How do I determine a fuse that I need for a circuit?
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    I have these very cheap but very useful 18650 battery chargers. However, if you accidentally put the battery in backwards, it immediately frys the chip on the charger and lets the smoke out. Someone at one time suggested that I use a fast acting resettable fuse inline between the battery and the charger and ive been looking at them but I don't know what kind of fuse to get.
    I was thinking that I could use a variable power supply and connect it backwards to the charger then up the voltage while I monitor the current and see at what point the chip frys ... obviously ill be able to determine how many amps it takes to fry the chip, but since the fuse must be installed in series, I don't know what voltage rating to spec the fuse at ... in fact ... i'm not even sure why fuses have voltage ratings since the voltage drop across the fuse would seem to be a non-issue. I did get some 1 amp fuses or maybe they were 2 amp I cant remember but they didnt do anything ... but I haven't tried my variable voltage test yet either ...
    So i'm looking for some advice on how to do this so I don't have to keep guessing.
    Thanks,
    Mike
    sigpic
  • petehall347
    • Jan 2015
    • 4426
    Re: How do I determine a fuse that I need for a circuit?
    ultra fast very expensive fuses will do it .. or simply make it fool proof then make certain a fool cant break the fuse .
      One simple method is to put diode's cathode on the (+) and Anode on the (-) of the charger then put a fuse (must be higher current rating than the charging curent) than the between Cathode (output of the charger) and the (+) of the battery.
      When you put the battery in backward, the diode will crowbar the battery so the fuse will blow which will disconnect the output from the battery that is put in reversed into the charger. Diode can be 5A or more, it will just conduct long enough to blow the fuse, but if the battery has really low Voltage the fuse may not blow.
      There are more than one way of handling the situation:
      https://www.maximintegrated.com/en/a...ex.mvp/id/4572
      Not sure if some of the circuits has been verified or not if the battery has really low Voltage.
      http://blog.deconinck.info/post/2017...ity-protection
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        I wonder if a PTC thermistor would slow down charge rate enough or fast enough to protect the charger?
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          No. I don't think so. The best bet is as budm suggests with the diode across.
          • EasyGoing1
            Shock Therapist
            • Sep 2016
            • 977
            So I decided to play a little, and I used an INA3221 that has a voltage input (which in this case would be the battery being charged) then on the monitoring terminals, I connected the output of the charger ... it's a nice chip because when the battery is plugged in properly and is being charged, the INA3221 will give me the current flowing to the battery plus the shunt voltage, which is actually the voltage that the charger has to elevate its output to in order to reach its programmed current (which is about 1 amp) but it will also give you the load voltage which is the voltage of the battery ... I don't know how it does, unless it disconnects very rapidly to read the battery's voltage then reconnects ... the load voltage and the source voltage (both are technically the battery) only differ by .01V which is more than acceptable in terms of margin of error ...
            So anyways ... I wrote a java program that received data from arduino at a fairly rapid rate ... something like 20 reads a second ... and logged it to disk then I put a 5k pot in series with the monitoring terminal and the battery connected backwards and slowly turned down the pot until the chip fried (the chip on the charge circuit) ... heres the data that is relevant:
            Code:
            Current	  Shunt V
            127.6 mA	864 mV
            128.2 mA	856 mV
            136.3 mA	941.3 mV
            144.8 mA	1,008 mV
            151.5 mA	994.7 mV
            165.0 mA	1,136 mV
            175.8 mA	1,205.3 mV
            190.4 mA	1,309.3 mV
            192.3 mA	1,306.7 mV
            208.0 mA	1,466.7 mV
            221.1 mA	1,445.3 mV
            218.5 mA	1,496 mV
            226.8 mA	1,437.3 mV
            222.6 mA	1,584 mV
            216.6 mA	1,301.3 mV
            189.0 mA	1,264 mV
            177.7 mA	1,122.7 mV
            173.8 mA	1,173.3 mV
            192.7 mA	1,400 mV
            218.3 mA	1,536 mV
            184.7 mA	1,136 mV
            169.3 mA	1,138.7 mV
            171.8 mA	1,149.3 mV
            181.9 mA	1,245.3 mV
            198.1 mA	1,304 mV
            203.9 mA	1,418.7 mV
            212.8 mA	1,429.3 mV
            209.3 mA	1,333.3 mV
            201.4 mA	1,346.7 mV
            206.6 mA	1,386.7 mV
            195.1 mA	1,304 mV
            205.2 mA	1,437.3 mV
            211.6 mA	1,370.7 mV
            218.6 mA	1,458.7 mV
            221.8 mA	1,490.7 mV
            206.5 mA	1,373.3 mV
            205.4 mA	1,362.7 mV
            209.3 mA	1,410.7 mV
            214.2 mA	1,416 mV
            213.9 mA	1,426.7 mV
            236.5 mA	1,629.3 mV
            252.0 mA	1,762.7 mV
            265.8 mA	1,813.3 mV
            273.7 mA	1,904 mV
            289.8 mA	1,936 mV
            284.1 mA	1,930.7 mV
            264.0 mA	1,784 mV
            275.3 mA	1,912 mV
            290.7 mA	1,962.7 mV
            299.4 mA	1,997.3 mV
            296.7 mA	1,965.3 mV
            302.8 mA	2,104 mV
            307.7 mA	2,002.7 mV
            285.4 mA	1,858.7 mV
            237.3 mA	1,373.3 mV
            203.3 mA	1,368 mV
            215.3 mA	1,402.7 mV
            212.7 mA	1,474.7 mV
            221.6 mA	1,546.7 mV
            223.5 mA	1,442.7 mV
            210.7 mA	1,378.7 mV
            212.9 mA	1,381.3 mV
            214.2 mA	1,496 mV
            253.2 mA	1,816 mV
            276.1 mA	1,938.7 mV
            292.3 mA	1,938.7 mV
            312.3 mA	2,197.3 mV
            340.9 mA	2,317.3 mV
            388.2 mA	2,744 mV
            448.4 mA	3,176 mV
            507.0 mA	3,520 mV
            1,063 mA	10,920 mV <---Fried
            1,638 mA	10,920 mV
            1,638 mA	10,920 mV
            1,638 mA	10,920 mV
            1,638 mA	10,920 mV
            1,638 mA	10,920 mV
            1,638 mA	10,920 mV
            1,638 mA	10,920 mV
            1,638 mA	1,0920 mV
            sigpic
            • EasyGoing1
              Shock Therapist
              • Sep 2016
              • 977
              Anyways, it looks like the chip will fry at 1.6 amps ... the most amps that it will throw out to a battery that it's charging is 1 amp ... so my fuse selection is going to have to be fairly precise so that it only blows when the current is about 1.1 or 1.2 amps but not 1.5 or 1.6 obviously ... does such a fuse exist or am I S.O.L.???
              sigpic
              • petehall347
                • Jan 2015
                • 4426
                take your pick ...https://www.google.co.uk/search?sour....0.c9zjrXuVtXw
                • EasyGoing1
                  Shock Therapist
                  • Sep 2016
                  • 977
                  take your pick ...
                  So the voltage rating of the fuse makes no difference at all in the results? They are strictly current sensing and a higher voltage fuse wont inadvertently NOT break at voltages this low?
                  sigpic
                  • EasyGoing1
                    Shock Therapist
                    • Sep 2016
                    • 977
                    Looking at resettable fuses ... the datasheets seem to indicate that it takes several SECONDS before the fuse trips ... are there extremely fast acting resettable fuses available?
                    sigpic
                    • R_J
                      • Jun 2012
                      • 9535
                      Basically the voltage rating is so when the fuse does fail and open it will not continue to conduct or arc across the blown elements of the fuse
                      You can use a 250 volt rated fuse to protect a 12 volt circuit without a problem
                      What about using a low FV diode (shottkey) in between the charger and battery to block the reversing of the battery and protect the charger
                      • EasyGoing1
                        Shock Therapist
                        • Sep 2016
                        • 977
                        I've considered this, but diodes have their own voltage drop, and there is no way for the charger to understand how the voltage is being used that it puts out ... so it technically thinks that the only thing attached to it is a battery but when you add the diode, then its output voltage MINUS the diode is actually being applied to the battery which will slow down the charge time ... although im not sure by how long ... I suppose its worth a test..
                        Then again ... if the chip is in cc mode, then it SHOULD up the voltage until the desired current is reached and at that point, it should push harder to compensate for the diode ... but when it switches to the end of the charge cycle, it goes into CV mode ... and THAT would slow down the charge time ... but again ... still worth a test I suppose ...
                        Which diodes have the smallest voltage drop? I remember .7 volts being the standard back when I took electronics, but im sure they have new stuff these days, no?
                        sigpic
                          Putting the diode is series with the output will not protect the IC when battery is put in backward, the diode will be forward bias by the battery! read the links I provided.
                          • EasyGoing1
                            Shock Therapist
                            • Sep 2016
                            • 977
                            OK, I tried all of the diodes that I have, and most of them wouldn't even allow the charger to kick in and charge the battery ... a couple of them did let the charger start charging, but without a diode, it would be charging at 800mA and with the diode, it would only charge at like 200mA ... so thats a no go ... at least for these diodes.
                            sigpic
                            • EasyGoing1
                              Shock Therapist
                              • Sep 2016
                              • 977
                              What's the quick answer to "Why would the diode be forward biased?"
                              sigpic
                              • EasyGoing1
                                Shock Therapist
                                • Sep 2016
                                • 977
                                You know whats interesting ... there was a time when I somehow used two MOSFETs and I connected them in such a way that they protected the circuit when the battery was plugged in backwards... the problem with that config (the way I had it anyways) was that when the battery was connected normally and charging ... the MOSFETs got WAY TOO HOT ... so it didn't seem practical ... I didn't take any current readings either. But I thought it was interesting that I was able to protect the circuit with a couple of MOSFETs ... I still have the circuit around here somewhere...
                                sigpic
                                  The negative of the battery will be connected to cathode of the diode, the positive will be connected to GND when battery is put in backward.
                                  BTW, that is how crowbar circuit works, it seems like you did not read the links to learn about the circuits.
                                  May I ask how much understanding you have about diode, MOSFET, transistor, and circuit?
                                    The heat has to do with Voltage drops on the MOSFET and current flowing through the MOSFET, if the MOFET is not fully turned on then its resistance will be at the minimum (mOhm range), simple Ohms law.
                                    • R_J
                                      • Jun 2012
                                      • 9535
                                      I looked at the second link and I see what they are talking about, I guess a diode with a charge circuit will not protect the charger.
                                        The diode in series is a cheap way of protecting the load from wrong battery polarity.
                                        In this case we are dealing with charger.
                                          Surface Mount Fuses Fundamentals Datasheet
                                          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                          10-07-2024, 06:07 AM
                                        • flat-earther
                                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                                          by flat-earther
                                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                          Windows also shows ''Plugged in'' when charger is not connected.
                                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                          If I let battery run out and say it has 3% Windows will...
                                          06-24-2025, 09:32 AM
                                        • corrize
                                          Replacing resistor fuse in Sony DV charger
                                          by corrize
                                          Hello, I have 2 old chargers for Sony DV, and I found the same resistor fuse dead. Fuse is a crossing component : 0,47 Ohms (0,125W deduced because the lenght is 3mm). But I can’t find the same for buy.
                                          So, I want to replace by another like 0 Ohms, 1 Ohms 0,125W,
                                          It is the same please ? I guess it’s the same, the only change should be the time to burn ? Thanks...
                                          06-30-2025, 06:59 PM
                                        • motormayhem
                                          Lenovo T460 Only Charges on One Charger
                                          by motormayhem
                                          Laptop Question
                                          I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                          A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                          05-12-2023, 01:46 PM
                                        • corrize
                                          A funny fuse story – Lumix LX100 II
                                          by corrize
                                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                          10-19-2023, 09:58 AM
