? These are much better clues to the possible faults than trying to trouble-shoot by measuring various components in-circuit. More often than not, that leads to red herrings. It is unlikely that those two SMD resistors are bad.
If there is any hint of corrosion at all, the best plan of action is to start with a full-immersion bath in strong isopropyl alcohol and scrub the board with a brush. (*Carefully* remove the LCD assembly first, of course.) Examine all suspect areas with magnification. Continuity-test suspect traces. Vias should also be checked for continuity from top to bottom. In a battery leakage or water ingress situation, it is not uncommon for the plated-through copper inside the vias to be eroded away. A good set of sharp probes is essential for this process.Comment
Re: Fluke 87 issue
As you suggest, a better approach would be to work from the improper behavior to the circuit(s) that could cause it.PeteS in CA
****************************Comment
by TinkerTronHey everyone,
I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
Instead, here's what's been bugging me so far:
The schematic...3 Photos-
by rouninHi everyone,
🛠 Original Issue
⚠️ New Problem: One USB-C Port Only Works in One Orientation... -
by ugamazingI have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre... -
I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
To assist with troubleshooting, I'm attaching two power circuit schematics:- Power
by wizard13Hello everyone,
I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
I have checked the forum and the available documentation but could not find a solution specific to my issue.- Brand & Model: Dynabook Satellite Pro C50D-B-100
- Part Number (P/N): PYU13E-00C00PFR
- Serial Number (S/N): 22028896H
- System Configuration (SC): A1PYU13E1127
- Motherboard Model: IP3_ACN16_MB_V21_20211222A
- Power Input: DC 19V –
Channel: BIOS Requests ONLY!
- Loading...
