Full wave rectifier vs bridge rectifier?
  • capwizard
    • Jun 2016
    • 1991
    This is a 25A 12v power supply use full wave rectifier on a bridge rectifier? is because the current? Why not use bridge rectifier connection?
  • petehall347
    • Jan 2015
    • 4424
    • United Kingdom
    Re: Full wave rectifier vs bridge rectifier?
    http://www.electronics-tutorials.ws/diode/diode_6.html
    • capwizard
      • Jun 2016
      • 1991
      The Full Wave Bridge Rectifier, the main advantage of this bridge circuit is that it does not require a special centre tapped transformer, thereby reducing its size and cost.
      I don't understand the manufacture wants cost-cutting they should take the advantage of The Full Wave Bridge Rectifier and uses smaller transformer?
      PS: Some of the old 200A car battery changers their also use Full wave rectifier
        "Full wave rectifier vs bridge rectifier?" They are Both Full wave rectification. Full wave using xformer with center tap, one without center tap; both accomplish full wave rectification.
        • capwizard
          • Jun 2016
          • 1991
          I need to open doors and windows, the smoke comes out from this bridge rectifier!
          Isn't that bridge rectifier use half current compares to Full wave rectifier? (they connected this bridge rectifier as a Full wave rectifier!)
          PS: Can I modify to bridge rectifier? The transformer is 12-0-12.
            Bridge rectifier IS FULL wave rectification, full wave using center tap transformer IS FULL WAVE. There are advantage and disadvantage for both of them but the end result output is still full wave for both type with ripple frequency twice of the AC input.
              What is that device? It looks like you have diode failure. What is the required output?
              The whole pictures of the device? Your pictures are not showing all the wires of the transformer.
              Are they using 12-0-12 to make dual output (+/-) suppliers?
              It looks like they are using only half of the diodes in that bridge package, they are doing that form factor to make it easier to cool the diode package, it is full wave center tap rectification.
              • capwizard
                • Jun 2016
                • 1991
                This 13.8v 20A power supply. it makes Wuuh...Wuuh noise and smoke comes out, I found is the bridge rectifier did that.
                I test the TRs (2N3055) none of them shorted, Caps needs to be change. I try to use Two bridge rectifiers to increase the current if that is the only problem.
                PS: Can I use 40.0 AMPS. Schottky Barrier Rectifiers?
                I read:
                Schottky diodes have a much lower voltage drop than the standard silicon types.
                The Schottky diodes will work just as well as normal diodes, by arranging them as you normally would a bridge rectifier. They are not normally used in regulators because they are more expensive and sometimes physically larger. The advantages of a Schottky diode (low forward voltage, fast switching) will not provide any benefit for an ordinary bridge rectifier.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8676
                  That last picture with the schematics makes me go "what the fsck...that doesn't make sense..."
                  I think using a 2-diode rectifier fullwave versus a bridge fullwave rectifier is a relic of the past for 60-cycle. Diodes used to be very expensive. No, not silicon diodes (well, maybe at first) - but definitely vacuum tube diodes. People were used to building full wave rectifiers with center tapped transformers and that carried on to silicon out there.
                  2-diode full wave still has a bit less power loss due to less drop, but costs much more to make the transformer - so nowadays bridges are the norm if halfwave isn't sufficient.
                  Now a bridge rectifier with center tapped transformer is a quick way to generate a bipolar supply which sometimes is still needed for op amps, etc. - if a charge pump is more expensive.
                    In the pictures, it shows only three of the four terminal are being used, that is because it is using center tap transformer so they are using only two for diode inside that bridge rectifer, it is single not dual output supplies.
                    https://www.badcaps.net/forum/attach...3&d=1486055357
                    Left drawing is wrong, look at how many terminals on the bridge rectifier being used in the unit. Your drawing has the bottom winding shorted out.
                    Right drawing you have FOUR diodes drops (2 Vdrops per each half of the cycle), wasted power.
                    See how it is wired yet?
                    • capwizard
                      • Jun 2016
                      • 1991
                      budm..........You are the BEST! Thank you very much.
                      • petehall347
                        • Jan 2015
                        • 4424
                        • United Kingdom
                        put some star diodes in there ...
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8676
                          so does it smoke if the bridge output is disconnected from the filter capacitors?
                          Any luck finding where the actual fault is?
                          hmm... nice to have a high current CV PSU... I only have an SCR-regulated 15A variable CV/CC. Its regulation is pretty horrible.
                          • capwizard
                            • Jun 2016
                            • 1991
                            Y...YYY...YES I fixed it!................"Any luck finding where the actual fault is?"......The problem is the bridge rectifier!.........
                            I like to experience with science projects, "The Schottky diodes will work just as well as normal diodes." So, I sub to two KCF16A60s, parts from used common Plasma TV regelation diodes, Ultra – Fast Recovery 16A 600v.
                            PS: I will use heater coil as 1 ohm resistor to test the current of this power supply.
                            PS: Dont bug me because this is mine.
                              Paralleling diode without balancing will have problem, the one with lower Vf will have most Vf the current flowing through it, and when it heat up the Vf goes down more so more current flow that and then you will have thermal run away.
                              I hope dual-diode package has really close Vf.
                              BTW, Ultra fast for this application is not going to be better, Vf is 1.7V at 8A per spec, so power dissipation will be 1.7V x 8A =13.6W/2 (DUE TO 50% DUTY CYCLE) = 6.8W at 8A Ambient of 25c, so at 20~25A you will see more power.
                              You want diode with lowest Vf as posiible.
                              • capwizard
                                • Jun 2016
                                • 1991
                                I will use heater coil (pic1) as a (13.8v / 20A =) 0.68 ohm resistor to test the current of this power supply. Any better and cheap idea to test the 20A current?
                                PS: Car headlights are pretty good!
                                  I will use heater coil (pic1) as 13.8v / 20A = 0.68 ohm resistor to test the current of this power supply. Any better and cheap idea to test the 20A current?
                                  Is that Hot or COLD resistance? Material type?
                                  https://farnam-custom.com/resources/...r-coil-design/
                                  http://electronics.stackexchange.com...er-dissipation
                                  • capwizard
                                    • Jun 2016
                                    • 1991
                                    Use the cold resistance is better. (...........to do that you'd need to know the temperature of the heated wire... calculating that would be non-trivial, especially in airflow..........) just merge the coil inside A bucket of water, it is at low voltage should be OK! Does headlight more safe?
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8676
                                      Weird that the diodes died, usually PSUs the other components die. It looks like in this case this PSU the weak point is the rectifier :o
                                      Honestly I have never tried my bench PSU at 15A, I sort of just assumed it will work. It does have an ammeter and I've driven DC-120VAC inverters with it as a test load. Using 22 gauge wire with the AC inverter to power a 100W incandescent lamp causes enough drop to make it stop working properly, not to mention the wires get warm/hot...
                                      22 gauge isn't enough for 10A. I doubled up/tripled up as a workaround.
                                      • capwizard
                                        • Jun 2016
                                        • 1991
                                        To eccerr0r: my next project is the 40A 12v or 96v 5A (lots combinations) power supply. it needs eight 12V 5A AC Adapters, I still collect them. It is A Universal AC Adapter Modular Power Supply.
                                        PS: Use four 12v 5A AC Adapters (up to 12v 20A) can replace the one I just fixed.
                                          HP Pavilion Wave Pavilion Wave Desktop - 600-a103na Pavilion Wave i3-7100T Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a103na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a103na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a103na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          09-12-2024, 02:00 PM
                                        • Steph.hen
                                          Bridge rectifier identification part number KPB305G
                                          by Steph.hen
                                          Hi all, a newby question about a bridge rectifier I'm trying to identify.
                                          I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?...
                                          08-29-2024, 09:52 AM
                                        • mpn78
                                          Fujitsu Q556, What capacitor for bridge rectifier?
                                          by mpn78
                                          Hello
                                          My Fujitsu Esprimo Q556 motherboards blew up. At least fuse, bridge rectifier and capacitor got damaged. I have changed fuse and bridge rectifier (DF1508S), but I don't know what capacitor it is (picture). I know that capacitors size is 47nF, but I don't know other specs for it. Can you help me to choose right capacitor for my motherboard?
                                          There is 240V AC on input side of bridge rectifier and 340V DC as output on capasitors side.
                                          Thanks....
                                          04-05-2022, 12:31 PM
                                          HP Pavilion Wave 600-a102ng Pavilion Wave i3-7100T Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Wave 600-a102ng can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave 600-a102ng boardview and Pavilion Wave 600-a102ng schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        • EasyGoing1
                                          Reading input and output of bridge rectifier on the same scope?
                                          by EasyGoing1
                                          I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
                                          When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
                                          06-26-2022, 12:52 AM
