iPhone backlight circuit operation question
  • caphair
    replied
    Re: iPhone backlight circuit operation question
    Originally posted by redwire View Post
    Why would Apple use an extra inductor and diode?
    One inductor is 1uH/3.6A and the other 15uH/0.72A, so a high power and low power mode.
    Boost converters have high peak input currents, even if the load is small.
    I would say there's no room in an iPhone for a big capacitor to absorb those spikes and they switch over to the bigger inductor to lower electrical noise.
    During a call, you want a low noise on power for cell comms. Also for lowering EMI with dual-frequency or multi-phase between the two boost converter outputs. But I don't see the one inductor capable of anything but low brightness.
    It also looks like they are turning off the LED boost converter during a GSM TX (packet) burst, to save available power. Long range GSM transmit power can take almost 2A.
    Is it in theory working like a power factor correction? Or simply to compensate for high current demand when needed?
  • Stefan Payne
    replied
    Originally posted by caphair View Post
    I've seen lots of videos on iPhone repairs. But I feel a lot of the people don't have clear understanding of electronics theory and circuit operation. They're mostly checking for shorts and replacing components. I'm sure they know basic stuff but I'm trying to understand circuit operation
    I think I've heard about him. Don't know when or why, but that's a rather good thing.
    But yeah, most people don't know what they're doing, maybe you'd like to watch something from "Grandma" as Louis Rossmann likes to call her:
    https://www.youtube.com/channel/UCPj...e1o_lp1US9TpWA
  • caphair
    replied
    Is the 15uh inductor responsible for the high power?
    When you say it's turning off boost during a gsm tx, does that only happen when the screen is off? If not how does the backlight stay lit if that's occurring
    How does it know when to switch to the other inductor to lower noise?
  • redwire
    replied
  • caphair
    replied
    It looks like both inductors are not driven at the same time, one is when high current demand is needed and one for lower current demanded.
    That's my guess but the earlier iPhone 6 screen used same size screen so my curiosity is why add the dual coils. Unless the 6s is brighter.
  • caphair
    replied
    Originally posted by Hellfiya View Post
    From what I've seen, there are dual circuits only in the Plus models, probably due to the larger screen.
    Could this have anything to do with having two coils?:
    If I'm understanding that circuit correctly, its to eliminate any start up voltage hiccup from boosting and produce smooth output?
    replied
    You can see one of the signal line has the word 'BURST', may be it has something to do with that. You also check the 'SWx' outputs to see what is going on. One inductor is rated at 3.6A, another one is rated at 0.72 A.
    No luck so far for the spec sheet of the IC.
  • Hellfiya
    replied
    Right but why are the coils two different kinds? At first I thought two of everything for one half of the screen for maybe two led strips, but when noticed coils are different specs it got me wondering
    I must've been editing my previous comment whenever you responded, but check that link. It looks fairly similar to the iPhone's backlight circuit. Looks like it has something to do with Electromagnetic interference?
    Oh, and this may be off topic but sometimes after I replace a screen on an iphone, the backlight flickers, even if I unplug it and plug it back in. But it always subsides over a few hours. Not sure if that has anything to do with EMI. It has happened maybe 5 or 6 times out of about 400 screens.
  • caphair
    replied
  • Hellfiya
    replied
    Originally posted by vinceroger69 View Post
    This artical by jessa says The backlight circuit is split into two. There are two coils, two diodes, two filters that come together to feed one LCD connector.
    http://mendonipadrehab.com/entries/g...-post-3?page=3
  • caphair
    replied
    That doesn't answer my curiosity as to why there's two of each and how they work together. In other iPhone models there's only one of each
  • vinceroger69
    replied
  • caphair
    replied
    Originally posted by PeteS in CA View Post
    I was thinking it might be multi-phase.
    Multi-phased for different current demand or?
  • PeteS in CA
    replied
    replied
    If you want to really understand the circuit operation then you need to start making actual measurement to see what is going on in the circuit such as this backlights controller IC
  • caphair
    replied
    Not sure if you watch chris long videos on youtube but maybe when hes doing a live stream ask him as hes really good at answering any questions people have regarding iphone repairs etc
    https://www.youtube.com/channel/UCQV...ZSv5BgQ/videos
  • vinceroger69
    replied
    replied
  • caphair
    replied
    Boost converter.
    Just look up 'BOOST CONVERTER'
    Since you have the P/N of the IC then just look up the spec sheet to see how it works, it is LED driver LED.
    No data sheet available. I know it's a boost converter I'm wondering the purpose of two coils of different sizes as oppose to just one
    replied
    Boost converter for driving the LED strings..
    Since you have the P/N of the IC (LM3539) then just look up the spec sheet to see how it works, it is LED driver LED.
