Amplify a signal from an inductive capacitive probe
  • diif
    • Feb 2014
    • 6978
    • England
    I've been handed a Hantek HT-25 inductive capacitive probe. http://hantek.eu/auto-ignition-probe-ht-25.html
    My friend bought it as he has a motorcycle dyno and his old probe for detecting HT pulses failed.
    Not knowing much about circuit design I'm wondering if it's possible an op amp circuit could be used to boost the signal so his current dyno can read the pulses ?
    Any input would be appreciated. Thank you.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8688
    Re: Amplify a signal from an inductive capacitive probe
    Appears to be for an oscilloscope, so it should be just fine to build an op amp circuit.
    Since it's for a scope, probably best to try to maintain a 1MΩ input to the op amp.
    Unfortunately not enough info about what the expected output voltage should be, so no design guidelines available other than the input impedance.
    If you have a scope, then this would make it easier to design a circuit... and also knowing what the target device/output requirements are is the other problem.
    • Bill122a
      • Dec 2013
      OP AMPS gain is set by the ratio of the feedback resistor and the input resistor from the output to the negative input.I suggest an npn transistor instead. you need two stages to avoid inverting the ignition spike
      • Bill122a
        • Dec 2013
        Try using a regular scope probe, holding it against the plug wire insulation, tape the probe tip and place it near the plug coil or wire for loose coupling. ITs no tcalibrated but it will show a fouled plug
          • 30963
          hantek only makes one scope for a car - download the manual for the input range.
          • diif
            • Feb 2014
            • 6978
            • England
            I spoke to the guy last night, his custom dyno machine has 5v on the plug connector. He was saying he's like the signal to be as close to the 5v as possible taking into account loss. He also said when he did a quick test with the probe on a bike with his oscilloscope it was showing "a blip one square high, 50mV ?" he was a little under the influence but it's not very big.
            This circuit is just required to amplify the signal so the pulse can be picked up by the dyno for timing, the specific value of the voltage is not important.
            Thanks for your interest so far.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8688
              Losses aren't that big if you're using copper wire since the current is very low. If it's 50mV and you need 5V P-P then you need ~100x gain (probably a bit less than this is still okay), so it shouldn't be too difficult to build an op amp circuit with this gain.
                • 30963
                feed the opamp into a schmitt triggered buffer like a 74ls14 - that will give you a clean 5v squarewave.
                • redwire
                  • Dec 2010
                  • 3900
                  The Hantek probe is linear with 1000:1 attenuation, so 1V/kV into a scope. Not sure if x10 or x1 1MEG scope.
                  If you just need a trigger pulse, I think you already have a few volts of signal (kV) at low current, enough to turn on a transistor or Schmitt trigger gate or 555 timer.
                  A problem is ignition firing voltages are full of ringing and RFI, they are not a nice pulse by any means. So you need some filtering.
                  Some ideas here: http://www.sportdevices.com/rpm_readings/index.htm
                  • perfm2
                    Wson8 spring pin probe WORKS
                    by perfm2
                    I couldn't find anywhere on the internet where someone had discussed actually using one of these newer wson8 probes for flashing your Wson8 BIOS chip without removing it from the MB.
                    I recently ordered one to give it a shot and it actually worked quite well.
                    The tricky part is obviously keeping the probe pins in place on the exposed Wson8 pads of the MB while reading/writing.
                    I used a larger binder clip attached to the top of the probe to create a large flat surface, then added about 1lb of weight to it.
                    This aided greatly in allowing the probe to stay in place...
                    03-30-2023, 11:19 AM
                  • Jane
                    How do you test MOSFET in laptops ?
                    by Jane
                    I tried to use this method:
                    Testing an N-channel MOSFET:
                    Step 1: Discharge the Gate (turn off the MOSFET)
                    Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                    Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                    Step 2: Charge the Gate (turn on the MOSFET)
                    Now, place the red probe on the Gate (G) and the black probe on the
                    09-27-2024, 03:31 AM
                  • Wolf1977
                    capacitive capacitor paralle with 24 volt dc
                    by Wolf1977
                    hi to all
                    in an inverter for motor
                    on input output modul has power supply 24 volt dc is coming from a electrolytic capacitor of main power supply of inverter modul
                    parallel has an capacitive smd capacitor that is shunt
                    i want to ask
                    first what is the play of this capacitor
                    and what value and voltage do you think must i use for that
                    09-01-2023, 02:46 PM
                  • Askic
                    Probe point corrosion -Macbook repair
                    by Askic
                    Hello guys,
                    I'm learning about logic board (motherboards) repairs. I don't do repairs professionally, but I manage from time to time to repair something for my family and friends.
                    What caught my attention is this visual inspection guide written by Louis Rossmann. It seems that corosion on probe points on the motherboard can "kill" Macbook. https://wiki2.rossmanngroup.com/inde...ual_inspection
                    I wonder how corrosion cause this. If there is a track that has a probe point made on it and corrosion is build up on that place, does this means...
                    01-31-2021, 10:46 AM
                  • JimBanville
                    MOSFET mystery
                    by JimBanville
                    N channel mosfets testing as P type?
                    Working on a smps.
                    Using Fluke 115. Red probe in red socket. Black probe in black/common socket. Meter set to diode mode.
                    Removed a pair of mosfets marked 1L02AB FDP
                    26N40 from the circuit.
                    The pair of Mosfets are still screwed to the single heatsink. Mosfet printing facing me.
                    I did the test where I short the left and center pins. I put black probe on right pin and red probe on center pin. I get OL. While keeping black probe on right pin, I put red probe on left pin and get OL. After a few seconds I move red...
                    09-14-2023, 04:22 PM
