Help locating short in iPhone
  • caphair
    • Nov 2011
    • 1249
    Hi guys I'm working on an iPhone 6s+ that has a short on the vcc_main line.
    I've soldered a wire to the vcc_main test point and applied power from bench supply. It draws 3 amps but I can't feel anything getting warm.
    Ive also tried using freeze spray, nothing. Usually doing this makes it evident what's shorted but this time it's not.
    Any tips on how to locate the faulty component?
    • 31281
    Re: Help locating short in iPhone
    increase the current?
    • caphair
      • Nov 2011
      • 1249
      It's maxed at 3 amps
        • 31281
        consider building a new psu?
        my next project!
        http://www.banggood.com/DP50V15A-DPS...p-1072236.html
        http://lygte-info.dk/review/Power%20DPS5015%20UK.html
          • Jul 2011
          • 6070
          Originally posted by stj
          I just bought one of these power supply I watch the video I was impressed with what I saw but we will see when I have it in my hands just what will it do
          • SarcasticOP
            Short on PP_VDD_MAIN on iPhone 12, disappears when I split the boards.
            by SarcasticOP
            Hello Wise Ones,
            I am working on an iPhone 12 that fell into a lake and has a short to the main power rail. I do a general look over the board and see no obvious physical issues such as burned-out caps or a split between the boards and the interposer. I separated the top board and the short seemed to disappear. I then checked every test point that I could and they are all not showing a short at all, even the spot where I initially tested. I assumed that something was causing a bridge in the interposer so I removed all the old solder, reapplied some new solder, and sandwiched the boards...
            05-22-2024, 09:44 AM
          • DynaxSC
            Extreme High Current & Low Voltage Short Killer ??
            by DynaxSC
            Hi Folks
            I'm looking for a extreme high current short killer solution for a reasonable cost.
            I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
            After taking off the socket, the shorts dissappear again.
            The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
            10-15-2024, 10:13 AM
          • Stephen
            MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
            by Stephen
            I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
            02-06-2025, 12:03 PM
          • adelfr2009
            HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
            by adelfr2009
            I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
            After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
            09-28-2025, 10:21 PM
          • Victor Moreira Silva
            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
            by Victor Moreira Silva
            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
            Well, my decice specs are the following:
            Model: Acer Nitro 5 AN517-54-55T5
            CPU: Intel Core i5-11400H
            GPU: NVIDIA GeForce GTX 1650
            Motherboard: GH51G LA-L181P Rev:1c
            The symptom:
            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
            05-26-2025, 10:49 AM
