First circuit design needs to be checked please?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8716
    Re: First circuit design needs to be checked please?
    It's never as simple as one thinks at first...
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      Here is the completed circuit up close and personal ... with a question at the end...
      I made a video!
      sigpic
      • EasyGoing1
        Shock Therapist
        • Sep 2016
        • 977
        Boy ain't that the truth ... and no more truer with any discipline other than electronics.
        sigpic
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8716
          I think it was already stated before: Silicon and other semiconductor materials have a negative temperature coefficient - it gets more conductive as it gets hotter (at a certain point). As it gets more conductive, resistance goes down, and the voltage drop across the transistor goes down. Since power is getting dissipated in the solenoid as it has the highest impedance (1A 12V drop = 12W and R=~12 ohms) luckily this does not cause the destruction of the transistor. If the lowest resistance element of the circuit is actually the transistor, the power would be dissipated in the transistor and potentially cause runaway heating and thus destruction of the transistor.
          Oh, and also wanted to add:
          Copper has a positive resistance coefficient, so as the solenoid heats up, it becomes more resistive and thus the voltage drop across the solenoid will increase. So you have both the semiconductor and the solenoid working together to show you that strange effect. I would think the solenoid heat up actually is generating more of the effect than the semiconductor, actually.
          • EasyGoing1
            Shock Therapist
            • Sep 2016
            • 977
            Yeah, it seems in this case, the recipe is just right...
            sigpic
            • EasyGoing1
              Shock Therapist
              • Sep 2016
              • 977
              That sounds logical .. and thank you for the explanation ... so as the solenoid gets warmer, its resistive properties increase, and as a result, it takes on more voltage over time ... is that an accurate description of whats going on there?
              Also, is there any possibility that such a phenomena could shut down the transistor ... under difference circumstances perhaps?
              sigpic
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8716
                As the voltage across the transistor goes down, it's going deeper and deeper into saturation, this is fine. I'd be more worried about any thermal meltdown of the solenoid as it's dissipating 12W worst case. I don't know what the maximum duty cycle of the solenoid is rated for...
                  The solenoid is going to be on just long enough to open the hidden compartment.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8716
                    Unless it's typical for the solenoid to heat up. Not sure if he expect to use it until it starts heating up frequently, but yes, ideally one would trigger, open, release within a few seconds. There should be plenty of thermal mass to not detect any heat...
                    • EasyGoing1
                      Shock Therapist
                      • Sep 2016
                      • 977
                      Under normal use, the solenoid will be actuated for less than two seconds ... long enough to open the door ... then when I'm done doing whatever, long enough to close the door. And that door might be accessed two to three times a week at best?
                      I think this thing should last quite a while.
                      sigpic
                      • Powderfanupnorf
                        Dell AL440LX power on switch circuit help required
                        by Powderfanupnorf
                        Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
                        So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
                        My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
                        06-24-2024, 01:24 PM
                        Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                        This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                        09-06-2024, 05:30 AM
                      • fab13
                        Nintendo Switch lite charging chip heats up and does not short circuit
                        by fab13
                        Hello everyone
                        Small technical problem on a Nintendo Switch lite
                        Here's what I noticed: the USB port has been damaged internally, with a short circuit on the power supply line to the small fuse.
                        After replacing the USB connector, the short circuit went away and I can't see any other short circuit in the whole motherboard.
                        When I charge the console, it seems to be charging: I get 15 volts and an amperage of 0.450 A.
                        Then, after a while, the amperage increases to 1.1 A and the BQ24193 charging chip starts to heat up, as evidenced...
                        09-16-2023, 04:59 AM
                      • Natob82
                        Micro Momentary Push Switch?
                        by Natob82
                        Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                        12-21-2022, 05:22 AM
                      • grimacelord
                        NEC TurboExpress On/Off Power Switch Replacement Help
                        by grimacelord
                        I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                        I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                        I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                        11-09-2023, 09:49 AM
