Bought myself a clamp amp meter. Am I using it wrong?
  • Pioneerx01
    • Apr 2015
    • 241
    • US
    Bought myself a new Tacklife CM01A Digital Clamp Meter from Amazon. First test is on the bench light I have plugged into an outlet. It has 2x 32W rated CFL tubes in it. Kill-A-Watt meter reads 120V with 0.72A, however my clamp meter only reads 0.34A on AC mode. It was zeroed out before measurement. What am I missing here?
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    Re: Bought myself a clamp amp meter. Am I using it wrong?
    try the other wire .
    is the meter rms ?
    • Pioneerx01
      • Apr 2015
      • 241
      • US
      Other wire is the same thing. The device is listed as True RMS.
      • Pioneerx01
        • Apr 2015
        • 241
        • US
        So I have put the clamp meter on a 500W halogen light with Kill-a-watt as well. Both read 3.6A.
        • PeteS in CA
          • Aug 2005
          • 3579
          • USA, Unsure of Planet
          The halogen light, IIRC, will have a power factor (and a crest factor of 1.414) of ~1. CFLs have a capacitive input: lousy power factor; high crest factor. I suspect one or both of your meters isn't interpreting the complex current waveform correctly.
          PeteS in CA
          • petehall347
            • Jan 2015
            • 4426
            • United Kingdom
            wonder if the home electricity meter can see it ?
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8695
              Home electricity meters will measure true power and not the spiked apparent power. (In fact most of them will measure backwards if you backpower into the grid, but don't do this without authorization.) In the UK/Europe, I heard that PF (real power to apparent power ratio) is a big problem and devices need to have neutral PF 1:1 - meaning you won't see weird readings like this.
              The Kill-A-Watt amps setting is measuring apparent amps, you may need to use the "watts" reading and divide out voltage to get "true" amps and see if it matches on a nonlinear load.
                Look at your kill-a-watt meter Watts display, VA display, and PF display and see what you have and then it will make sense to you. CFL is not linear load like regular lamp. You will see VA value is higher than the Watt value due to PF.
                • marce002
                  UT210E clamp meter amps measurements wrong
                  by marce002
                  Hello all
                  I have an UT210E clamp meter that went wrong doing amps measurements in continuity DC, it shows an offset of around 4/5A when first set, (lever at DC 10A) at 2A DC shows fixed 0L always......,,,,,, and also does not allow me to (zero button) , and as i said it is even worse in the 2A !! setting which do nothing and shows "0L"... when you can measure DV in 20A after achiving a ZERO with many RESET ZERO times , you can measure with a lot of offset..... eg 1A current is measured at around 650 mamps, . Similarly, a 4A current is shown at around 3A. |O
                  05-08-2020, 11:52 AM
                  Bought a volt multi meter that is capable of data logging Hantek 365C USB/Bluetooth Data Logger
                  by sam_sam_sam
                  I have had this in my wish list for quite a while now and I might need to test BMS protection board with this device because of the limitations of the battery testing machine that I have been using
                  https://www.aliexpress.us/item/32568...yAdapt=glo2usa
                  What this will allow me to do is use my load testing machine that is having issues with the voltage cutoff set/ current meter monitoring system and I decided not to try to replace it or repair it I just going to use a very primitive load testing...
                  03-30-2025, 11:05 AM
                  AE20218 Milliohm Meter Kit, 0.1 Milliohm Resolution, Four Wire Measurements bought one
                  by sam_sam_sam
                  I have been in need of a mega ohm meter for a while but just could not make up my mind to which one I want to buy and this one has a couple of things going for it can also be used on a computer to display a resistance graph plus it is a kit that you put together supposedly the only parts installed are the surface mount components
                  I will probably make a rechargeable battery pack for so it can be used as a portable device and anywhere
                  I kind a wish that it had a higher resistance value higher than 240 ohms at 10 milliamperes on high range but it is what it it
                  On the...
                  03-15-2025, 05:10 PM
                • Baldbentley
                  repairing a Fluke 335 clamp meter
                  by Baldbentley
                  I am repairing a Fluke 335 clamp meter. After contacting fluke it appears there is no service manual or circuit board/ component list available. I have determined that there us a faulty PNP bipolar junction transistors shown in the pictures. I am having trouble sourcing this transistor. I pulled a good one off of the board and tested it with my component analyzer but I cannot find anything that matches the specifications. Any help locating this part or a replacement would be greatly appreciated.
                  Thanks...
                  10-18-2023, 02:05 AM
