Component Identification
  • lordshade
    • Jun 2011
    • 9
    Hello guys,
    Recently a friend of mine had an issue with his air conditioning unit and he brought me this board to see if I can make it work again. The board had a nasty encounter with water while it was powered up and as you can imagine, some things shorted out.
    After the initial checkup, besides other things, I have found what it looks like an LC circuit but it seems like the inductor is encased in glass. I'm not sure if that is an inductor or not, I've tested it with a multimeter and doesn't show any readings.
    So, my question is: What is that thing, is it normal not to show any readings, and if it's bad what replacement should I get ?
    Thanks alot.
    Re: Component Identification
    That is Surge Arrestor/suppressor (SA, Gas discharge type), it should show open circuit. It is not need for the circuit to function.
    BTW, did you remove that Common mode choke?
    What Voltage testing have you done so far?
    • lordshade
      • Jun 2011
      • 9
      Yeah I temporary removed it and that relay on the left side to make a clearing so I can work in peace.
      Haven't managed to do any voltage readings yet, the board was too damaged.
      I have to replace a coupe of SMD optocouplers PC1 and PC2 in the first picture next to the 3 diodes as they had 2 legs coroded clean off, also a couple of 470k and 68k burned out smd resistors, and redo a big circuit trace and check on many others especially under large components.
        • 31283
        bad tracks, clear in the foto.
        • Techie_hobby1
          Help please with identification of few components for troubleshooting (Solar Water Fountain circuit)
          by Techie_hobby1
          Need some help please with a few components on this small board so that I can troubleshoot the circuit.
          The PCB is a Single sided board fairly simple circuitry has a +ve and -ve Solar cell power input, a 7.4v 1500mAh (dual 18630 cell) power in which the Solar panel charges the cells, and lastly the Output goes to a DC connector...
          J1 is actually 1P1T Switch (in ON position completes Battery cell circuit
          J2 - to DC Output
          J3 is Battery cell connector
          however I am struggling to identify if:
          Y1 (SOT-23) are NPN Transistors, MOSFET's or 11v Zener's....
          07-24-2025, 12:43 PM
        • grimacelord
          by grimacelord
          Hello. I am working on a circuit board that is part of a motorized HDTV lift. The circuit board belongs to the controller component that tells the motor to either raise or lower the HDTV height.
          The controller started sparking when the 29V power supply was attached and the green light on the power supply would go out as soon as it was plugged into the controller board. This indicated a shorted component and I was able to identify which component it is that is causing the short. When I remove this component, the short is cleared.
          The problem is finding a replacement component....
          06-10-2025, 02:00 PM
          Corsair CX750M [Model 75-002019] - burned output toroid inductor
          by momaka
          Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
          So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
          09-19-2021, 08:44 PM
        • olliec420
          Nvidia Tesla P40 (Q0V80A) Enterprise GPU, I put the power cable on backwards.
          by olliec420
          Ok I screwed up big time and hoping I can fix. I will break down what happened and the images.
          • Have Dell PowerEdge R730
          • Bought Tesla P40
          • Researched power cables and order correct one, pic had two black connectors in photos
          • Power cable arrived, same connectors (EPS-12v) on both ends
            Both sides are the same plug but different colors. The listing stated that colors would be random. OK I plug it in, red side to riser board, black side to GPU.
          • Power on.
          • System immediately turns off.
          • I only had 1 PSU plugged in and it was blinking orange, I thought I drew too much so I plugged in
          02-11-2025, 07:29 PM
        • tvguy12012012120
          by tvguy12012012120
          02-07-2025, 05:13 PM
