LED strip tester. Make or buy ?
    Good day folks. So perhaps one of the most common issue we repairmen encounter is dead backlight LEDs, so naturally tools have been invented to make our life easier by speeding up the process of finding the dead ones, especially in large panels. This of course leads to the age-old question: how would one go about building one of these themselves ? These little cheapy, plastiky, nasty looking boxes are pretty expensive and although it would be handy to have one, it would sure be a lot more convenient and DIY to....well.....DIY
    There doesn't seem to much to them the way I see it at least. I imagine an adjustable constant current source, since that's how LEDs are normally driven in backlights (except in this case we have to adjust the current to drive various types of strips, since some may have more/less LEDs, requiring a different current).
    Perhaps adapting a pre-existing supply like a power brick or an actual TV PSU might be easier than trying to start from absolute scratch.
    How's THIS look ? Of course it's nothing fancy: plenty of people have discussed this before. The point is not so much building the tool itself, since I'm fine with testing LED by LED the way I'm doing now with a 5v adapter and limit resistor, but it would be a learning experience, plus it would still come in handy in practice since it would allow me to power up the whole strip at once. I'm aware that if there's a dead LED somewhere the strip wouldn't light up at all and I'd still have to test LED by LED to find it, but if the LED failed shorted, THAT'S when I'd instantly see it, since the rest of them would still come on.
    Any thoughts ? Perhaps someone has already made one or has suggestions Cheers and thanks.
    Wattevah...
    Re: LED strip tester. Make or buy ?
    The one I bought is only $30, its output can go up to 300V for testing LED string with high Vf. I cannot make one for $30.
    https://www.ebay.com/itm/0-315V-TV-L.../201713742817?
      Would be nice if they had one with adjustable current
        That's not exactly cheap, that's why I was asking That's a good point: can you make something of comparable performance for the same or less money ? Probably not.
        Wattevah...
          One separation transformer,or may use two identical back to back connected,bridge rectifier,LR8K4,or more via multi-position switch,volt amp meter 300v
          Result is much better than this one.
          You may also use some universal TV power supply to get 300V in place of transformer.
          You can also use more LR8K4 set to 10mA and test at 10-20-30-... mA
          But still problem may exist.
          On my build only 10 20 and 30mA encountered two problems until now.
          All led light up and seems OK all in series and one by one but still on TV doesn't work.
          One led was bad, tested with power source and resistor ,over 100mA led was off.
          Another one same result all was OK on tester but at high current led was blinking
          I plan to extend my tester to more than 100mA for better results.
            LR8K4 looks identical to an LM317, just with a greater input range. Current limit of only 20mA would mean having to parallel several of them to go higher than that. How much current does a typical LED strip take anyway ? I've yet to measure that, I admit, despite having repaired hundreds so far
            Wattevah...
              How much can
              Around 350mA most often encountered in many,so around 1W led.
                Also, with LEDs, current tends to increase as they get hotter, hence why they use CC rather than CV supplies I reckon.
                Wattevah...
                  There are weak points with LED tester due to it does not putting out full drive current, but not different than using meter to check semiconductor device since the meter does not put out enough Voltage or current at the same level as the circuit.
                  LED tester is used as a quick test to know if you have open circuit or to find out if it has shorted LED by reading the Vf on that digital display.
                  When you tester on just one or two LEDs then you will have to make sure that the active element that controls the CC can handle the power dissipation.
                    What do you think about this tester?
                    https://www.aliexpress.com/item/USB-...311.0.0.iuc0EM
                      Looks interesting
                        If it can actually do 300mA then that will be a good tester, I will probably wait for the price to come down.
                          I just measured an LG I got on the bench right now out of curiosity and it's a 139mA CC supply apparently, as it's trying to maintain that even when I short across an entire strip with the meter in current measuring mode. It's got 3 strips with 7 LEDs each. Each LED has a drop of around 2.7v
                          Wattevah...
                            It has always been constant current circuit for driving the LED backlights, nothing new, 139mA is on the low side, most LG drives them around 400mA, adjust the backlights level and see, or put in VIVID mode, Vf will also goes up as more current is forced through the LED as you can see in the graph of the LED.
                              Haven't really put my meter on LED strips before until now, despite having fixed quite a few, so it was mostly out of curiosity, not to report some interesting find.
                              Wattevah...
                                I am surprised it is 139ma. I would think they would be quite dim. But last forever
                                  It must be small screen since it only has 21 LEDs.
                                    Without input signal screen dim on some TV’s
                                    On all received for repair allways modified current on led driver to reduce current to extend life of led’s.
                                    Even so,led’s are pretty hot
                                    First time tested with my fingers,was too hot and I suppose was bad solder by me and heat can’t disipate.
                                    After few tries and same result I removed lens from another led and this one too was too hot.
                                    In some there is metal back plate somehow they keep a lower temp but in some cases led strips are mounted on plastic back plate (cheaper ones or in some Toshiba)
                                    That fails more often.
                                      How do you normally do that ? By increasing the value of the sense resistor ? Haven't done it myself, but I imagine in a CC supply, you can modify either the "reference", let's call it or the feedback.
                                      Wattevah...
                                        That depends on each one.
                                        Schematic and or datasheet of IC used and you can see what to adjust.
                                        Some have resistor in paralel for current sensing,remove one or two ar replace with another value.
                                        On crappy Toshiba,1333 series are four transistors there is need to disable one,removing from board,cut base trace.Result is 25% less current,but almost nothing signifiant on image.
