Cooler running resistor
    Not sure of the power draw on a circuit, the resisor specified is a 56 ohm 5 watt, what can I use that is cooler running? The resistor is used as a load on a 12v circuit.
    Re: Cooler running resistor
    A physically larger resistor like a 10 watt resistor will have less temperature rise because of its lager surface area. Or you could attach the 5 watt resistor to a finned heatsink.
    Or use a high resistance if it doesn't cause other problems.
      56 ohms accross 12 volts is about 214 ma of current, so the wattage would be about 2.6 watts.
        Thanks, probably go for a 10w resistor, did think of an aluminium ohmite resistor, think they do a 15w one.
          any wattage resistor will get as hot . use a heat sink to dissipate the heat or install a fan
            Fan not practical, I'll use a heatsink.
              Keep in mind that those finned panel mount resistors are designed to have some sort of heat (like a ........ panel). Without that a 15W resistor might be 5-7 watts or something like that.
              PeteS in CA
                What are you doing? Is this 56 ohm resistor just there to put some load on the 12 volt power supply?
