This is more of a general question to something I've seen more than once.
If a MCU or CPU etc reset line is pulled low due to the MCU, could you change the pull up resistor to a lower value (for example 100k to 1k) to pull the line up to the proper voltage to get it going or is that a bad idea?
Also what would happen if the resistor was replaced by a wire? Too much current going to ground or?
