Multi 110v outlets, individual timed control
  • Poor Flick
    Of sound mind
    • Jun 2014
    • 3167
    • U.S.S.A. The flophouse of the world.
    I'm wanting to control on and off timing to 4 110v outlets for outdoor Christmas light strings. Probably have 1 outlet on for about 30 seconds or maybe a minute, then switch off and repeat in sequence to another for the same amount of time, each independently, not to have more than 1 on at a time. I've looked some on the internet and searched some here on BCN with no luck, anyone heard of such a timer?
    From my favoritest movie ever!:
    Cledus Snow: Can I ask you a question?
    Bo Darville: Sure, ask me what?
    Cleedus: What the Hell do we want to go to Texas for and haul beer back here? What is that?
    Bo: For the good old American life. For the money, the glory, and the fun. Mostly for the money.
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Multi 110v outlets, individual timed control
    You can't have independent and "NOT" gated at the same time...
    So you are looking for sequential timing?
    EG: socket X on for 30 seconds, then turns off and socket X+1 switches on for 30 seconds, etc, repeat?
    Follow the white rabbit.
    • R_J
      • 9579
      Put this into google " 4 channel christmas light controller " or " 4 Channel Chase Controller " they make 4,6,8 etc. channel ones
      There is an ic that can do it, UTC 8156, just add a few more parts. There is also the ELM711 ic that could be used.
        • 31142
        solid-state relays and an arduino or 4017 and 555 circuit.
        or go oldschool and find an old camswitch - that's how it used to be done.
        • Poor Flick
          Of sound mind
          • Jun 2014
          • 3167
          Thanks Goontron, I’d want X to come on for about 30 seconds or so, then shut off and the next socket Y would do the same, and continue for a total of 4 sockets.
          • Poor Flick
            Of sound mind
            • Jun 2014
            • 3167
            Appreciate it guys, the search advice really helped! I’m thinking I’m on the right track now with this or something similar:
            https://www.goknight.com/Chauvet-dj-dmx-4/
            • Yanleb
              LG 60PK550 Logic Control Board EBR63450301
              by Yanleb
              Hi all, I just want to share the repair of my 60PK550-UA TV set.
              The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
              But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
              All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
              C57: 3.30V
              C61:...
              07-20-2023, 12:38 AM
            • harp
              triac phase control 0-100%
              by harp
              Trying to understand which properties of circuit affect triac phase range, is it possible to control near whole period, or it have some limitations - on net found a couple circuit, that claims almost full control, but in the past I build some simple circuit and remember that it do only half of control over triac?...
              06-02-2024, 09:00 AM
            • tmhobadcap
              Pioneer VSX-522-K remote control not working???
              by tmhobadcap
              I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
              At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
              12-24-2020, 01:44 AM
              Linear Garage Door Opener Control board took a crap install a new control board back normal
              by sam_sam_sam
              I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
              02-08-2025, 06:52 AM
            • crackedprint
              Sony HCD-HX80R Amplifier Volume Control Problem
              by crackedprint
              I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
              I have tried a Cold Reset as per the service manual.
              I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
              I have looked all the way through the service manual and tried many online...
              01-21-2025, 12:18 PM
