What amp smt fuse is ???
  • Bobdee
    • Jun 2008
    • 461
    Hello
    Can you help please, I have a fuse to replace but I do not know what Amp it is,
    Its from a proview 780 monitor lcd, Its at DC input socket and has input of 12v 4A.
    It is stamped FT on it, can you help me out please.
    bob
  • PlainBill
    • Feb 2009
    • 7034
    Re: What amp smt fuse is ???
    Something doesn't add up. According to some information I found, FT would be a .5 Amp time delay fuse. However, that doesn't make sense for the input fuse on an LCD monitor. I'd expect a 3 - 5 Amp fuse.
    PlainBill
    • Toasty
      • Jul 2007
      • 4171
      It sounds like it's the same as the Pico fuses Bill. Not the main fuse, but on the output side or in-circuit protection. 500 mA would sound right. I'd put an ammeter on it and if it's working correctly, choose an appropriate value from that.
      Pics of board where it was and the device with size relationship help.
      veritas odium parit
      • Bobdee
        • Jun 2008
        • 461
        Hello PlainBill & Toasty
        Sorry cant post picture (dont know how)
        I have 4 Proveiw 780,s with same fuse so they are standard in this monitor,
        This fuse is the first component off the DC connector,then from fuse to a 30v power trench mosfet,
        and another unidentified IC.
        I have done one on a HP F1703 Monitor that was 6.5 Amp
        Size of fuse = 3 x 1.5 x 1.5 mm, ( Approx ) its makeup is clear resin with what look like a metal running through it
        By the way HAPPY BIRTHDAY PlainBill
        bob
        • Toasty
          • Jul 2007
          • 4171
          Pictures -
          -Dump them from your cam into a folder of your creation in My Documents
          -run them through any picture modification software you might have (Photoshop etc.)
          -use the Manage Attachments button under Additional Options when you reply or make a new post
          -click on the Browse button in the pop-up window to go to the folder on your computer where you put them
          -select the file and click the Open button
          -repeat above 2 steps for each additional photo
          -now click Upload button
          -VoilĂ ! You picture now appears as an attachment
          -files need to be less than about 190kb in size
          Toast
          veritas odium parit
          • PlainBill
            • Feb 2009
            • 7034
            bob
            That sounds exactly like the Littlefuse SMD fuse I replaced on an inverter. I checked one of Littlefuse's datasheets on their fuse line and didn't find FT listed. Which means either you got the letter code wrong, I didn't read the datasheet correctly, or Littlefuse didn't make that fuse.
            OK, we can eliminate one possibility. I double checked with Littlefuse's site and they do not have a SMD fuse with a FT marking. I also established that Cooper-Bussmann doesn't.
            PlainBill
              by momaka
              03-15-2023, 10:17 PM
            • keepread
              Dell monitor PSU vs Dell laptop PSU
              by keepread
              Hi there!
              Someone gave me their old monitor, it's Dell S2715ht.
              The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
              Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
              10-30-2025, 04:45 PM
            • wattage
              AOC AG493UCX 49-inch monitor - Firmware request
              by wattage
              Hello Badcaps Community,
              The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
              07-13-2025, 04:41 PM
            • ant3202
              HP 27es - LED monitor - Monitor Flashing On - Off
              by ant3202
              Hi Everyone
              Lately I am experiencing the deja-vu incident on one of the led monitor like this.
              https://www.badcaps.net/forum/troubl...lashing-on-off
              The monitor is HP 27es LED Monitor
              https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
              The monitor will randomly blackout and display no signal and will recover again.
              Sometimes need to power and off again to restore the display but...
              03-20-2025, 07:30 PM
            • Rick_1234
              LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
              by Rick_1234
              Good evening, gentlemen.
              I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
              To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
              https://drive.google.com/file/d/1L6S...ew?usp=sharing
              Things I tried
              - Bought a new AC adapter thinking that was the problem but the problem...
              06-22-2024, 04:44 PM
