Is there a polarity for this resistor?
+ More Options
Posts
  • buchman
    • Aug 2015
    • 283
    • greece
    and, it says 0.2 ohm... is that correct? that what it should be?
    My DMM reads 0.6 ohms, does this mean the resistor is dead?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Is there a polarity for this resistor?
    When you touch the two leads from your DDM does it show 0.00 on the display?
    • buchman
      • Aug 2015
      • 283
      • greece
      No, it it show 0.6 ohms.
      • joshnz
        • Feb 2011
        • 969
        • New Zealand
        Resistor has no polarity.
        The resistance you read is your multimeter lead resistance.
        My pc
        CPU : AMD PHENOM II x4 @ 3.5Ghz
        MB : ASUS M4A89TD PRO USB3
        RAM : Kingston ValueRAM 16gb DDR3
        PSU : Cooler Master 850W Silent Pro
        GPU : ATI Radeon HD 6850
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          OK. So when you touch the DMM's RED probe to the BLACK probe you see 0.6 Ohms....This means when you measure, you have to minus 0.6 form what is seen on the display........Then if it is 0.2....you should see 0.8.....minus 0.6 and you have 0.2.
          • petehall347
            • Jan 2015
            • 4437
            • United Kingdom
            resistor is likely fine .. your meter or leads are in doubt .
            • mariushm
              • May 2011
              • 3799
              That's why some multimeters have a button that says REL on them ... clean the leads of your multimeter (ideally use some isopropyl alcohol, but something abrasive works as well, basically to remove whatever oxides and crap is on the leads tips). Then press REL and now the multimeter should ignore the resistance of the wires in your leads. You should get a fairly good measurement of resistance from now on.
              You'd have to use the REL button every time, most multimeters don't have memory to keep track of it.
              • buchman
                • Aug 2015
                • 283
                • greece
                Thanks a lot guys. You all were right.
                • gica69
                  Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
                  by gica69
                  I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
                  Resistor shows orange range silver gold and green lines.
                  Thanks in adv...
                  07-21-2025, 09:49 PM
                • jinu_j
                  by jinu_j
                  Hi
                  05-03-2025, 10:51 PM
                • mikey5791
                  Need help to replace burned resistor in 350w atx psu
                  by mikey5791
                  Hi to all forum members,
                  Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                  The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                  Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                  Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                  12-26-2024, 04:55 AM
                • artvandalai
                  What resistor ohm will work better to repair this waterpik?
                  by artvandalai
                  The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                  01-05-2025, 04:10 PM
                • ResoluteHawk
                  ASUS GA401QM Missing 5v
                  by ResoluteHawk
                  Hello;
                  I have an ASUS G14 GA401QM that currently has no 5v rail among other things stated below in points #3 and #4. I'd like to see if it's condition can be improved.
                  1) Originally this laptop had a problem with a shorted main power rail, so measuring at the current sense resistor after the DC IN FETs yielded a very low resistance. Before proceeding further I measured the CPU coils. We get 8.2 Ohms on the farthest right coil (PL8105) and 3.3 Ohms on the four to left left of it (PL8101 through PL8104). When I injected 1v into the current sense resistor, PQH9402 got warm....
                  03-14-2023, 12:23 PM
