Missing capacitor ( what will i replace it with )
  • garrymc123
    • Apr 2010
    • 336
    • United Kingdom
    Hi there i have received a disco light power board for repair but someone has been here before me and removed the fuse and a capacitor c3 ive got the fuse no problem but unsure what size or kind of cap it should be there any ideas
    thanks in advance
    Your never to old to learn
  • R_J
    • 9622
    Re: Missing capacitor ( what will i replace it with )
    It is most likely the same as the blue one (c4?) next to it. It should be fine to try without that cap. They are just the x & y capacitors, Looks like C4 goes across the line and C3 goes from line to ground
      +1, it is X/Y safety cap for EMI and it will not affect the operation of the unit.
      • R_J
        • 9622
        My money is on bad U2 that blew the fuse
        • garrymc123
          • Apr 2010
          • 336
          • United Kingdom
          thanks for your reply's how would i test the u2 chip thanks in advance
          • R_J
            • 9622
            Easiest way, put in a fuse, I cant make out the ic number
              Check R17 (1R2) Source pin resistor for that SMPS U2 IC to see if it is still show around 1.2 Ohms.
              Also check resistance between Pin 4 (S) and pin 5/6 (D) of U2 to see if it shows a shorted circuit.
              It is best to get the U2 spec to verify my pin out.
                • 31278
                check the bridge diodes first - because they are the first thing power passes through.
                • garrymc123
                  • Apr 2010
                  • 336
                  • United Kingdom
                  Hi guys thanks for your reply's checked diodes all good at 0.583 one way R17 1.3 ohms and no short between ic at pins 4 to 5/6 t reads 0.559 one way anything else i should check before putting the fuse in and trying it
                    • 31278
                    inline lamp trick?
                    • garrymc123
                      • Apr 2010
                      • 336
                      • United Kingdom
                      Thanks stj.. how is it you do again I've got a fair idea but just want to be sure before I do it. All info is much appreciated. Thanks
                      • chth96
                        Is it no harm to replace with capacitor without ripple current rating?
                        by chth96
                        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                        Rubycon YK DataSheet (b...
                        04-19-2024, 05:19 AM
                      • chth96
                        If I replace with inferior capacitor, Is it No harm to other IC components at all?
                        by chth96
                        I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                        Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                        It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                        So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                        I know that these capacitor will not last as long as nichicon capacitor...
                        12-22-2023, 04:34 AM
                      • chth96
                        Should I replace polymer capacitor?
                        by chth96
                        a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                        I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                        Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                        Is this ESR value of polymer capacitor correct?...
                        11-18-2022, 04:22 AM
                      • MORETTIGIAN
                        Capacitor detached from PCB – RTX 2070 Super Founders Edition
                        by MORETTIGIAN
                        Title:
                        Description:
                        During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                        I did not notice it detaching, so I am unsure of its original location on the PCB.
                        Procedure performed:
                        - Removed backplate
                        - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                        - Reapplied thermal compound
                        - Reassembled card
                        Observed behavior after reassembly:
                        - GPU powers on and operates normally under...
                        09-18-2025, 12:14 PM
                      • benberry24
                        surface go 2 missing capacitor, Motherboard# DA0Z93MBAE0
                        by benberry24
                        I have surface go 2 that a capacitor was nocked off. Can anyone tell me the value of the missing capacitor or if it's needed.
                        Motherboard# DA0Z93MBAE0...
                        09-12-2025, 10:16 AM
