Capacitor curiousity
  • Bobdee
    • Jun 2008
    • 461
    Hello Guys
    Can you help me, I removed 4 caps from old m/board brand Ost series RLX 3300uF 6.3V they appeared to look good, bungs fine, no bulging.
    When measured with ESR meter several times, over several days at room temp, they read around 4400uF and 0.00 esr, no doubt caput but what causes the caps to go high, well above there tollerance and reduce in ESR and still look good.
    The caps I normally remove that are bad go down in capacitance and up in ESR as you know.
    Can you tell me why they go like this???
    Does this happen often???
    Will look forward to your replies
    many thanks
    bobdee
  • Wizard
    • Mar 2008
    • 2296
    Re: Capacitor curiousity
    ESR is where water and chemical are, basically the electrolyte formulation comes from. If not right, poor seal or combination of many, the electrolyte dry out and ESR rises. Sometimes violently enough that tops or bung blows out, sometimes boiling and pressure builds quietly then gently pop or with a noise.
    And if you see listed of brands like OST it's granteed to go bad with time and use.
    Cheers, Wizard
    • i4004
      • Oct 2006
      • 2029
      >no doubt caput
      what is caput?
      it seems to me you've taken out the good caps and now you're wondering how come they're good.
      • gdement
        • Jan 2007
        • 690
        Originally posted by i4004
        >no doubt caput
        what is caput?
        4400uF is out of tolerance. But maybe they're not particularly bad other than that.
        • Bobdee
          • Jun 2008
          • 461
          Hi again Guys
          Thanks for input, so you think these caps could still be good, if thats the case they must have been manufactured with way over tollerance, or something made them go that way, is thats possible???.
          Also the 0.00 ESR, I am sure I read in a capacitor thread (Ithink byTopcat) a while back, that it is not possible to have a good cap with 0.00 ESR, so I still find that very strange why these caps are like this.
          Look forward to revised, and new input from you.
          Many Thanks
          Bobdee
          Sorry about the caput, should have been kaput, meaning had it, gone bad,dead ect
          • i4004
            • Oct 2006
            • 2029
            i doubt it.
            other thing 0.00 esr may suggest is short circuit, but if it's that than capacitance would be at 0.
            (use normal multimeter to test for that...)
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              likely esr meter cannot measure low enough
              • Bobdee
                • Jun 2008
                • 461
                Hi Guys
                Tested with m/meter for shorts across terminals both ways, and terminals to casing, no shorts.
                Also ESR meter is ATLAS esr60, it measures from 0 to 20 Ohms, resolution as low as 0.01, and if capacitence more than 20 Ohms reads >20 Ohms, did a probe compensation test on meter, tested OK.
                Bobdee
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  iirc in the first stages of cap death the uf value rises.
                  • Bobdee
                    • Jun 2008
                    • 461
                    Hello again Guys
                    At first I thought iirc that was mentioned by Kc8adu was a chemical component inside capacitor untill I googled it.
                    Found abbreviation meaning, IF I Remember Correctly, it was new to me, but I will remember that one.
                    I think hes hit the nail on the head with his explanation, I can certainly go with that, and bin the caps as kaput, unless anyone has more to add.
                    I would like to thank everyone for there input, much appreciated, I have learned from this experience.
                    Bobdee
                    If anyone has a link to read up on this rise in capacitance, I would like to hear from you.
                    • MORETTIGIAN
                      by MORETTIGIAN
                      Title:
                      Description:
                      Procedure performed:
                      - Removed backplate
                      - Reapplied thermal compound
                      - Reassembled card
                      09-18-2025, 12:14 PM
                    • Prolog
                      by Prolog
                      12-01-2024, 08:27 PM
                    • Agent24
                      Dick Smith Q-1760 linear power supply filter capacitor question
                      by Agent24
                      I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                      It has at least one problem.
                      The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                      I have already ordered a replacement potentiometer, so that's not an issue.
                      Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                      All are CapXon...
                      10-21-2025, 05:39 PM
                    • chth96
                      by chth96
                      12-22-2023, 04:34 AM
                    • chth96
                      by chth96
                      06-02-2024, 07:31 PM
