iPhone backlight circuit operation question
  • caphair
    replied
    Re: iPhone backlight circuit operation question
    Originally posted by redwire
    Why would Apple use an extra inductor and diode?
    One inductor is 1uH/3.6A and the other 15uH/0.72A, so a high power and low power mode.
    Boost converters have high peak input currents, even if the load is small.
    I would say there's no room in an iPhone for a big capacitor to absorb those spikes and they switch over to the bigger inductor to lower electrical noise.
    During a call, you want a low noise on power for cell comms. Also for lowering EMI with dual-frequency or multi-phase between the two boost converter outputs. But I don't see the one inductor capable of anything but low brightness.
    It also looks like they are turning off the LED boost converter during a GSM TX (packet) burst, to save available power. Long range GSM transmit power can take almost 2A.
    Is it in theory working like a power factor correction? Or simply to compensate for high current demand when needed?
  • Stefan Payne
    replied
    Originally posted by caphair
    I've seen lots of videos on iPhone repairs. But I feel a lot of the people don't have clear understanding of electronics theory and circuit operation. They're mostly checking for shorts and replacing components. I'm sure they know basic stuff but I'm trying to understand circuit operation
    I think I've heard about him. Don't know when or why, but that's a rather good thing.
    But yeah, most people don't know what they're doing, maybe you'd like to watch something from "Grandma" as Louis Rossmann likes to call her:
    https://www.youtube.com/channel/UCPj...e1o_lp1US9TpWA
  • caphair
    replied
    Is the 15uh inductor responsible for the high power?
    When you say it's turning off boost during a gsm tx, does that only happen when the screen is off? If not how does the backlight stay lit if that's occurring
    How does it know when to switch to the other inductor to lower noise?
  • redwire
    replied
  • caphair
    replied
    Originally posted by budm
    It looks like both inductors are not driven at the same time, one is when high current demand is needed and one for lower current demanded.
    That's my guess but the earlier iPhone 6 screen used same size screen so my curiosity is why add the dual coils. Unless the 6s is brighter.
  • caphair
    replied
    Originally posted by Hellfiya
    From what I've seen, there are dual circuits only in the Plus models, probably due to the larger screen.
    Could this have anything to do with having two coils?:
    If I'm understanding that circuit correctly, its to eliminate any start up voltage hiccup from boosting and produce smooth output?
    replied
    You can see one of the signal line has the word 'BURST', may be it has something to do with that. You also check the 'SWx' outputs to see what is going on. One inductor is rated at 3.6A, another one is rated at 0.72 A.
    No luck so far for the spec sheet of the IC.
  • Hellfiya
    replied
    Right but why are the coils two different kinds? At first I thought two of everything for one half of the screen for maybe two led strips, but when noticed coils are different specs it got me wondering
    I must've been editing my previous comment whenever you responded, but check that link. It looks fairly similar to the iPhone's backlight circuit. Looks like it has something to do with Electromagnetic interference?
    Oh, and this may be off topic but sometimes after I replace a screen on an iphone, the backlight flickers, even if I unplug it and plug it back in. But it always subsides over a few hours. Not sure if that has anything to do with EMI. It has happened maybe 5 or 6 times out of about 400 screens.
  • caphair
    replied
  • Hellfiya
    replied
    This artical by jessa says The backlight circuit is split into two. There are two coils, two diodes, two filters that come together to feed one LCD connector.
    http://mendonipadrehab.com/entries/g...-post-3?page=3
  • caphair
    replied
    That doesn't answer my curiosity as to why there's two of each and how they work together. In other iPhone models there's only one of each
  • vinceroger69
    replied
  • caphair
    replied
    I was thinking it might be multi-phase.
    Multi-phased for different current demand or?
  • PeteS in CA
    replied
    replied
    If you want to really understand the circuit operation then you need to start making actual measurement to see what is going on in the circuit such as this backlights controller IC
  • caphair
    replied
    Not sure if you watch chris long videos on youtube but maybe when hes doing a live stream ask him as hes really good at answering any questions people have regarding iphone repairs etc
    https://www.youtube.com/channel/UCQV...ZSv5BgQ/videos
  • vinceroger69
    replied
    replied
  • caphair
    replied
    Boost converter.
    Just look up 'BOOST CONVERTER'
    Since you have the P/N of the IC then just look up the spec sheet to see how it works, it is LED driver LED.
    No data sheet available. I know it's a boost converter I'm wondering the purpose of two coils of different sizes as oppose to just one
    replied
    Boost converter for driving the LED strings..
    Since you have the P/N of the IC (LM3539) then just look up the spec sheet to see how it works, it is LED driver LED.
  • gizmo1990
    What is this PSW1 part on a circuit board? Trying to fix a Canopus ADVC-300 DV/VHS Converter
    by gizmo1990
    I'm trying to fix this Canopus converter so that I can convert lots of old VHS cassettes. The problem is that it turns on for a split (and I mean split!) second, the fan jerks and then.. nothing. I've checked the power brick works. I've opened up the converter itself and been testing for shorts.
    The image attached shows the on/off switch (which I've checked works) to the left of the yellow socket. Below the yellow socket is a green block marked 26 with a strange symbol at the front. Putting my probes either end of this block, on the silver parts, gives an open short...
    10-21-2024, 08:02 AM
  • triplefour
    by triplefour
    09-13-2023, 10:43 PM
  • Comp_Pro
    No Backlight Macbook A1990 820-01041
    by Comp_Pro
    Hello all,
    Am trying to figure out this backlight issue with this A1990 Macbook Pro.
    Tests performed:
    There is no backlight even with a good screen.
    Backlight IC is receiving the correct support voltages.
    Fuse F8400 ok
    Current sense resistor R8400 ok
    Backlight IC is receiving 3.3V on enable pin.
    Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
    Backlight IC receiving 5V from PP5V_G3S
    Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
    I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
    05-06-2024, 10:23 PM
  • redbaron1007
    Yamaha HTR-3065 No power/No Standby
    by redbaron1007
    I got a Yamaha HTR-3065 on the bench currently that's got a no power/ no standby issue.When I plug it in it draws 0.01A from the wall, the relay for the ac transformer never clicks, there are no standby lights on the front, and pressing the power button does nothing. The fuse was not blown but upon measuring the voltages on the power low voltage power supply board (labeled operation 3 pg 89 in the schematic) they do not match what the schematic says they should be.
    S9 13.7V
    Pwr Ry 0V
    AC Det 9.1V
    Mgnd 0V GND
    The two pins on the transformer for the operation...
    09-12-2024, 03:04 PM
  • phuzzyday
    My horror movie continues.. "70X690E Power Supply- the Sequel - Attack of the Backlight circuit!"
    by phuzzyday
    This was my initial thread.. https://www.badcaps.net/forum/troubl...-m-at-wits-end
    (All the Electrolytics are brand new.)
    I started a new one, hope that's ok, because my question is different now! (Strangely enough, after I walked away for a few weeks, it stopped lighting up at all!!)
    I am determined to fix this power supply because I have the skills to replace bad components, I just need to find out...
    05-30-2025, 05:20 PM
