Not sure of the power draw on a circuit, the resisor specified is a 56 ohm 5 watt, what can I use that is cooler running? The resistor is used as a load on a 12v circuit.
Cooler running resistor
Re: Cooler running resistor
A physically larger resistor like a 10 watt resistor will have less temperature rise because of its lager surface area. Or you could attach the 5 watt resistor to a finned heatsink.
Or use a high resistance if it doesn't cause other problems. -
any wattage resistor will get as hot . use a heat sink to dissipate the heat or install a fanComment
Keep in mind that those finned panel mount resistors are designed to have some sort of heat (like a ........ panel). Without that a 15W resistor might be 5-7 watts or something like that.PeteS in CA
****************************Comment
by mikey5791Hi to all forum members,
Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor... -
I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors... -
by artvandalaiThe resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y3 Photos
by adelfr2009Hello .
I have an HP Victus 15-fb laptop with the DAG3PRMB8D0 motherboard, Ryzen 7 7535HS CPU, and RTX 2050 GPU. I had a short on the 19 V line, and I was forced to replace the following components:
1- 2 nmos near dc jack connector
2- ic charger (88739b) + small resistor between CSIN pin and sense resistor output
3- i changed also a 1 dual mosfet in VRM
After replacing the VRM MOSFETs and the charger IC, the laptop works and the CPU survived 🙏
However, now I have a problem: the laptop is very slow, running only at 0.4 GHz.
After...11-08-2025, 06:48 PM -
by AstonishedHi friends of electronics
What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
Please help me fix this circuit.
(the datasheet of the IC: https://pdf.datasheet.live/28... - Loading...
