Forget tin whiskers, now there's .. plastic whiskers?
  • Agent24
    I see dead caps
    • Oct 2007
    • 4913
    • New Zealand
    I'm troubleshooting one of my oscilloscopes which has lost its trace. Since the PSU seems OK and the front panel LEDs still light, the buttons still switch the relays etc, I'm guessing it's in the CRT section.
    I have begun performing visual inspections, and while looking around the neck board I noticed a trimpot which seems to have started growing white crystals - out of the plastic!
    I also noticed these to a lesser extent, on the main power switch body and the case of what seems to be some part (as yet unidentified) in the mains filtering circuit.
    Has anyone seen anything like this before? I assume it's some breakdown of the plastic due to contamination or incorrect manufacture. I don't think it's environmental, only those three parts seem affected. Another trimpot on the neck-board looks totally normal.
    Interestingly enough, this crystallised trimpot is part of a circuit which seems(?) associated with the cathode voltage (the schematic is labelled in French) - so maybe it has failed and is the cause of the fault?
    -David VanHorn
    • 30931
    Re: Forget tin whiskers, now there's .. plastic whiskers?
    someone posted this issue on eevblog just a few days ago.
    nobody knows if it's from the plastic, or just attracted to it.
    scoop a bit up and put the meter probes in it - check resistance and capacitance.
    be interesting to see if it can actually conduct!!
    • R_J
      • 9515
      I suspect there is a fairly high voltage on that control, and it is caused from the enviroment it was in. Just like dust on high voltage controls etc. but this is white, maybe from a salty humid enviroment. Have you always had this scope or was it bought used from somewhere?
      • Agent24
        I see dead caps
        • Oct 2007
        • 4913
        • New Zealand
        Salt crystal build-up is probably a good explanation, actually.
        The oscilloscope was inherited, I don't know its history before I ended up with it. But I can say it probably spent most of its life in Australia, and if so, it also most likely resided in a coastal area for some time. Some of the shielding metal is also rather rusty.
        The trimpot sits between the 110v and 5v rail, with the wiper going off to the cathode (KAT) through a diode and capacitor. Through another diode it connects to G1 which they have called "WHE".
        The other trimpot is between a 58v rail and ground, with the wiper feeding the base of a translator which seems to adjust G4 and G5.
        I'll see if I can poke around with the crystals a bit...
        -David VanHorn
        • R_J
          • 9515
          With high voltage in the area any moisture evaprorates and leaves behind the mineral. Does the heater light up in the neck of the tube?
          • Agent24
            I see dead caps
            • Oct 2007
            • 4913
            • New Zealand
            Yes, the heater lights, although it is quite bright for a second at power on. They are powering it from an unregulated winding in the main SMPS, so maybe it's 'normal' before the SMPS stabilises. Seems like a bad idea though.
            Ignore the unplugged wire in the photo. I had unplugged it due to reading a rectifier diode as shorted, but it was just due to the heater resistance in parallel through the transformer winding.
            -David VanHorn
            • Agent24
              I see dead caps
              • Oct 2007
              • 4913
              • New Zealand
              http://www.eevblog.com/forum/chat/wh...783/#msg163783
              Same thing (maybe) but probably no high voltage there to cause electrostatic attraction?
              -David VanHorn
              • R_J
                • 9515
                Similar to this I think https://www.wired.com/2012/04/snowfl...owing-machine/
                • petehall347
                  • Jan 2015
                  • 4423
                  • United Kingdom
                  looks like its growing from inside .have seen similar to this before .
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                  • corrize
                    Desoldering - soldering BGA chip close plastic mini fpc connectors ?
                    by corrize
                    Hello, I need your advise please ? I need to remove and replace the BGA black chip with fpc connectors around. The PCB is small, from camera.
                    There is no plastic component directly under, on the other face, (only fuse and oscillator I can remove if they are sensitives to heat), but there is a lot of very small smd components I don't want to desolder by mistake.
                    I have :
                    - hot air, and a
                    ll stuff around
                    - true kapton tape
                    - 140 and 180 degree soldering paste
                    - bismuth
                    - little hot plate 250 degree max
                    - the new BGA chip with probably
                    05-20-2025, 01:26 AM
                  • corrize
                    Soldering plastic low profile FPC close camera CMOS sensor ?
                    by corrize
                    Hello, I will have to solder a very small FPC connector (pins : 0.3mm), on the pcb of CMOS sensor, it is very close. I was surprised by movie on ytb, someone soldering directly with hot air directly on the sensor without kapton, nothing.
                    CMOS sensor seems resist to high temps.
                    But I also directly saw sensor broken because a blocked motor at the corner became very hot and probably bent the metal frame and cracked the sensor.
                    I have low melting point solder.
                    I will probably test hot air directly on one of plastic connector (I have a lot) at 320 degree on a test
                    07-12-2024, 02:21 PM
                  • geo86
                    Plastic stand offs for backlight diffuser
                    by geo86
                    Does anyone know where to buy plastic stand offs for backlight diffuser, mainly for Vestel TVs?
                    They are extremely brittle and almost always they break into pieces.
                    I looked on internet but little success.
                    Thank you!...
                    08-22-2022, 12:40 AM
                  • RolandVossen
                    How do I remove a plastic split washer from a VHS VCR ?
                    by RolandVossen
                    I am trying to repair a JVC HR-D530E VHS recorder, the cassette does not eject. I discovered that the rubber belt of the loading motor is slipping, so I'd like to replace it. I think I have to remove the (nylon?) washers at each end of the worm axel, labeled '2' in the photo. I tried using a small screwdriver and a pair of tweezers, but to no avail.
                    Is there perhaps a special tool or a trick required to remove these ?
                    Thanks in advance, Roland.
                    12-30-2023, 07:48 AM
