Compatible MOSFET's? HFP50N06? FMU22U?
  • jdbird613
    • Jul 2018
    • 35
    Hello all, I could really use some advice on finding suitable replacements for a couple FETs I'm trying to replace. Does anyone have any info on a compatible replacement for FET DFP50N06? I've been informed that IRF3205 is suitable, but when comparing the data sheet info, the numbers are way off. I also ran across a forum where somebody was going to try to substitute with FET IRFZ44N, but same situation when data sheets are compared. Furthermore, also looking for equivalent for rectifier FMU22U. I found these on ebay, but trying to avoid buying parts from ebay. Trying to stick to Digikey or Mouser. Any and all info & input will be greatly appreciated! THNX in advance!
  • jdbird613
    • Jul 2018
    • 35
    Re: Compatible MOSFET's? HFP50N06? FMU22U?
    Anyone have any suggestions?
      • Jul 2011
      • 6057
      You might be able to use this
      You do need to look at both data sheet to be sure
      https://www.mouser.com/ProductDetail...SAAEgJjKvD_BwE
      If I was looking for this
      https://www.ebay.com/itm/16pcs-FQP50...sid=m570.l1313
      I would recommend this this seller because of there rating
      I have from time to time I have had to order electronic parts like this and so far so good
      I always look at the feedback ( Neutral / Negative ) for pattern of problems with a particular seller this has worked for me
      You can find this FMU22U here
      https://www.littlediode.com/components/FMU22U.html
      I have ordered parts for them before they do respond to your email
      I have had no problems with them
      Just a thought
      • BlackScreen_22
        Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
        by BlackScreen_22
        Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
        Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
        I had no problems connecting mosfets and capacitors,...
        08-27-2024, 12:46 PM
      • kotel studios
        Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
        by kotel studios
        Finally got time to fix this board up.
        At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
        Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
        04-22-2025, 05:08 AM
      • flerre
        Gainward Phantom GTX 980 - mosfets w/ integrated driver NCP5369
        by flerre
        Hi!
        Managed to get a Gainward Phantom GTX 980 in an auction for a bin with components.
        No video out so I started fault finding and found a blown fuse for 3 mosfets. Started checking for shorts and found what I think is a short through all of those 3 mosfets; 0.1 ohms between "VIN" input and "VSWH" output. All mosfets in this gpu are the same ones (NCP5369) with integrated drivers and when I tried measuring the other ones through these ports they were somewhere in the kilo-ohms range.
        So, could I safely assume all of these 3 mosfets are...
        03-13-2022, 12:14 PM
      • прямо
        Help me decide which MOSFETs are suitable replacements
        by прямо
        Friends,
        I need help. I'm having a bit of difficulty in deciding what would be the compatible replacement for these MagnaChip N-Channel Trench MOSFETs on a VRM circuit because they seem to have a much faster switching times compared to most N-Channel Trench MOSFETs out there that have the same (more or less) current rating and Rds(on)
        MDD1502 (high side), 48.5A 7.8mOhm
        MDD1501 (low side, 2 in parallel), 67A 5.6mOhm
        VGS is 10V High side drain is 12V. Low side drain is from PWM controller (Richtek RT8120A) phase output 1V.
        Here are the ones...
        02-01-2024, 09:06 PM
      • NanoTesting
        Lenovo Ideapad 15IIL05, turns on and off with charger BUT works by injecting 20v after main mosfets
        by NanoTesting
        I got a 15-IIL05 that failed to turn on BUT IT DID TRY TO TURN ON and then turned off after 30+- seconds, i disassembled it and found a screw loose inside the case.
        With charger it turns on, fan spins but gives no image.
        Tested main mosfets no short, tested 3.3v,5v,DRAM, CPU etc and they were present.
        Reflashed BIOS, same problem.
        Replaced both main mosfets.
        Checked main mosfets again and i noticed that they closed once the laptop shut down, so i decided to bypass them and used a bench PSU to check how much power the laptop was drawing while trying to turn on, 20v@3A,...
        10-30-2024, 10:48 PM
