Short on PP_VDD_MAIN on iPhone 12, disappears when I split the boards.
  • SarcasticOP
    Wildly Mediocre
    • Oct 2023
    • 33
    Hello Wise Ones,
    I am working on an iPhone 12 that fell into a lake and has a short to the main power rail. I do a general look over the board and see no obvious physical issues such as burned-out caps or a split between the boards and the interposer. I separated the top board and the short seemed to disappear. I then checked every test point that I could and they are all not showing a short at all, even the spot where I initially tested. I assumed that something was causing a bridge in the interposer so I removed all the old solder, reapplied some new solder, and sandwiched the boards back together. The short reappeared! I then took it all apart again and retested all the test points and very thoroughly went through the pads on the interposer to see if I missed something and it all looked clean. Not sure what to do now, maybe someone has experience with something like this and can guide me to a repair? I will attach a screenshot of the area I initially tested to see if there was a short.
Name:	iPhone 12 Top Board.png
  • DynaxSC
    Extreme High Current & Low Voltage Short Killer ??
    by DynaxSC
    Hi Folks
    I'm looking for a extreme high current short killer solution for a reasonable cost.
    I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
    After taking off the socket, the shorts dissappear again.
    The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
    10-15-2024, 10:13 AM
  • Stephen
    MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
    by Stephen
    I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
    02-06-2025, 12:03 PM
  • adelfr2009
    HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
    by adelfr2009
    I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
    After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
    09-28-2025, 10:21 PM
  • Victor Moreira Silva
    Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
    by Victor Moreira Silva
    I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
    Well, my decice specs are the following:
    Model: Acer Nitro 5 AN517-54-55T5
    CPU: Intel Core i5-11400H
    GPU: NVIDIA GeForce GTX 1650
    Motherboard: GH51G LA-L181P Rev:1c
    The symptom:
    When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
    05-26-2025, 10:49 AM
  • Geeker007
    9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
    by Geeker007
    Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
    I am new to electronics repair, so my queries could be naive but I am ready to learn.
    So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
    01-28-2025, 03:31 PM
