Capacitor 22uf vs 20 uf
  • socratez
    • Jun 2017
    • 9
    I bought replacement nichicon capacitors but bought the 20uf 50V instead of the 22uf 50V and the 220uf 25V instead of the 222uf 25V.
    Am I going to have any issues with this?
    Edit- I got the 22uf equivalent but I still could not find the 222uf 25V equivalent.
    Re: Capacitor 22uf vs 20 uf
    Can I see the 20uF and the 222uf caps? Those are odd value caps for today typical value. Typical lytics cap has +/-20% Tolerance.
    • socratez
      • Jun 2017
      • 9
      So here are the caps. Now that I found it out of the trash I realized I misread one of them.
      The smaller cap is the starter cap I believe, it's isolated by itself by the transformer.
        • Jul 2011
        • 6044
        Here are some caps you could use
        This is what I would use
        22uf
        https://www.digikey.com/product-deta...1703-ND/756219
        220uf
        https://www.digikey.com/product-deta...1546-ND/756062
        • socratez
          • Jun 2017
          • 9
          Yep, I've been noticing a trend with the mosfets being a secondary problem after reading some of the posts in here.
          I'm still trying to understand the principles behind testing mosfets using the 'Seconds to Black guide'.
          I'd like to understand the physical reasons why the test are done in the order they are because I learn things easier that way.
          • Prolog
            RTX 3080 FE Identifying capacitor
            by Prolog
            Hi people, I hope this is the correct spot to post this, I'm new to the forum.
            I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
            I hope these photos make it clear which component I am referring to:
            (yes, the soldering is a bit botched from removing the blown one, I know)
            I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
            12-01-2024, 08:27 PM
          • chth96
            If I replace with inferior capacitor, Is it No harm to other IC components at all?
            by chth96
            I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
            Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
            It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
            So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
            I know that these capacitor will not last as long as nichicon capacitor...
            12-22-2023, 04:34 AM
          • chth96
            How can I test non-polarized capacitor?
            by chth96
            I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
            I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
            And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
            I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
            06-02-2024, 07:31 PM
          • chth96
            Is it no harm to replace with capacitor without ripple current rating?
            by chth96
            When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
            Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
            But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
            Rubycon YK DataSheet (b...
            04-19-2024, 05:19 AM
          • chth96
            Should I replace polymer capacitor?
            by chth96
            a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
            I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
            Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
            Is this ESR value of polymer capacitor correct?...
            11-18-2022, 04:22 AM
