No lead solder use on a safety relay controller
    • Jul 2011
    • 6070
    Here is one that gave me a real big headache---->
    This unit is on a Plasma Cutting Table
    This start about 3 months ago
    The machine would work ok ---->
    Then all of sudden the machine stop in its track as though you hit E stop
    But you did not do that
    You would hit the power button to restart the machine and would work again for awhile and it might or might do it again that day this at the beginning of this problem
    Then it started doing this more and more but it would most of the time you could restart it
    Then it started doing this a little different---->
    It would shut off but then the (safety relay) -->(MSR15D) --->would come on but the machine would not power all the way but it dose not have any errors
    This went on for about month or so like this ----->
    Then one day last week it would not come back ON at all
    Now this safety relay controller has
    2 inputs for the E stop switches
    3 outputs for controlling the machine
    1 set of contacts to active the safety relay controller
    2 contacts for power supply to the safety relay controller
    It has 5 relay in this controller and four boards in a box formation this was a real trip to take apart to check the relay in question to check it
    So I checked the outputs contacts on the controller and found one set has voltage on it when it should NOT have any at all
    So I took the safety relay controller apart and what do I find is that one of pins on the board for the relays has turn the real brown but the soldering joint did not look that bad so I though that the relay contacts had gone bad but NO
    When I remove the solder from the board the pad came off with it and was not in one pice but it had turn black and looked like small grain pepper what hell is this
    I have seen this before where the pad come off the board but the pad comes off hole or in half or part of it ----->but this is the first time that I have seen it this bad
    Now I was able to repair this board with wire wrapping wire
    It was not the prettiest thing in the world but it worked
    ****** My boss is real happy now ********
    Now the machine is back up and running again
    This was a headache to figure out what was going on with this machine
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: No lead soldier use on a safety relay controller
    Am i missing something, or are there no images?
    Follow the white rabbit.
    • redwire
      • Dec 2010
      • 3912
      I don't see it as caused by the no-lead solder?
      A fractured solder joint arcing, or (old) relay contacts make heat and end result is a burned pin on the PCB. One cooked pin on a relay, see that in appliances. It starts fires in dishwashers or stoves, the high-current/high-inductance loads are mean to a poor connection.
      Vibration might be a problem, if the plasma cutter's vibrate the PCB then all heavy through-hole parts can fracture their solder joints
        • Jul 2011
        • 6070
        When the solders is no lead the solder is not shine
        When lead solder is used it is shine-e
        At least that what I have noticed
        I could be wrong
        I am sorry that I did not take photos of these boards
        I have a vacuum Desoldering gun that captures the solder
        When lead solder is use you get a ball of solder that all stays together
        When lead free solder is used it is a lot of very small pieces that do not stay together
        Also when you heat the soldering joint the solder does not flow very easily and takes a lot more heat I have the Desoldering gun temperature set 775* F so I get on the soldering joint and get off of it quickly but with this type of solder you have to stay on it longer to get all of solder out of the joint and lot of the time I have to put some leaded solder for all of the solder to come out of the joint
        Now with leaded solder with the Desoldering gun set at 775* F I can do this very quickly and most of the time I get all of the solder to come out the joint
        This how can I tell which type of solder is used
        One note the pin on the relay was not burn it was the pad that was destroyed
        Now I could be completely wrong but this is what I have noticed
          • 31278
          When the soldiers is no lead the soldier is not shine
          When lead soldier is used it is shine-e
          I could be wrong
          you are wrong, *good* lead free solder like i use does shine.
          it's just the cheap crap used in chinese factories that doesnt.
            • Jul 2011
            • 6070
            Ok thanks
            Can you recommend some good lead free solder
              • 31278
              btw, i dont think it's the actual solder - i think it's the flux used in the solder.
              because good & bad ones use pretty much the same alloy but are very different to use!
              i use stannol solder, 99% tin 1% copper with krystal505 flux.
              that's a water clear colourless very mild flux you can hardly see like a thin layer of glass.
              very hard to find though
              the next one up that i also have is the same alloy with HS10 flux.
              that's more what your probably used to, mild golden flux with a bit of rosin in it.
                • Jul 2011
                • 6070
                btw,
                You can find it on eBay from Germany but it is not to bad in cost
                Here is the link that I found it at
                http://www.ebay.com/itm/STANNOL-Sold...WkV1a#shpCntId
                  • 31278
                  that's 60/40 not lead-free.
                  but anyway, finding HS10 loaded solder is easy - it's finding krystal505 that's hard!
                    • Jul 2011
                    • 6070
                    i did find it on eBay but it is expensive
                    I found this will this work even this is a little expensive as well but not as bad
                    http://www.ebay.com/itm/MULTICORE-LO...3D322297499802
                      • 31278
                      that has silver in it!
                      anyway, i may have found a source (re-labelled) of solder with krystal505 at farnell
                      • fadi90
                        PILZ PNOZ X4 Safety Relay
                        by fadi90
                        I'm working on repairing a Pilz PNOZ X4 safety relay module. When I opened it up, I found some of the connector pins detached from their pads. I replaced the connector with individual wires, but the issue remains.
                        The module is set to dual-channel mode with manual start. In this mode:
                        • Y36-Y37 and Y1-Y2 are bridged.
                        • 24VDC is applied across A1-A2.
                        • It monitors two emergency circuits (S11→S12 and S11→S52).
                        • When both are closed (24V present on S12 and S52) and the start button is pressed (S33 connected to S34), the NO contacts (13-14, 23-24, 33-34)
                        06-07-2025, 01:21 AM
                      • CoinCoin88
                        Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                        by CoinCoin88
                        I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                        Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                        09-15-2025, 03:36 AM
                      • master3112
                        ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
                        by master3112
                        I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
                        When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
                        10-29-2024, 09:32 PM
                      • acedogblast
                        by acedogblast
                        11-02-2024, 05:13 PM
                      • valvashon
                        Repair Success! Middle Atlantic UPS2200R-IP
                        by valvashon
                        Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                        Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                        02-06-2024, 12:54 PM
