Is it okay to use 25v rated caps in 24v rail output of SMPS
  • zape
    • Jul 2017
    • 176
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Is it okay to use 25v rated caps in 24v rail output of SMPS
    Nope. Too close to the rated voltage. Get a 35V cap.
    The 24V rail could be 22 to 26 depending on regulation and/or load.
    --- begin sig file ---
    --- end sig file ---
    • zape
      • Jul 2017
      • 176
      I tested it is 24.1v
      Anyway, will order 35v caps then
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        It's better to use higher rated caps.
        Unless the capacitor you use can handle overvoltage.
        Here is an example of a 24VDC PSU with a 25v bulk cap:
        https://www.badcaps.net/forum/showthread.php?t=7413
          • 31278
          the old design rule was 1.5x running voltage,
          so 24x1.5 = 36
          so 35 is pretty much perfect.
          • zape
            • Jul 2017
            • 176
            So when the cap says 25v what exactly does this mean?
            I thought exactly what is says - up to 25v is OK. I would even expect that there is always some room for overvoltage. Why should I divide by 1.5?
            Is this just to make its life longer (the question is then for how much longer?)
            I'm only using top brand caps like Rubycon or Panasonic.
            The cap specs may say 10000 hrs at 105C I guess at it's rated voltage, so why divide by 1.5 then? to make it 11000?
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              It's a general "rule of thumb"
              That's why I gave you the link I did:
              To show that it's possible to do it with 25v caps.
              (If you know what you are doing).
              But in general I would not recommend it.
              I was looking for specs that say how much you can briefly overvolt that UCC KMH capacitor.
              Because I'm quite sure I've seen it somewhere but now I can't find it anymore.
                • 31278
                voltage has ripple, or you wouldnt need the cap.
                the cap must handle the level of ripple.
                how much is that?
                well the common thing is mains.
                it's a 50% duty cycle sine-wave.
                if you rectify it to dc the peak is 1.4x the rated level.
                so that's probably how the 1.5 rule started.
                it's also not wise to run caps or any other part on the limit because it could reduce the lifespan.
                • zape
                  • Jul 2017
                  • 176
                  how much is that?
                  Good point, but when you have the cap in circuit the ripple level is reduced, so there is no more (significant) ripple.
                  • redwire
                    • Dec 2010
                    • 3912
                    You can do the research and you'll find electrolytic capacitor applied voltage (to rated voltage) does not matter much, for quality manufacturers.
                    Electrolytic caps in (linear or SMPS primary) power supplies are subjected to mains tolerances, so voltage moves around and you'd always leave some headroom in the WVDC.
                    UCC Electrolytic Capacitor Technical Notes
                    Shows no difference Graph 5-2, unless larger 350V parts.
                    5-6-1 Overvoltage shows 107% WV has small effect and 114% WV much more on lifetime.
                    Nichicon shows a 35V part (Fig.2-4) at >40V is heading into drama. 2-9-4 Operating at rated voltage has no effect.
                    Cornell Dubilier Aluminum Electrolytic Capacitor Application Guide
                    "...Aluminum electrolytic capacitors [are] made with formation voltages at least 35% higher than rated voltage and with rated temperatures of 85ºC or higher, don't require much voltage derating. In applications operating at less than 45ºC no derating is needed, and with up to 75ºC, 10% is sufficient. For higher temperatures and with high ripple current, 15% or 20% is appropriate. Since operating life continues to increase for further derating, military and space applications use 50% voltage derating."
                    Panasonic alum. electro cap lifetime estimation
                    "...Applied voltage does not influence life time too much if an applied voltage to the aluminum electrolytic capacitor is below 0.9x the rated voltage but can be a factor of sudden failure."
                      • 31278
                      the ripple is only reduced because the cap is doing it!
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        I used my eyes when looking at the datasheet again.
                        It's listed right under the rated voltage.
                        For example a 25v KMH cap is rated for 32v surge voltage...
                        There is an explanation here under "Guidelines for Using Aluminum Electrolytic Capacitors"
                        Surge Voltage
                        The surge voltage rating is the maximum over-voltage including DC, peak AC and transients to which the capacitor may be subjected for short periods of time (not exceeding 30 seconds every 5 minutes). According to JIS C5141, the test shall be conducted for 1000 cycles at room temperature under test condition W of JIS C5141or at the maximum operating temperature under test condition B and C of JIS C5141. Under test, the capacitor shall have voltage applied through a current limiting resistor of 1000 ohms without discharge. After test, the electrical characteristics of the capacitor are specified in JIS C5141.
                          • 31278
                          yesn surge is not ripple, it's not continuous.
                          • Techgeeky
                            • Oct 2017
                            • 15
                            • Turkey
                            35 v or 36 v will be good to go.
                            • madan1
                              DALI SUB E-12F class D, fluctuating power rail
                              by madan1
                              Good day everyone.
                              I have on the bench an amp board from DALI SUB E-12F. It is class D amp with a smps on the same board.
                              The issue is that it powers off way before the rated power is reached (the protection circuit kicks in). It has an independent standby power supply, which stays on after the main power supply is turned off via a relay on the primary side (thus there is no reason to believe that the protection is triggered from the smps IC on the primary side).
                              The normal value of the positive and negative power rails is +/- 43V.
                              The positive rail stays...
                              10-15-2025, 10:33 AM
                            • Nagy Daniel
                              Lowest possible resistance on laptop motherboard rail - Guide Table request
                              by Nagy Daniel
                              Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                              I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                              I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                              So, I generated a table with AI so I can...
                              03-04-2025, 08:24 AM
                            • FrancescoV
                              Onkyo HT-R390 no sound output, video output ok
                              by FrancescoV
                              Good morning everyone,
                              I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                              The firmware reported is the following:
                              M:1.00/11107BLP
                              D:?.??/????????
                              O:1.00/11107AL
                              The DSP firmware given the question marks seems corrupt.
                              On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                              05-11-2025, 02:59 AM
                            • прямо
                              Corsair HX 750W - DC Leakage at 12V Output Rail in Standby Mode
                              by прямо
                              Just received it today from a friend.
                              Auto shutdown by the supervisor IC because of an under voltage condition with 12V output rail (dropped to 10.5V)
                              The same rail also does this when the PSU is in standby mode.
                              https://ibb.co/5TBkg66
                              The leakage keeps climbing at a steady rate but slowing down when it reaches over 800mV or so. I didn't measure exactly at what value it stopped or if it's even stopped at all.
                              What could have caused that?
                              First time I have seen such behavior.
                              3.3V and 5V rails don't have the same...
                              02-19-2024, 09:52 PM
                              by momaka
                              03-15-2023, 10:17 PM
