Re: Making a door chime
well there is obviously widespread pic stealing, they dont even care if it's got a logo or watermark!
			Making a door chime
Then this is intriguing: Why not ask why?
ebay sellers trying to evade something? Widespread picture stealing?Leave a comment:
no, common ebay seller trick is to flip the image.
dont ask why - but it's very common.Leave a comment:
I still get cracked up on that ebay listing... someone got the silkscreen mirrored wrong, ouch. I wonder if they're fire-sale-ing those with bad silkscreen and that's not the real cost of those units...Leave a comment:
Arduino suit can directy be used on some ARM boards - i'v done it.
here's some Links
http://www.stm32duino.com/
http://wiki.stm32duino.com/index.php?title=Blue_Pill
https://www.ebay.co.uk/itm/291693366485
what's good is these boards are faster than Atmega, 4x the flash, real USB,
AND they cost less!!!Leave a comment:
Code that you write in a portable language is... portable!
 (C, python, etc.)
Where you will most encounter problems is when you start using non-portable extensions to a language. Or, support libraries that may be tied to a particular "board" (i.e., there is no portable way to turn on a digital output bit cuz there are no standards governing them).
This is why pseudo-code is a big win -- you express what you want the algorithm to do in a language that is almost real. The parts that are fictional end up being implemented (by you) in whatever way is necessary to fit the microprocessor/microcontroller that you've targeted.
E.g., in my example, upthread, there is no definition for the "set_output()" function, included... because that code sample has no idea of which MCU you'll be using for the actual implementation! Will the "output" be a digital output bit on a port on the MCU? Will that port reside at some particular memory address? Or, some particular I/O address?? Will I need to write a special value -- or series of special values -- to drive the pin HIGH? etc.
By writing the algorithm the way I did, I can "port" it to virtually any processor -- including an IBM PC -- just by changing that non-portable aspect of the code (and using a compiler appropriate for the computer in question).Leave a comment:
You can do a lot with a single bit (on/off) output -- if you have a sufficiently high sample clock. The speaker in the original PC (or, maybe it was the AT?) could be made to "speak" with a little utility called SAY.COM.
Here's a version with a canned (unalterable) message within... (unpack for DOS executable)
[Run it in a sandbox if you fear it]Attached FilesLeave a comment:
Well, that's what the "mapping" issue I was alluding to on the other thread, you'll have to "map" your code to the target architecture which will differ. Arduino was meant as an add-on to Atmel. You'll have to convert it to run it on other chips, and perhaps there are add-ons to other chips that will take Arduino code directly. You could even have to map Arduino to ATTiny directly so you don't use Arduino code, but if mapped carefully it's likely smaller; at the very least that the Arduino "loader/library" adds a bunch of code that wastes space...
It is a bit troubling that microcontroller manufacturers like to differentiate themselves to get people to stick with a particular microcontroller as "vendor lock-in". I ended up learning PIC first to do a project (if you don't count z80 and the likes) but was instantly in love with Atmel after getting it to work for a different project... Probably because I was more used to load-store architectures and actual stack pointers (instead of dedicated stacks) in memory.Leave a comment:
Question: can I use arduino code on chips other than Atmels ? I heard that it is possible somehow. I already have a buzzer project so it would be easier to send that straight to the micro (with the obligatory modifications to do what I want of course) than to struggle with code for a an entirely different micro.....true, as somebody pointed out, that would be part of the learning experience, but I'm too "young" at this to venture that far...at least for now. You can't really learn to drive on a perfectly flat and straight road - true, but it's also not a good idea to try out 5 different cars days after getting your license
My boss wouldn't quite like the idea of me creating a device that says thatYeah, I was thinking the atmel could also be used to play arbitrary tones and not just have to turn on a buzzer -- just use a speaker.
I don't think it has enough memory to PWM a voice sample, maybe if you used an ARM. Now it might be "overkill" for a doorbell, but it having it say:
"SHH! SOMEONE'S AT THE DOOR, QUICK! HIDE IT ALL!!!"
is priceless...
 While some clients may get a little laugh out of it, some might not, so a simple buzzer is OK. I found a way to actually run some power to that door, since I personally don't like batteries all that much to begin with - shoot me
 My colleague is more vexed with micros and has played around with Attiny before so I might ask him to lend me a helping hand...After all, all it needs is a buzzer and a reed or even mechanical switch.
is priceless...Leave a comment:
funny you should say that,
i have code to play tunes or even a short sound-sample from an atmel tiny-series.
also, for a couple of € on ebay -Attached FilesLeave a comment:
There are innumerable small MCUs that will tackle any of these jobs. It boils down to a matter of personal preference. Most folks start using "Brand X" and find themselves using it over and over again -- for no real reason (other than the fact that Brand X and Brand Y are practically equivalent in terms of price/performance... it's a commodity market!)The human doorbell would require payment, plus we already do that ourselves and would like a day off every now and then
The idea was to use parts from my junk box, but on a serious note: an Attiny perhaps ? I'm not vexed in micros so I know they CAN be used, but don't know WHICH to use for the job...I'll just use my Arduino Mega then
"Familiarity" drives these decisions. What components are you used to using, what tools do you have available, what parts do you have in stock, etc. I used to rely heavily on 74163's when doing MSI designs even when I just needed a latch (i.e., not a counter) -- instead of specifying a different component that was just a latch! Being a fully synchronous part made it easier for me to use without having to gate clocks, or synthesize multiphasic control signals. Folks looking at my designs would scratch their heads wondering why the "counters never counted" <frown>
It's only when you get to pinching pennies -- or, operating on the bleeding edge, performance wise -- that the actual device you choose takes on special significance.
Nowadays, there is very little barrier to getting started with most processors. Tools are virtually free, development boards are inexpensive, etc. You don't have to purchase a "development system", PROM programmer, In-Circuit Emulator, assembler/linker/compiler, etc. Indeed, you can even simulate your code on a desktop PC without having any "real" hardware available!
The ATtiny family, some of the smaller PICs, etc. are all good fits. You just decide which you want to play with or already have on hand! I've used small MCUs as "slave processors" in some designs to offload certain well-defined aspects of the application from the "master processor" (iff there is a clean semantic interface between them)
IME, its good to play with different components so you are coerced into trying different approaches to problems -- you discover that component Y doesn't have a capability that component X had and you are forced to come up with an alternative, equivalent way of doing something.
Part of the fun is figuring out what you didn't need in a design and using that knowledge to optimize your next one!
Do chase down the Signetics docs on the 555 (556/558/559) if you're interested in them. You would be amazed at the number of interesting applications that folks have created for that venerable part! (And, the folks at Signetics were notorious for their sense of humor so expect some interesting Easter Eggs along the way)
Time to go count falling stars...Leave a comment:
The human doorbell would require payment, plus we already do that ourselves and would like a day off every now and thenBy the same token, isn't a 555 overkill? Using electronics to electromagnetically move a diaphram to recreate the vibrations that a metallic object creates when struck?
How about hiring someone to stand by the door and go "ring-a-ling-a-ling" when folks come in? That has the added advantage of being a unique solution -- one that can be customized on-the-fly (heck, it could even ANNOUNCE the identities of your visitors!!)
[One gets the impression that you're just trying to find a use for a 555]
[One gets the impression that you're just trying to find a use for a 555]Leave a comment:
Why the obsession with 555's? You can use a microcontroller in the same physical space with thousands of times more capability/flexibility. (about all the 555 offers is more source/sink current capability on the output pin -- something you can add to an MCU with a discrete transistor/FET). Time spent fiddling with an archaic 555 would be more fruitfully spent playing with MCU's. And, once you've mastered that, you'll be at the doorstep of writing VHDL/Verilog to design FPGA's, etc.Good day folks. This may seem like something totally stupid and pointless, but I want to make one of those chimes which emit a fairly loud sound when someone opens the door to let me know someone has walked in
 Of course you can just buy one of these, but that's beside the point.
I'm thinking of the humble 555 again and sure enough, I found something which is fairly close: THIS. I'd like it to beep 5-6 times in rapid succession at a high pitch (2000Hz or so) then stop (how these chimes typically work). To achieve this, I may need TWO 555s: one to generate the ringing (which is illustrated in the article) and another to handle the 1-2 second countdown in which the thing is allowed to beep, then cut its power so to say. A N/O reed switch in alarm systems will detect the door's closure/opening: when the door is closed, so is the switch and the circuit is disabled. When the door opens, so does the reed switch, which triggers a fast sequence of beeps then stops - that would be the operating principle.
I HAVE built a 555 countdown timer for another project so I know that works, but I was wondering if someone had any better ideas to cut down the part count even more. 2 555s seem a bit overkill.
(OTOH, if you're fixated on the 555, Signetics has some excellent databooks that are oriented exclusively on 555 applications -- which are numerous and varied!)
[As a hardware designer by training -- EE -- I am chagrined at how often I can solve a problem with a bit of code and a 50 cent microcontroller cheaper and more flexibly than a "real" hardware solution!]
Without using any hardware timers (which would impact the range of MCU choices available to you), your application boils down to:
#define BEEP_PERIOD (??)
ASSERT(2*BEEP_PERIOD > 0)
#define BEEP_CYCLES (??)
ASSERT(BEEP_CYCLES > 0)
#define PAUSE_INTERVAL (??)
#define NUMBER_OF_BEEPS (5)
main() {int count = 0;}
while (count++ < NUMBER_OF_BEEPS) {beep(BEEP_PERIOD/2, BEEP_CYCLES);}
delay(PAUSE_INTERVAL);
beep(long halfperiod, long cycles) {do {}set_output(HIGH);} while (cycles--);
delay(halfperiod);
set_output(LOW);
delay(halfperiod);
delay(long time) {while (time--) { /* No-Op */ }}
Compile it with all optimizations off.
Start by picking (in your mind) a nominal beep frequency (e.g., 2KHz). And, a nominal "beep duration" -- say half a second? From this, you can compute the number of BEEP_CYCLES as duration*frequency (e.g., 1000)
Initially, set NUMBER_OF_BEEPS to one to ensure you don't have multiple beeps running together (until we know how to specify the PAUSE_INTERVAL). Then, poke in values for BEEP_PERIOD until you get a beep that is about the right duration (note that this should ensure the beep is about the correct frequency as the two are related by the equation saving you the need to drag out a 'scope to measure the actual frequency!)
Take whatever number you've come up with for BEEP_PERIOD and compute frequency*BEEP_PERIOD to yield a figure roughly representative of "one second". Take that number and use it to derive a PAUSE_INTERVAL figure (e.g., if you want to pause for half a second between beeps, use half of the number you've come up with).
Replace NUMBER_OF_BEEPS with the desired number of beep tones.
You can eliminate much of this "guesswork" if you know the MCU you've targeted (so you know how fast it runs and how expensive its opcodes are) and the code generation characteristics of the compiler you're using (so you know which opcodes it is using to implement each of the above statements).
Power the circuit from the "door is open" switch. The program will just stop when it completes (if the door remains open indefinitely).
Or, if you want to be able to play a long series of beeps initiated by a short duration door switch, poll a switch to determine when to start the program.
Capacitively couple the drive to the speaker to remove the possibility of DC sitting on the coil.Leave a comment:
That would work, though it's not really DIY is it ?
 A micro would make it easy but it's overkill...
			by sam_sam_samI had a lot of trouble with the WiFi connection from my router inside of the house into a ( new ) metal garage I had to run a 150 ft cat6 patch cord so the WIFI connection would be strong enough for the WiFi connection on the garage door opener would work correctly ( my son has a work out area in the garage as well and he was having to put his phone near the door to be able to stream music ) ( so I was going to eventually put WiFi out there anyway )
This garage door opener WiFi is very touchy if you lose the power it does not remember the password for the router which is weird or... -
			by sam_sam_samI have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
			Macbook A1398 - had repeating loop of startup chime with no actual boot. Just startup chime, then restart, start up chime, then restart, etc. I pulled the battery and cleared BIOS. It will now power up, fans on, CPU warming, but no startup chime and no boot. I reflashed the BIOS chip but the same thing happening. Where should I go from here?06-14-2023, 11:45 AM
			by sam_sam_samI was having issues with the controller not always responding to remote control signal having to hold button until garage door started to move
Now after replacing the two capacitors on the two 5 volt power supply rails
One is used for the up/down limit up/down force circuits
Second one is used for the radio receiver circuit
The main filtering capacitor ESR value was a little higher than a new one
https://www.northshorecommercialdoor...yABEgLxlvD_BwE
			by sam_sam_samThis happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
I am comparing them to a brand new one that I installed
The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
I going to let it run for several days before I remount back on the wall next to the... - Loading...
