Overrated Capacitors?
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Overrated Capacitors?
    tantalum i did not see for a few years.
    there is also rubycon pc-con polymer caps
    http://www.rubycon.co.jp/en/pc-con/index.html
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      going back to the topic of ripple current affecting lifetime of caps. How does throwing a UPS into the equation figure. generally i have found good caps in UPS systems. or do UPS not really filter to the level we are interested in.
      • stretch0069
        Screwed Up Super Moderator
        • Oct 2003
        • 2658
        • oooo ess aaaaaaaaa
        Originally posted by willawake
        is it possible that low quality psu can affect cap lifetimes on a motherboard.
        Way back when I first had trouble with my VP6, it was recommended that my PS was screwy. I replaced it with a higher rated Antec (I think....I hate getting old) and it ran fine for a couple months. Then the old problems came back. I replaced the caps on the MB and all was well.
        So I would have to say that yes....a bad PS can cause more problems.
        "Its all about the boom....."
        Guns kill people like spoons made Rosie O'Donnell fat.
        We now return you to your regularly scheduled drinking.
        "Fear accompanies the possibility of death.....calm shepherds its certainty"
        Originally posted by Topcat
        AWD is just training wheels for RWD.
        • PeteS in CA
          • Aug 2005
          • 3581
          • USA, Unsure of Planet
          did you test any panasonic?
          Yes. I've gotten inconsistent results with FC, excellent in one voltage/case, poor in another. With FM, I've had less experience, as the max voltage for the series is 50V. That said, the FMs I've tested have performed very well. With the three 'Cons and Panasonic/Matsushita I do not at all doubt the ESR, Ripple Current, or life ratings. What I'm observing is how they perform under abuse.
          is it possible that low quality psu can affect cap lifetimes on a motherboard. how does eliminating caps from the original design for cost savings affect also.
          Yes. The ripple current is going to be about the same. With crap caps in the P/S, MB caps on the same line may see increased ripple current. In the same way, if a cap is eliminated, whether thru not installing or failing, that will increase the ripple current thru the remaining caps (IOW, when one crap cap fails, it hastens the failure of those that remain.)
          PeteS in CA
          • PeteS in CA
            • Aug 2005
            • 3581
            I don't know whether anyone here has heard of this discussion board, but they have an Apple crap caps thread.
            PeteS in CA
            • PeteS in CA
              • Aug 2005
              • 3581
              #26
              Tantalums are dry electrolytic - that's their major feature, apart from compactness and low inductance. They do fail occasionally, but usually only due to overvoltage, reverse polarity and humidity seeping through cracks in the epoxy coat.
              Some tantalums have liquid electrolyte - very acidic IIRC. Tantalums also may fail suddenly and dramatically due to ripple current and ripple current surges.
              PeteS in CA
              • RJARRRPCGP
                • Jul 2004
                • 6304
                which boards are you talking about? the g5 has the most caps i have ever seen on a board.
                Pre-2003 socket A motherboards seem to have the most caps of 1000uf and higher.
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • Chris1992
                  • Apr 2005
                  • 561
                  #28
                  RJARRRPCGP: I had a PCChips M810LMR board, same as ECS K7SEM. It had 10 caps in just the VRM section. Rather weird for a low-end mATX board. I think the 'most caps' award goes to Abit BE6-II though.
                  The great capacitor showdown!
                  • Rainbow
                    • Aug 2005
                    • 1374
                    #29
                    "They're crap and cheap so at least we put a lot of them there".
                    • dragon3x
                      After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                      by dragon3x
                      Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                      power on.
                      Here are some examples :
                      (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                      switching supply area).
                      (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                      than 6.3 V.)
                      1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                      I replaced capacitors with aluminum-polymer.
                      3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                      03-21-2025, 02:46 PM
                    • slybunda
                      AA and AAA battery charger capacitors?
                      by slybunda
                      hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                      it has inside:
                      2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                      2 x 470uf 16v LZ105c branded as G.Luxon
                      not heard of these brands are they any good?
                      iv attached photos of the charger and the board inside for an idea on the type of...
                      12-24-2023, 04:41 AM
                      by sam_sam_sam
                      After all of...
                      07-13-2024, 08:14 PM
                    • LearningToRepair
                      Do capacitors have maximum allowed amps rating?
                      by LearningToRepair
                      Hi!
                      I am interested to know what happens to capacitors when too much load is applied? Do they only pop on overvolt or also on over load?
                      In SMPS caps are in parallel in order to get rid of ripple. If I exceed capacitors supply ability will I only get tons of ripple or will they also explode at the some point? And is there way to calculate max allowed amps for capacitor if I know actual volts, allowed max volts and capacitance? And also is there some rule that for example if I got this power supply from china then calculated maximum load should be divided by 3 to be...
                      04-11-2021, 10:42 AM
                    • chth96
                      Is it no harm to replace with capacitor without ripple current rating?
                      by chth96
                      When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                      Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                      But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                      Rubycon YK DataSheet (b...
                      04-19-2024, 05:19 AM
